Issue : After installing and configuring the ESXI and VCenter in the Dell server with Tesla P40 GPU card I am not able to start any created VM attached with GPU as PCI in passthrough mode.
Below is the Vcenter settings for graphics for GPU passthrough,
The VM needs to boot in EFI mode, and you need to also set the pciPassthru.use64bitMMIO=”TRUE” and pciPassthru.64bitMMIOSizeGB= (In the case of P40, 64 should do).
Does anybody noticed problems with max resolution used in a windows10 Pro VM using a P40 in Passthrough mode? I’m trying to access using VNC or Teradici and I can only set it to 1440x900 max resolution. In shared mode using part of a P40 as a vGPU I can use 3840x2160 (as native) resolution without any problem.
How can I increase the max resolution supported for a TERA DEFAULT monitor when using the P40 in passthrough mode?
