I have a server and an L40s on it. I want to use the gpu as pass thru and assign to a VM. The server uses Esxi 8.0.0. I have enabled the above 4G, and intel vt-d on BIOS settings. I have successfully created the VM and installed Ubuntu 22 on it. I have also added the keys pciPassthru.use64bitMMIO=“TRUE” ‘pciPassthru.64bitMMIOSizeGB = “64”’ for the VM. The passthru is also enabled for the GPU and the GPU is also visible on the devices section:
But when I add the PCI device to VM and turn it on, the VM does not start. And when I check the devices section I cannot see the GPU, I have to restart the server to see it again:
When I check the logs of the server and the VM the only relevant logs are below, “0000:3a:00.0” is the GPU:
2025-01-07T13:16:26.319Z In(182) vmkernel: cpu36:2097564)PCIEHP: 1476: 0000:39:00.0: hotplug slot:0x4 (0000:3a:00.0) Adapter inserted.
2025-01-07T13:16:26.421Z In(182) vmkernel: cpu36:2097564)PCIEHP: 981: 0000:39:00.0: Enabling hotplug slot:0x4
2025-01-07T13:16:26.421Z Wa(180) vmkwarning: cpu36:2097564)WARNING: PCIEHP: 639: 0000:39:00.0: hotplug slot: 0x4: Device insertion detected while prior device 0000:3a:00.0 removal is still pending
2025-01-07T13:16:28.002Z In(182) vmkernel: cpu36:2097565)PCIEHP: 1571: 0000:39:00.0: hotplug slot:0x4: num reads=1 slot status=0x108.
2025-01-07T13:16:28.002Z In(182) vmkernel: cpu36:2097565)PCIEHP: 1495: 0000:39:00.0: hotplug slot:0x4 (0000:3a:00.0) Adapter removed.
2025-01-07T13:16:28.002Z In(182) vmkernel: cpu36:2097565)PCIEHP: 1047: 0000:39:00.0: Disabling hotplug slot:0x4
2025-01-07T13:16:28.002Z In(182) vmkernel: cpu3:2097563)PCIEHP: 1571: 0000:39:00.0: hotplug slot:0x4: num reads=0 slot status=0x0.
2025-01-07T13:16:30.328Z In(182) vmkernel: cpu36:2097564)PCIEHP: 1571: 0000:39:00.0: hotplug slot:0x4: num reads=1 slot status=0x148.
2025-01-07T13:16:30.328Z In(182) vmkernel: cpu36:2097564)PCIEHP: 1476: 0000:39:00.0: hotplug slot:0x4 (0000:3a:00.0) Adapter inserted.
2025-01-07T13:16:30.328Z In(182) vmkernel: cpu3:2097563)PCIEHP: 1571: 0000:39:00.0: hotplug slot:0x4: num reads=0 slot status=0x0.
2025-01-07T13:16:30.430Z In(182) vmkernel: cpu36:2097564)PCIEHP: 981: 0000:39:00.0: Enabling hotplug slot:0x4
2025-01-07T13:16:30.430Z Wa(180) vmkwarning: cpu36:2097564)WARNING: PCIEHP: 639: 0000:39:00.0: hotplug slot: 0x4: Device insertion detected while prior device 0000:3a:00.0 removal is still pending
2025-01-07T13:16:32.008Z In(182) vmkernel: cpu13:2102257)PCIPassthru: 1587: Disable Domain for device 0000:3a:00.0
2025-01-07T13:16:32.008Z In(182) vmkernel: cpu13:2102257)PCIPassthru: 906: pcipdevInfo: 0x431f070015f0 (0000:3a:00.0), state 0, destroyed
2025-01-07T13:16:32.008Z In(182) vmkernel: cpu113:2098264)PCIPassthru: PCIPassthruForgetDev:556: Forgot device 0000:3a:00.0
2025-01-07T13:16:32.008Z In(182) vmkernel: cpu113:2098264)Device: 802: PCIPassthru:driver->ops.forgetDevice:8013 ms
2025-01-07T13:16:32.008Z In(182) vmkernel: cpu113:2098264)PCIPassthru: PCIPassthruQuiesceDev:454: Quiesced device 0000:3a:00.0
2025-01-07T13:16:32.008Z In(182) vmkernel: cpu113:2098264)Device: 646: PCIPassthru:driver->ops.quiesceDevice:0 ms
2025-01-07T13:16:32.008Z In(182) vmkernel: cpu113:2098264)PCIPassthru: PCIPassthruDetachDev:368: Device 0000:3a:00.0 removed from passthru sbdfmap(0x431f070012a0)
2025-01-07T13:16:32.008Z In(182) vmkernel: cpu113:2098264)PCIPassthru: PCIPassthruDetachDev:374: Detached passthru device 0000:3a:00.0
2025-01-07T13:16:32.008Z In(182) vmkernel: cpu113:2098264)Device: 460: PCIPassthru:driver->ops.detachDevice:0 ms
2025-01-07T13:16:32.008Z In(182) vmkernel: cpu13:2102257)VMKAH: 1523: AH 1 IDs, size 257
2025-01-07T13:16:32Z In(182) vmkernel:
2025-01-07T13:16:32.008Z In(182) vmkernel: cpu113:2098264)Device: 1748: Unregistered device: 0x430dd0806c10 s00000004.00 10de26b910de1851030200
2025-01-07T13:16:32.008Z In(182) vmkernel: cpu113:2098264)Device: 724: pci:ops->removeDevice:0 ms
2025-01-07T13:16:32.021Z In(182) vmkernel: cpu13:2102257)VMKAH: 1523: AH 1 IDs, size 257
2025-01-07T13:16:32.021Z In(182) vmkernel: cpu13:2102257)PCIPassthru: 4769: 0000:3a:00.0: device not found
2025-01-07T13:16:32.052Z In(182) vmkernel: cpu13:2102257)VSCSI: 8300: handle 9029129357762562(GID:8194)(vscsi0:0):Destroying Device for world 2102258 (pendCom 0)
2025-01-07T13:16:32.021Z Wa(03) vmx - PCIPassthru: Failed to get NumaNode for sbdf 0000:3a:00.0
2025-01-07T13:16:32.021Z Wa(03) vmx - PCIPassthru: Selected device 0000:3a:00.0 is outside of the NUMA configuration
Also, I tried to install nvidia gpu drivers for the gpu to use vGPU since the passthru configuration failed. I have followed the guides in the video (Step-by-Step Installation of NVIDIA Virtual GPU Software on VMware vSphere - https://www.youtube.com/watch?v=gJy2dS20so8&t=865s). I have successfullu installed the drivers listed below:
- NVD-AIE-800_550.90.05-1OEM.800.1.0.20613240_23968270.zip
- nvd-gpu-mgmt-daemon_550.90.05-0.0.0000_23967827.zip
and confirmed that the nvidia-smi command outputs the gpu successfully:
Also the SR-IOV is active and pass thru is passive:
However, when I try to access the graphic devices on Esxi to turn on the “Shared Direct”, I cannot find the Graphics Devices section:
Can you help me with the passthru and vGPU problem? For these to work, should I register my gpu serial number in any Nvidia Webiste or follow a similar approach?
