I want to passthrough the GPU to one single VM. But the VM does not starts with the Error:
Module ‘DevicePowerOn’ failed.
I configured it like in the nvidia documentation:
https://docs.nvidia.com/grid/5.0/grid-vgpu-user-guide/index.html#using-gpu-pass-through-vmware-vsphere
the vt-d and the passthrough in ESXi host is active:
https://docs.vmware.com/en/VMware-Horizon-7/7.5/horizon-virtual-desktops/GUID-41547581-2CAC-40D2-AC9F-962E8D649B5E.html
vt-d is 3, it means it is enabled (https://kb.vmware.com/s/article/1011712)
[root@bigdata:~] esxcfg-info | grep "HV Support"
|----HV Support............................................3
ResourceGroup: Skipping CPU times for: Vcpu Id 2104401 Times due to error: max # of processors: 12 < 2104401
ResourceGroup: Skipping VCPU stats for: Vcpu Id 2104401 Times due to error: max # of processors: 12 < 2104401
ResourceGroup: Skipping CPU times for: Vcpu Id 2104403 Times due to error: max # of processors: 12 < 2104403
VM settings, all memory is reserved, instead normal bios is efi:
i try some solution from the internet like set the svga.present=FALSE in VM-Options-Advanced, but the error message still there
