[Driver & Cuda Installation] Conflict packages in Fedora 34 - 470.63.01-1.fc34
After an update on my Fedora 34, I get these messages from the DNF,
$ sudo dnf update
[sudo] password for juan:
Last metadata expiration check: 0:11:32 ago on Fri 24 Sep 2021 09:37:15 CEST.
Dependencies resolved.
 Problem 1: package akmod-nvidia-3:470.63.01-1.fc34.x86_64 requires nvidia-kmod-common >= 3:470.63.01, but none of the providers can be installed
  - cannot install the best update candidate for package akmod-nvidia-3:470.57.02-1.fc34.x86_64
  - package xorg-x11-drv-nvidia-3:470.63.01-3.fc34.x86_64 is filtered out by modular filtering
 Problem 2: package kmod-nvidia-3:470.63.01-1.fc34.x86_64 requires akmod-nvidia = 3:470.63.01-1.fc34, but none of the providers can be installed
  - package akmod-nvidia-3:470.63.01-1.fc34.x86_64 requires nvidia-kmod-common >= 3:470.63.01, but none of the providers can be installed
  - cannot install the best update candidate for package kmod-nvidia-3:470.57.02-1.fc34.x86_64
 Package                                              Architecture                                   Version                                                    Repository                                                               Size
Skipping packages with broken dependencies:
 akmod-nvidia                                         x86_64                                         3:470.63.01-1.fc34                                         rpmfusion-nonfree-updates                                                27 k
 kmod-nvidia                                          x86_64                                         3:470.63.01-1.fc34                                         rpmfusion-nonfree-nvidia-driver                                          11 k
Transaction Summary
Skip  2 Packages
Nothing to do.
Complete!
The nvidia-smi
nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
The kernel I am running: Linux fedora 5.14.7-200.fc34.x86_64
I had it working by following the steps explained here: https://developer.nvidia.com/cuda-downloads?target_os=Linux&target_arch=x86_64&Distribution=Fedora&target_version=34&target_type=rpm_local
I think the issue is that the Nvidia driver provided is 470.57.02-1, while it conflicts with some of the dependencies on my system, trying to get 470.63.01-1.fc34.
Is any work around this?
Is it possible to provide a more recent version here? https://developer.nvidia.com/cuda-downloads?target_os=Linux&target_arch=x86_64&Distribution=Fedora&target_version=34&target_type=rpm_local
Any pointers will be appreciated.
Juan
[Update] I manually installed the driver 470.63.01 and at least now I can use the GPU and run CUDA programs.
Hi, could you describe where you found the newer version of the driver ?
I’ve tried to modify the following url with another version name but without success.
https://developer.download.nvidia.com/compute/cuda/11.4.2/local_installers/cuda-repo-fedora34-11-4-local-11.4.2_470.57.02-1.x86_64.rpm
How did you find the RPM for 470.63.01 ?
Did you need to run other commands ?
I found it here: Linux x64 (AMD64/EM64T) Display Driver | 470.63.01 | Linux 64-bit | NVIDIA
I did the installation as follows:
sudo systemctl set-default multi-user.target
reboot
Then install the driver:
sudo ./NVIDIA-Linux-x86_64-470.63.01.run
And then I enabled the graphical interface again:
sudo systemctl set-default graphical.target
reboot
This worked for me.
