If using the RHEL 8 repo (Index of /compute/cuda/repos/rhel8/x86_64) and having no Nvidia/Cuda software installed and we try to just do “yum install cuda” it is not resolving dependencies. If we try to install the slightly older version cuda-12.5.1-1.x86_64 that runs fine. The error we get when installing cuda-12.6.0-1.x86_64 is
Error:
Problem: package nvidia-open-3:560.28.03-1.noarch from cuda-rhel8-x86_64 requires nvidia-kmod >= 3:560.28.03, but none of the providers can be installed
package nvidia-open-3:560.28.03-1.noarch from cuda-rhel8-x86_64 conflicts with kmod-nvidia-latest-dkms provided by kmod-nvidia-latest-dkms-3:560.28.03-1.el8.x86_64 from cuda-rhel8-x86_64
package cuda-12.6.0-1.x86_64 from cuda-rhel8-x86_64 requires nvidia-open >= 560.28.03, but none of the providers can be installed
cannot install the best candidate for the job
package kmod-nvidia-open-dkms-3:560.28.03-1.el8.x86_64 from cuda-rhel8-x86_64 is filtered out by modular filtering
Anyone else experiencing this? We are seeing this on multiple systems at multiple sites on servers with V100’s, A100’s, and H100’s.
Same here, I have a similar Rocky 8 setup with cuda already installed. Trying to update we get:
Error:
Problem 1: package nvidia-open-3:560.28.03-1.noarch from cuda-rhel8-x86_64 conflicts with kmod-nvidia-latest-dkms provided by kmod-nvidia-latest-dkms-3:560.28.03-1.el8.x86_64 from @System
- cannot install the best update candidate for package kmod-nvidia-latest-dkms-3:560.28.03-1.el8.x86_64
- cannot install the best update candidate for package cuda-drivers-555.42.06-1.x86_64
Problem 2: package nvidia-open-3:560.28.03-1.noarch from cuda-rhel8-x86_64 requires nvidia-kmod >= 3:560.28.03, but none of the providers can be installed
- package nvidia-open-3:560.28.03-1.noarch from cuda-rhel8-x86_64 conflicts with kmod-nvidia-latest-dkms provided by kmod-nvidia-latest-dkms-3:560.28.03-1.el8.x86_64 from @System
- package nvidia-open-3:560.28.03-1.noarch from cuda-rhel8-x86_64 conflicts with kmod-nvidia-latest-dkms provided by kmod-nvidia-latest-dkms-3:560.28.03-1.el8.x86_64 from cuda-rhel8-x86_64
- package cuda-12.6.0-1.x86_64 from cuda-rhel8-x86_64 requires nvidia-open >= 560.28.03, but none of the providers can be installed
- cannot install the best update candidate for package cuda-12.5.1-1.x86_64
- package kmod-nvidia-open-dkms-3:560.28.03-1.el8.x86_64 from cuda-rhel8-x86_64 is filtered out by modular filtering
Yes, I hit this too, with Fedora 39 doing a dnf --refresh upgrade with the latest 12.5 update and its accompanying driver. (The normal way to pick up system and software updates for anyone not familiar). The last ok dnf upgrade upgraded cuda 12.5 correctly. Because I didn’t read the notes properly I manually installed the 560.28.03 open driver which wouldn’t have helped as I have a pascal GPU. Having got out of that I did a dnf install of the closed source driver and the driver was ok, at least. On doing, dnf upgrade again it complained that it had a problem doing cuda and the driver as observed by others. However I told it to skip these 2 and as far as I could tell all the cuda components got updated. I can compile, run nsys (not the current version of compute as its pascal) nvvp etc.
So for my use case it seems ok but… Also it dnf needs telling to skip every time so it needs care. I don’t have my
notes handy for the driver install but I thought it was worth a reply anyway. Hope its of use.
Sorry I probably wasn’t very clear. I was using 12.5 update 1 successfully, which had upgraded using dnf correctly (with no intervention) from 12.5 release. The errors appeared when trying to accept the upgrade to 12.6. Apologies.
$ sudo dnf update --refresh
cuda-fedora39-x86_64 116 kB/s | 3.5 kB 00:00
Fedora 39 - x86_64 71 kB/s | 29 kB 00:00
Fedora 39 openh264 (From Cisco) - x86_64 3.8 kB/s | 989 B 00:00
Fedora 39 - x86_64 - Updates 88 kB/s | 28 kB 00:00
Dependencies resolved.
Problem 1: package nvidia-open-3:560.28.03-1.noarch from cuda-fedora39-x86_64 conflicts with kmod-nvidia-latest-dkms provided by kmod-nvidia-latest-dkms-3:560.28.03-1.fc39.x86_64 from @System
- cannot install the best update candidate for package kmod-nvidia-latest-dkms-3:560.28.03-1.fc39.x86_64
- cannot install the best update candidate for package cuda-drivers-3:560.28.03-1.x86_64
Problem 2: package nvidia-open-3:560.28.03-1.noarch from cuda-fedora39-x86_64 requires nvidia-kmod >= 3:560.28.03, but none of the providers can be installed
- package nvidia-open-3:560.28.03-1.noarch from cuda-fedora39-x86_64 conflicts with kmod-nvidia-latest-dkms provided by kmod-nvidia-latest-dkms-3:560.28.03-1.fc39.x86_64 from @System
- package nvidia-open-3:560.28.03-1.noarch from cuda-fedora39-x86_64 conflicts with kmod-nvidia-latest-dkms provided by kmod-nvidia-latest-dkms-3:560.28.03-1.fc39.x86_64 from cuda-fedora39-x86_64
- package cuda-12.6.0-1.x86_64 from cuda-fedora39-x86_64 requires nvidia-open >= 560.28.03, but none of the providers can be installed
- package kmod-nvidia-open-dkms-3:560.28.03-1.fc39.x86_64 from cuda-fedora39-x86_64 is filtered out by modular filtering
Package Architecture Version Repository Size
Skipping packages with conflicts:
(add '--best --allowerasing' to command line to force their upgrade):
nvidia-open noarch 3:560.28.03-1 cuda-fedora39-x86_64 7.9 k
Skipping packages with broken dependencies:
cuda x86_64 12.6.0-1 cuda-fedora39-x86_64 7.3 k
Transaction Summary
Skip 2 Packages
Attempting and update on Rocky Linux 8:
Rocky Linux 8 - AppStream 7.3 kB/s | 4.8 kB 00:00
Rocky Linux 8 - BaseOS 7.1 kB/s | 4.3 kB 00:00
Rocky Linux 8 - Extras 4.1 kB/s | 3.1 kB 00:00
Rocky Linux 8 - PowerTools 7.7 kB/s | 4.8 kB 00:00
cuda-rhel8-x86_64 13 kB/s | 3.5 kB 00:00
Docker CE Stable - x86_64 11 kB/s | 3.5 kB 00:00
Extra Packages for Enterprise Linux 8 - x86_64 45 kB/s | 33 kB 00:00
NVIDIA HPC SDK 11 kB/s | 3.0 kB 00:00
libnvidia-container 1.4 kB/s | 833 B 00:00
RPM Fusion for EL 8 - Free - Updates 6.8 kB/s | 3.7 kB 00:00
RPM Fusion for EL 8 - Nonfree - Updates 5.4 kB/s | 3.7 kB 00:00
runner_gitlab-runner 1.2 kB/s | 1.0 kB 00:00
runner_gitlab-runner-source 1.0 kB/s | 951 B 00:00
packages.microsoft.com 672 B/s | 481 B 00:00
Error:
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
It appears that some dependencies and packages have been changed as of this morning. If you run yum/dnf install cuda on Alma 8 it installs cuda 12.6 successfully. You have to make sure you have removed the kmod-nvidia-latest-dkms package as it appears that nvidia has replaced it with the kmod-nvidia-open-dkms package.
Also worth noting, the open drivers don’t support cards Volta or older. We currently support several nodes that have V100s in them. Looking for a work around or alternative to my suggestion above that uses the proprietary drivers or requesting support for Voltas in the open source driver.
Update: it seems that installing cuda-toolkit and nvidia-driver-cuda (where it installs the proprietary drivers instead of the open ones) works for our application.
And that left me with a working cuda 12.6 as per my post of Aug 15, but with these complaintsevery time with dnf upgrade::
Package Arch Version Repository Size
Upgrading:
Box2D x86_64 2.4.2-1.fc39 updates 108 k
(add ‘–best --allowerasing’ to command line to force their upgrade):
Box2D
When driver upgraded to 560.35.03 the complaints went down to:
Problem: package cuda-12.6.0-1.x86_64 from cuda-fedora39-x86_64 requires nvidia-open >= 560.28.03, but none of the providers can be installed
package nvidia-open-3:560.28.03-1.noarch from cuda-fedora39-x86_64 is filtered out by modular filtering
package nvidia-open-3:560.35.03-1.noarch from cuda-fedora39-x86_64 is filtered out by modular filtering
However I was not entirely comfortable with this so today I did:
dnf remove cuda #which removed everything but the drivers.
then:
dnf install cuda-toolkit
All complaints gone on dnf upgrade. cuda 12.6 works as before.
I will sort out drivers for gpu myself in future.
Tried unpinning from cuda 12.5 and installing the latest cuda package, given the comments above, but still hit
openstack.openhpc-cuda: Depsolve Error occurred:
openstack.openhpc-cuda: Problem: package cuda-12.6.1-1.x86_64 from cuda-rhel9-x86_64 requires nvidia-open >= 560.35.03, but none of the providers can be installed
openstack.openhpc-cuda: - cannot install the best candidate for the job
openstack.openhpc-cuda: - package nvidia-open-3:560.28.03-1.noarch from cuda-rhel9-x86_64 is filtered out by modular filtering
openstack.openhpc-cuda: - package nvidia-open-3:560.35.03-1.noarch from cuda-rhel9-x86_64 is filtered out by modular filtering
