Hi I am facing problem after compling with ffmpeg, Tesla m60
Driver does not support the required nvenc API version. Required: 8.0 Found: 7.1
[h264_nvenc @ 0x2ef3be0] The minimum required Nvidia driver for nvenc is 378.13 or newer
[h264_nvenc @ 0x2ef3be0] cuCtxPushCurrent failed
Error initializing output stream 0:0 – Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
