I downloaded the latest cuda offline installer cuda_12.1.0_530.30.02_linux.run
. Attempting to install the driver errors out with the error message
Failed to verify gcc version. See log at /tmp/cuda-installer.log for details.
Content of /tmp/cuda-installer.log
are
[INFO]: Setting driver=true
[INFO]: Setting silent=true
[INFO]: Driver not installed.
[INFO]: Checking compiler version...
[INFO]: gcc location: /usr/bin/gcc
[INFO]: gcc version: gcc version 13.0.1 20230314 (experimental) [revision 42630fadbe248717859d61c0244c821c32b4e52c] (SUSE Linux)
[ERROR]: unsupported compiler version: 13.0.1. Use --override to override this check.
I have gcc-11, gcc-12, and gcc-13 versions installed side-by-side on my system. Based on the docs, both gcc-11 and gcc-12 should be compatible with the driver. gcc
points to gcc-13 on my system. I’ve tried setting the typical environment variables that are used by build systems to try to get the installer to use gcc-12 and without exception it always uses the default /usr/bin/gcc
which points to gcc-13
. I’ve tried setting local aliases and it still picks /usr/bin/gcc
. It seems like it explicitly looks for a /usr/bin/gcc
regardless of any other types of inputs. I do not want to overwrite a symlink. Is there a way to get the installer to use the right version of gcc? If not, where can I file a bug report on this?
