I am trying to get CUDA on my laptop. First step is to get the new driver with the installer NVIDIADisplayWin2KXP(97_73)eng.exe
I uninstalled the current driver and then when I run the setup program I get an error that says:
“The NVIDIA Setup program could not locate any drivers that are compatible with your current hardware. Setup will now exit.”
It is a Dell Latitude d620, winXP, with Quadro NVS 110M graphics card, driver version 8.4.6.9
Thanks for help,
Matei
The Quadro NVS 110M is not able to run CUDA ( you need a G80 GPU ).
You can still run CUDA in emulation mode and for that, you don’t need to install the driver.
