Originally I asked for help in NoMachine forums, but they pointed out that it should be on the driver side. https://forums.nomachine.com/topic/nvidia-gpu-only-is-slower-than-hybrid-with-intel-graphics
I have two options for graphics on PC: integrated Intel and RTX 2070. I have no problems with Intel. When I’m using Nvidia working directly with PC (not remoting) everything is fine. But connecting to a physical desktop using NoMachine I have frame lags, typing lags etc. I tried different driver versions, linux distributions, desktop environment, linux kernels all the same. So I’m here after NoMachine developer replied:
unfortunately there is nothing more that can be done in the NoMachine software. After excluding hardware encoding, GPU is not used by NoMachine directly. I have seen other similar cases where the local X server is slow to pull pixels data back from video memory. This is an issue on the video card/drivers side. You may try to use a different version of the drivers, but I can’t say if that will solve the problem.
My setup:
- Intel i5-3470
- Nvidia RTX 2070 (proprietary drivers 440.82)
- Not headless
- Manjaro linux, tried also Fedora 32
- 4.19 kernel, tried also 5.4
- Gnome 3.36 (X session), also tried XFCE
