Apparently the driver is installed, however no display output on gpu. What I’ve tried so far:
- Reinstalled drivers (2x - using
sudo apt install nvidia-drivers-550andubuntu-drivers autoinstall) - Changed
options nvidia-drm modesetfrom0to1in/etc/modprobe.d/*and/lib/modprobe.d/*, applied withsudo update-initramfs -u sudo prime-select on-demand→ reboot →sudo prime-select nvidia→ reboot- Changed
GRUB_CMDLINE_LINUX_DEFAULT=fromquiet splashtonomodesetand applied withsudo update-grub - Setted two env variables:
__GLX_VENDOR_LIBRARY_NAME=nvidiaand__NV_PRIME_RENDER_OFFLOAD=1in /etc/environment - Added
Option "PrimaryGPU" "true"in/usr/share/X11/xorg.conf.d/10-nvidia.conf - Tried changing kernel to use
6.5.0-1020-oemkernel (rollback to 6.5.0-28-generic)
During the tries, I had to enable autologin due to login loop and had blinking screen after reboot - rollback the second and fourth bullet points. Autologin is still enabled. I do not want to change display manager, currently using gdm3.
Any suggestions to solve this?
nvidia-bug-report.log.gz (468.5 KB)
➤ sudo gpu-manager
last_boot_file: /var/lib/ubuntu-drivers-common/last_gfx_boot
new_boot_file: /var/lib/ubuntu-drivers-common/last_gfx_boot
can't access /opt/amdgpu-pro/bin/amdgpu-pro-px
Looking for nvidia modules in /lib/modules/6.5.0-28-generic/kernel
Looking for nvidia modules in /lib/modules/6.5.0-28-generic/kernel/nvidia-550srv
Found nvidia.ko module in /lib/modules/6.5.0-28-generic/kernel/nvidia-550/nvidia.ko
Looking for amdgpu modules in /lib/modules/6.5.0-28-generic/kernel
Looking for amdgpu modules in /lib/modules/6.5.0-28-generic/updates/dkms
Is nvidia loaded? yes
Was nvidia unloaded? no
Is nvidia blacklisted? no
Is intel loaded? yes
Is radeon loaded? no
Is radeon blacklisted? no
Is amdgpu loaded? no
Is amdgpu blacklisted? no
Is amdgpu versioned? no
Is amdgpu pro stack? no
Is nouveau loaded? no
Is nouveau blacklisted? yes
Is nvidia kernel module available? yes
Is amdgpu kernel module available? no
Vendor/Device Id: 8086:152
BusID "PCI:0@0:2:0"
Is boot vga? yes
Vendor/Device Id: 10de:13c2
BusID "PCI:1@0:0:0"
Is boot vga? no
Chassis type: "3"
Laptop not detected
Is nvidia runtime pm supported for "0x13c2"? no
Checking power status in /proc/driver/nvidia/gpus/0000:01:00.0/power
Runtime D3 status: Disabled by default
Is nvidia runtime pm enabled for "0x13c2"? no
Skipping "/dev/dri/card1", driven by "nvidia-drm"
Skipping "/dev/dri/card0", driven by "i915"
Found "/dev/dri/card0", driven by "i915"
output 0:
card0-VGA-1
Number of connected outputs for /dev/dri/card0: 1
Does it require offloading? yes
last cards number = 2
Has amd? no
Has intel? yes
Has nvidia? yes
How many cards? 2
Has the system changed? No
Takes 0ms to wait for nvidia udev rules completed.
Intel IGP detected
NVIDIA hybrid system
Creating /usr/share/X11/xorg.conf.d/11-nvidia-prime.conf
Setting power control to "on" in /sys/bus/pci/devices/0000:01:00.0/power/control
➤ sudo lshw -C display
*-display
description: VGA compatible controller
product: GM204 [GeForce GTX 970]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:31 memory:f6000000-f6ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:e000(size=128) memory:f7000000-f707ffff
*-display
product: Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
logical name: /dev/fb0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=i915 latency=0 resolution=1920,1080
resources: irq:29 memory:f7400000-f77fffff memory:d0000000-dfffffff ioport:f000(size=64) memory:c0000-dffff
➤ nvidia-smi
Thu Apr 25 18:26:18 2024
| NVIDIA-SMI 550.67 Driver Version: 550.67 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce GTX 970 Off | 00000000:01:00.0 Off | N/A |
| 22% 40C P8 11W / 151W | 190MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2187 G /usr/bin/gnome-shell 2MiB |
| 0 N/A N/A 6008 G ...erProcess --variations-seed-version 89MiB |
| 0 N/A N/A 7428 G ...,262144 --variations-seed-version=1 91MiB |
➤ sudo prime-select query
nvidia
➤ glxinfo | grep vendor
server glx vendor string: SGI
client glx vendor string: NVIDIA Corporation
OpenGL vendor string: NVIDIA Corporation
➤ mokutil --sb-state
This system doesn't support Secure Boot
➤ apt list --installed | grep nvidia
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libnvidia-cfg1-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev amd64 [installed,automatic]
libnvidia-common-535/jammy,jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev all [installed]
libnvidia-common-550/jammy,jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev all [installed,automatic]
libnvidia-compute-535/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev i386 [installed]
libnvidia-compute-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev amd64 [installed,automatic]
libnvidia-compute-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev i386 [installed,automatic]
libnvidia-decode-535/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev i386 [installed]
libnvidia-decode-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev amd64 [installed,automatic]
libnvidia-decode-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev i386 [installed,automatic]
libnvidia-egl-wayland1/jammy,now 1:1.1.9-1.1 amd64 [installed,automatic]
libnvidia-encode-535/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev i386 [installed]
libnvidia-encode-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev amd64 [installed,automatic]
libnvidia-encode-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev i386 [installed,automatic]
libnvidia-extra-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev amd64 [installed,automatic]
libnvidia-fbc1-535/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev i386 [installed]
libnvidia-fbc1-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev amd64 [installed,automatic]
libnvidia-fbc1-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev i386 [installed,automatic]
libnvidia-gl-535/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev i386 [installed]
libnvidia-gl-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev amd64 [installed,automatic]
libnvidia-gl-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev i386 [installed,automatic]
linux-modules-nvidia-550-6.5.0-1020-oem/jammy-updates,jammy-security,now 6.5.0-1020.21+2 amd64 [installed]
linux-modules-nvidia-550-6.5.0-28-generic/jammy-updates,jammy-security,now 6.5.0-28.29~22.04.1+2 amd64 [installed,automatic]
linux-modules-nvidia-550-generic-hwe-22.04/jammy-updates,jammy-security,now 6.5.0-28.29~22.04.1+2 amd64 [installed]
linux-objects-nvidia-550-6.5.0-1020-oem/jammy-updates,jammy-security,now 6.5.0-1020.21+2 amd64 [installed,automatic]
linux-objects-nvidia-550-6.5.0-28-generic/jammy-updates,jammy-security,now 6.5.0-28.29~22.04.1+2 amd64 [installed,automatic]
linux-signatures-nvidia-6.5.0-1020-oem/jammy-updates,jammy-security,now 6.5.0-1020.21+2 amd64 [installed,automatic]
linux-signatures-nvidia-6.5.0-28-generic/jammy-updates,jammy-security,now 6.5.0-28.29~22.04.1+2 amd64 [installed,automatic]
nvidia-compute-utils-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev amd64 [installed,automatic]
nvidia-dkms-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev amd64 [installed]
nvidia-driver-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev amd64 [installed]
nvidia-firmware-550-550.67/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev amd64 [installed,automatic]
nvidia-kernel-common-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev amd64 [installed,automatic]
nvidia-kernel-source-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev amd64 [installed,automatic]
nvidia-prime/jammy,jammy,now 0.8.17.1 all [installed]
nvidia-settings/jammy,jammy,now 510.47.03-0ubuntu1 amd64 [installed,automatic]
nvidia-utils-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev amd64 [installed,automatic]
xserver-xorg-video-nvidia-550/jammy,now 550.67-1pop0~1710948064~22.04~b0f6b1b~dev amd64 [installed,automatic]
