Description
I try to run Driveworks 3.5 sample application “sample_dnn_tensor” on my custom board with Xavier. it says " INVALID_CONFIG: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors."
I had a look similar forums and they all say I need to rebuild engine file with “tensorRT_optimization” tool. By the way, nobody says where are uff or caffe or onnx files to run “tensorRT_optimization”. I guess there should be corresponding model file for “sample_dnn_tensor” and other dnn sample application for driveworks 3.5.
Does anybody know?
Environment
TensorRT Version:
GPU Type:
Nvidia Driver Version:
CUDA Version:
CUDNN Version:
Operating System + Version:
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
