After upgrading to L4T 35.1, drmModeFreeResources() supplied by libdrm_nvdc.so does not return anymore, causing the respective thread within our application to freeze.
A simple code snippet to reproduce this behaviour:
#include <stdio.h>
#include <xf86drm.h>
#include <xf86drmMode.h>
int main(void)
int fd = drmOpen("drm-nvdc", NULL);
printf("fd: %i\n", fd);
drmModeResPtr res = drmModeGetResources(fd);
printf("res: 0x%lx\n", (long)res);
printf("fbs: 0x%lx\n", (long)res->fbs);
printf("crtcs: 0x%lx\n", (long)res->crtcs);
printf("connectors: 0x%lx\n", (long)res->connectors);
printf("encoders: 0x%lx\n", (long)res->encoders);
/* Does not return :( */
drmModeFreeResources(res);
Compiled with clang -I/usr/include/libdrm -ldrm main.c
If you run the executable it will hang after the last printf()
lldb yields:
$ lldb a.out
(lldb) target create "a.out"
Current executable set to 'a.out' (aarch64).
(lldb) run
Process 1528 launched: 'a.out' (aarch64)
fd: 4
res: 0xaaaaaaabd320
fbs: 0x0
crtcs: 0xaaaaaaabd380
connectors: 0xaaaaaaabd3a0
encoders: 0xaaaaaaabd3c0
Process 1528 stopped
* thread #1, name = 'a.out', stop reason = signal SIGSTOP
frame #0: 0x0000fffff7ddf268 libpthread.so.0`__lll_lock_wait(futex=0x0000fffff7fc7420, private=0) at lowlevellock.c:52:7
(lldb) thread list
* thread #1: tid = 1528, 0x0000fffff7ddf268 libpthread.so.0`__lll_lock_wait(futex=0x0000fffff7fc7420, private=0) at lowlevellock.c:52:7, name = 'a.out', stop reason = signal SIGSTOP
thread #2: tid = 1556, 0x0000fffff7ddb414 libpthread.so.0`__pthread_cond_wait at futex-internal.h:186:13, name = 'drm_vbl'
thread #3: tid = 1557, 0x0000fffff7ddb414 libpthread.so.0`__pthread_cond_wait at futex-internal.h:186:13, name = 'drm_pflip'
thread #4: tid = 1558, 0x0000fffff7ddb414 libpthread.so.0`__pthread_cond_wait at futex-internal.h:186:13, name = 'drm_vbl'
thread #5: tid = 1559, 0x0000fffff7ddb414 libpthread.so.0`__pthread_cond_wait at futex-internal.h:186:13, name = 'drm_pflip'
thread #6: tid = 1560, 0x0000fffff7ddb414 libpthread.so.0`__pthread_cond_wait at futex-internal.h:186:13, name = 'drm_vbl'
thread #7: tid = 1561, 0x0000fffff7ddb414 libpthread.so.0`__pthread_cond_wait at futex-internal.h:186:13, name = 'drm_pflip'
(lldb) bt
* frame #0: 0x0000fffff7ddf268 libpthread.so.0`__lll_lock_wait(futex=0x0000fffff7fc7420, private=0) at lowlevellock.c:52:7
frame #1: 0x0000fffff7dd6d20 libpthread.so.0`__GI___pthread_mutex_lock(mutex=0x0000fffff7fc7420) at pthread_mutex_lock.c:80:7
frame #2: 0x0000fffff7fa25a0 libdrm.so.2`drmFree + 32
frame #3: 0x0000fffff7bae6dc libdrm.so.2.4.0`drmModeFreeResources + 28
frame #4: 0x0000fffff7fa0c58 libdrm.so.2`drmModeFreeResources + 40
frame #5: 0x0000aaaaaaaa0958 a.out`main + 164
frame #6: 0x0000fffff7e3de18 libc.so.6`__libc_start_main(main=(a.out`main), argc=1, argv=0x0000fffffffff4c8, init=<unavailable>, fini=<unavailable>, rtld_fini=<unavailable>, stack_end=<unavailable>) at libc-start.c:308:16
frame #7: 0x0000aaaaaaaa07d4 a.out`_start + 52
The Mesa version of drmModeFreeResources() in xf86drmMode.c looks quite trivial with no obvious point where this could hang. I was not able to find the source for the nvidia version, i.e. libdrm_nvdc.so.
Following questions:
- Just to make sure, is the source of libdrm_nvdc.so available somewhere?
- What is the purpose of the drm_vbl and drm_pflip threads?
- What must be changed to avoid the freeze?
