hello,
how to accesses the dtb file to modification to resolve can bus error.
hello jadhav9354,
please access L4T sources package for the source codes.
you may extract kernel source package and checking hardware
folder for the dtsi files.
thanks
i extracted L4T sources and i found device tree folder in this /dvs/git/dirty/git-master_linux/out/out_src/dtc-1.4.0.tar.bz2 location .
but i want update clock frequency for 40 Mhz in order to to communicate with can can you give any suggestion regarding the same.
thanks regards
akshay
hello jadhav9354,
may I know what’s your actual use-case? which CAN hardware you’re used?
hi,
i have been trying to configure CAN-BUS on the JETSON NX development board with a CAN transceiver SN65HVD230. in that i have to change above mentioned frequency
