I use R35.3.1, I connect two orin by rgmii fixed-link, after configurating pinmux according to jetson orin developer guide, and add ethernet@2310000 in tegra234-ethernet-3737-0000.dtsi as below:
ethernet@2310000 {
status = "okay";
nvidia,mac-addr-idx = <1>;
nvidia,max-platform-mtu = <9000>;
nvidia,pause_frames = <1>;
phy-mode = "rgmii";
nvidia,if-name = "eth_eqos";
fixed-link {
speed = <100>;
full-duplex;
now, two orin can link up through ethtool eth_eqos, but ping don’t work, I check the td0~3’s signal waveshape, always low, it indicates no tx data send out
for checking hardware, I use busybox to config td0~3 pin as gpio, those pins’ voltage level can be changed, hardware is normal. the tx_clk and rx_clk’s waveshare is normal, the clock is 25MHz
