I’m not sure how to configure the xorg.conf file (hopefully using nvidia-xconfig or similar command). It sees the display based on the output from nvidia-xconfig below, but from the Xorg.0.log file, it’s only checking GPU 0 for displays, doesn’t find any, and won’t start X. I’m remote from the system so I can’t just swap the display to the other card. Any suggestions or guidance is appreciated!
nvidia-xconfig --query-gpu-info
Number of GPUs: 2
GPU #0:
Name : Quadro RTX 6000
UUID : GPU-860f605e-0cbf-60cc-f6e1-05b3d80a0396
PCI BusID : PCI:21:0:0
Number of Display Devices: 0
GPU #1:
UUID : GPU-8a10b12a-8682-0972-9731-72421b45757b
PCI BusID : PCI:45:0:0
Number of Display Devices: 1
Display Device 0 (TV-0):
EDID Name : DELL P2213
Minimum HorizSync : 30.000 kHz
Maximum HorizSync : 83.000 kHz
Minimum VertRefresh : 56 Hz
Maximum VertRefresh : 75 Hz
Maximum PixelClock : 160.000 MHz
Maximum Width : 1680 pixels
Maximum Height : 1050 pixels
Preferred Width : 1680 pixels
Preferred Height : 1050 pixels
Preferred VertRefresh : 60 Hz
Physical Width : 470 mm
Physical Height : 300 mm
