Hello everybody,
I have a Xiaomi Gaming Laptop 2019 which contain one intel graphic card and one RTX2060 form Nvidia:
[vahid@yoda ~]$ sudo lshw -c display
*-display
description: VGA compatible controller
product: TU106M [GeForce RTX 2060 Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:162 memory:b3000000-b3ffffff memory:a0000000-afffffff memory:b0000000-b1ffffff ioport:4000(size=128) memory:b2000000-b207ffff
*-display
product: UHD Graphics 630 (Mobile)
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:132 memory:b5000000-b5ffffff memory:90000000-9fffffff ioport:5000(size=64) memory:c0000-dffff
I installed the driver from Nvidia site and it works:
[vahid@yoda ~]$ nvidia-smi
Mon Feb 17 17:31:09 2020
| NVIDIA-SMI 440.44 Driver Version: 440.44 CUDA Version: 10.2 |
| 0 GeForce RTX 2060 Off | 00000000:01:00.0 On | N/A |
| N/A 50C P8 4W / N/A | 638MiB / 5934MiB | 1% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 2287 G /usr/libexec/Xorg 18MiB |
| 0 2488 G /usr/bin/gnome-shell 68MiB |
| 0 2958 G /usr/libexec/Xorg 189MiB |
| 0 5007 G ...uest-channel-token=11966873828770633102 43MiB |
| 0 7000 G ...quest-channel-token=3442500682710008371 139MiB |
| 0 13799 G /usr/bin/gnome-shell 173MiB |
Jus the problem is I want to be able to use Nvidia when I need !! and be able to normally use HDMI out put and laptop display both with intel.
now if I enable Nvidia it just the HDMI out put and the main laptop display goes black and if I use intel then the HDMI out put shows nothing.
below is the x.conf (if I want the intel I have to delit this file!)
long story short: I want both display with intel or both with nvidia or at least woth working at the same time!!
appriciate any help.
Section "ServerLayout"
Identifier "layout"
Screen 0 "nvidia"
Screen 1 "intel" RightOf "intel"
EndSection
Section "Device"
Identifier "intel"
Driver "intel"
BusID "PCI:0:2:0"
Option "AccelMethod" "SNA"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1:0:0"
Option "ConstrainCursor" "off"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
Option "AllowEmptyInitialConfiguration" "yes"
Option "IgnoreDisplayDevices" "CRT"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
