I started with 2 1080 ti GPUs and my machine recognized both.
I recently added a 1060 for my monitors so that I can use the 2 1080 ti for ML.
Now, nvidia-smi reports all 3 GPUs but deviceQuery only reports 2.
It is missing one of the 1080 ti. Other programs also miss the 2nd 1080 ti.
I’m on Ubuntu 16.05 lts.
Here is the output:
bash:/usr/local/cuda/extras/demo_suite$<b>./deviceQuery</b>
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 2 CUDA Capable device(s)
Device 0: "GeForce GTX 1060 6GB"
CUDA Driver Version / Runtime Version 9.0 / 9.0
CUDA Capability Major/Minor version number: 6.1
Total amount of global memory: 6065 MBytes (6359285760 bytes)
(10) Multiprocessors, (128) CUDA Cores/MP: 1280 CUDA Cores
GPU Max Clock rate: 1759 MHz (1.76 GHz)
Memory Clock rate: 4004 Mhz
Memory Bus Width: 192-bit
L2 Cache Size: 1572864 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 2 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
Device 1: "GeForce GTX 1080 Ti"
Total amount of global memory: 11172 MBytes (11715084288 bytes)
(28) Multiprocessors, (128) CUDA Cores/MP: 3584 CUDA Cores
GPU Max Clock rate: 1582 MHz (1.58 GHz)
Memory Clock rate: 5505 Mhz
Memory Bus Width: 352-bit
L2 Cache Size: 2883584 bytes
Warp size: 32
Run time limit on kernels: No
Device PCI Domain ID / Bus ID / location ID: 0 / 129 / 0
Compute Mode:
> Peer access from GeForce GTX 1060 6GB (GPU0) -> GeForce GTX 1080 Ti (GPU1) : No
> Peer access from GeForce GTX 1080 Ti (GPU1) -> GeForce GTX 1060 6GB (GPU0) : No
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 9.0, CUDA Runtime Version = 9.0, NumDevs = 2, Device0 = GeForce GTX 1060 6GB, Device1 = GeForce GTX 1080 Ti
Result = PASS
bash:/usr/local/cuda/extras/demo_suite$ <b>nvidia-smi</b>
Fri Jun 22 23:57:03 2018
| NVIDIA-SMI 384.130 Driver Version: 384.130 |
| 0 GeForce GTX 106... Off | 00000000:02:00.0 On | N/A |
| 49% 54C P0 25W / 120W | 3230MiB / 6064MiB | 0% Default |
| 1 GeForce GTX 108... Off | 00000000:03:00.0 Off | N/A |
| 28% 37C P8 9W / 250W | 1MiB / 11172MiB | 0% Default |
| 2 GeForce GTX 108... Off | 00000000:81:00.0 Off | N/A |
| 28% 37C P8 16W / 250W | 2MiB / 11172MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1298 G /usr/lib/xorg/Xorg 2327MiB |
| 0 2889 G compiz 644MiB |
| 0 26451 G ...-token=93429DDE62D483B80BDFFE30C4640FA2 256MiB |
bash::/usr/local/cuda/extras/demo_suite$ nvidia-smi -L
GPU 0: GeForce GTX 1060 6GB (UUID: GPU-636542da-27ae-8916-0a0e-2dc3959a3153)
GPU 1: GeForce GTX 1080 Ti (UUID: GPU-950c1e6c-6fd6-aa2e-bc1f-eece2062a980)
GPU 2: GeForce GTX 1080 Ti (UUID: GPU-de2a9056-c77c-cc20-4784-2a91ad6eac46)
