Duplicate message in 1 batch source if nvmsgbroker is behind nvmultistreamtiler in pipeline
Sending data sometimes gets duplicated when nvmsgbroker is behind nvmultistreamtiler in pipeline with streammux batch size larger than 1.
Temporary solution: Remove nvmultistreamtiler and set nvstreammux with batch_size=1 even when processing 4 streams, but this option leads to a decrease in FPS.
Jetson Nano, Jetson Xavier NX, x86
• DeepStream Version
5.0
4.4
• TensorRT Version
7.1.3-1+cuda10.2
Bugs
This error pipeline
gst-launch-1.0 -e nvstreammux name=m batched-push-timeout=40000 batch-size=4 width=1920 height=1080 ! nvinfer config-file-path=/data/configs/pgie_arm.txt ! yoloparser ! nvdsanalytics config-file=/data/configs/analytics.txt ! nvmultistreamtiler rows=2 columns=2 width=1280 height=720 ! queue ! nvmsgconv config=/data/configs/msgconv.txt payload-type=257 ! nvmsgbroker proto-lib=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_kafka_proto.so conn-str=$BOOTSTRAP_SERVER topic=$TOPIC config=/data/configs/kafka.txt sync=false
I will check
can you use deepstream-test4 or deepstream-test5 to reproduce this issue? could you share some duplicated data?
