Hi all,
I’m currently running a system with a GRID K1 card running driver version 347.25. I am able to run all the DX samples provided by the GRID SDK, however I’m having trouble integrating it into my own project. The GRID SDK version is 2.3.7.
I can successfully create the NvIFR interface, passing in my D3D11Device*.
However, I cannot call NvIFRSetUpH264HWEncoder. Using the same params as the samples, NVIFR_ERROR_DX_DRIVER_FAILURE is always returned. I’ve tried changing sizes, back buffer formats, but I get the same error.
Under what conditions is NVIFR_ERROR_DX_DRIVER_FAILURE returned? Where should I start looking? Is there anyway to get some debugging info?
Thanks,
Matt
[xposting from devtalk, maybe I’ll get some traction here :)]
Could you provide a DX SDK sample with your changes to the code to exhibit the problem?
Shaah
March 8, 2016, 9:38am
3
I have the same problem with DX10 and posted my question here https://gridforums.nvidia.com/default/topic/737/nvidia-grid-apis/nvifr_error_dx_driver_failure/
This is the GridLog in my case
## 0.000 | NvIFR | PID 6788 ##
NVIFR_CREATE_PARAMS::dwVersion: 0x22010100
NVIFR_CREATE_PARAMS::dwInterfaceType: 8707
NVIFR_CREATE_PARAMS::pDevice: 0x 004E2064
NVIFR_CREATE_PARAMS::pPrivateData: 0x 00000000
NVIFR_CREATE_PARAMS::dwPrivateDataSize: 0.
## 0.105 | NvIFR | PID 6788 ## : NvIFRCreate_Core ::Entry.
## 0.156 | NvIFR | PID 6788 ## : NvIFRCreate_Core :: Success (NVIFR_SUCCESS). .
NVIFR_CREATE_PARAMS::dwNvIFRVersion: 64
NVIFR_CREATE_PARAMS::pNvIFR: 0x 05162F0C
NVIFR_CREATE_PARAMS::result: NVIFR_SUCCESS.
## 8.654 | NvIFR | PID 6788 ## : NvIFRH264Dx1xImp_v2::NvIFRSetUpH264HWEncoder :: Entry.
NVIFR_SETUP_H264_PARAMS_V2::dwVersion: 0x22020180
NVIFR_SETUP_H264_PARAMS_V2::eStreamStereoFormat: NVIFR_H264_STEREO_NONE
NVIFR_SETUP_H264_PARAMS_V2::dwTargetWidth: 980
NVIFR_SETUP_H264_PARAMS_V2::dwTargetHeight: 734
NVIFR_SETUP_H264_PARAMS_V2::dwNBuffers: 1
NVIFR_SETUP_H264_PARAMS_V2::dwBSMaxSize: 2097152
NVIFR_SETUP_H264_PARAMS_V2::ppPageLockedBitStreamBuffers: 0x 5EA2A400
NVIFR_SETUP_H264_PARAMS_V2::ppEncodeCompletionEvents: 0x 5EA2A3E4
NVIFR_SETUP_H264_PARAMS_V2::dwBitStreamOffset: 0
NVIFR_SETUP_H264_PARAMS_V2::bIsCustomYUV444: 0.
## 8.655 | NvIFR | PID 6788 ##
NvIFR_H264HWEncoder_Config_V2::dwVersion: 0x22020180
NvIFR_H264HWEncoder_Config_V2::dwProfile: 100
NvIFR_H264HWEncoder_Config_V2::dwFrameRateNum: 30
NvIFR_H264HWEncoder_Config_V2::dwFrameRateDen: 1
NvIFR_H264HWEncoder_Config_V2::dwAvgBitRate: 3000000
NvIFR_H264HWEncoder_Config_V2::dwPeakBitRate: 3600000
NvIFR_H264HWEncoder_Config_V2::dwGOPLength: 75
NvIFR_H264HWEncoder_Config_V2::dwQP: 26
NvIFR_H264HWEncoder_Config_V2::maxRCQP[P frame]: 0
NvIFR_H264HWEncoder_Config_V2::maxRCQP[B frame]: 0
NvIFR_H264HWEncoder_Config_V2::maxRCQP[I frame]: 0
NvIFR_H264HWEncoder_Config_V2::bUseMaxRCQP: 0
NvIFR_H264HWEncoder_Config_V2::bRepeatSPSPPSHeader: 0
NvIFR_H264HWEn.
## 8.655 | NvIFR | PID 6788 ## : NvIFRH264Dx1xImp_v0::CleanUp :: Exit.
## 8.655 | NvIFR | PID 6788 ## : NvIFRDx10::SetCurrentRenderTarget :: Error (NVIFR_ERROR_GENERIC). .
## 8.655 | NvIFR | PID 6788 ## : NvIFRH264Dx1xImp_v2::NvIFRSetUpH264HWEncoder :: got driver error unknown return code from driver.
## 8.655 | NvIFR | PID 6788 ## : NvIFRH264Dx1xImp_v2::NvIFRSetUpH264HWEncoder :: Error (NVIFR_ERROR_DX_DRIVER_FAILURE). Failed to set current RenderTarget..
