Hi guys, I want to test dynamic global memory allocation. the code is that:
module a_test
integer,device,allocatable :: b(:)
contains
attributes(global) subroutine kernel(a,n)
integer,value :: n
integer,device :: a(n)
integer :: i
!integer,device,allocatable :: b(:)
if(threadidx%x==1) then
allocate(b(n))
endif
call syncthreads()
i=threadIdx%x
b(i)=i
a(i)=b(i)
end subroutine
end module
program prog
use a_test
use cudafor
implicit none
integer,parameter :: n=128
integer,device :: a_d(n)
integer :: a(n)
call kernel<<<1,128>>>(a_d,n)
a=a_d
write(*,*)a(10:20)
end program
I compile the code ,using PVF13.7. ‘’-Mcuda" value is “-Mcuda=cc3.05,cuda5.0,rdc” But there are some problems.
C:\Users\Administrator\AppData\Local\Temp\pgnvd3bzu6blDNefEUF.s: Assembler messages:
C:\Users\Administrator\AppData\Local\Temp\pgnvd3bzu6blDNefEUF.s:4: Warning: value 0xffed truncated to 0xed
C:\Users\Administrator\AppData\Local\Temp\pgnvd3bzu6blDNefEUF.s:4: Warning: value 0xffba truncated to 0xba
C:\Users\Administrator\AppData\Local\Temp\pgnvd3bzu6blDNefEUF.s:4: Warning: value 0xff98 truncated to 0x98
C:\Users\Administrator\AppData\Local\Temp\pgnvd3bzu6blDNefEUF.s:5: Warning: value 0xff80 truncated to 0x80
C:\Users\Administrator\AppData\Local\Temp\pgnvd3bzu6blDNefEUF.s:6: Warning: value 0xfff6 truncated to 0xf6
C:\Users\Administrator\AppData\Local\Temp\pgnvd3bzu6blDNefEUF.s:13: Warning: value 0xff80 truncated to 0x80
C:\Users\Administrator\AppData\Local\Temp\pgnvd3bzu6blDNefEUF.s:15: Warning: value 0xfff3 truncated to 0xf3
C:\Users\Administrator\AppData\Local\Temp\pgnvd3bzu6blDNefEUF.s:22: Warning: value 0xff80 truncated to 0x80
C:\Users\Administrator\AppData\Local\Temp\pgnvd3bzu6blDNefEUF.s:23: Warning: value 0xfff1 truncated to 0xf1
pgacclnk: spawnv failed: C:\Users\Administrator\AppData\Local\Temp\pgcudafat2d54bcRJcHcR3D.o
I compile the code under CentOS using PGI Workstation, that is OK. But under window OS, I can’t compile it successfully. I don’t know why. Please help me
ps: Is thera any tool to debug CUDA Fortran code?
