Hi all,
we tried to use some kernels dynamically as this would decrease our cpu usage. But we found that the kernels launched from other kernels work ~ 2.5x slower. This happens even if we dynamically launch them in separate streams.
Here’s our simple test code (slightly modified vectorAdd - first we launch 1000 kernels dynamically, than we launch 1000 kernels in the usual way):
* Copyright 1993-2013 NVIDIA Corporation. All rights reserved.
* Please refer to the NVIDIA end user license agreement (EULA) associated
* with this source code for terms and conditions that govern your use of
* this software. Any use, reproduction, disclosure, or distribution of
* this software and related documentation outside the terms of the EULA
* is strictly prohibited.
* Vector addition: C = A + B.
* This sample is a very basic sample that implements element by element
* vector addition. It is the same as the sample illustrating Chapter 2
* of the programming guide with some additions like error checking.
#include <stdio.h>
// For the CUDA runtime routines (prefixed with "cuda_")
#include <cuda_runtime.h>
* CUDA Kernel Device code
* Computes the vector addition of A and B into C. The 3 vectors have the same
* number of elements numElements.
__global__ void
vectorAdd(const float *A, const float *B, float *C, int numElements)
int i = blockDim.x * blockIdx.x + threadIdx.x;
if (i < numElements)
C[i] = A[i] + B[i];
// a kernel dynamically launching other kernels
__global__ void
vectorAddDyn(const float *A, const float *B, float *C, int numElements) {
for (int i = 0; i < 1000; i++) {
cudaStream_t stream;
cudaStreamCreateWithFlags(&stream, cudaStreamNonBlocking);
// Launch the Vector Add CUDA Kernel
int threadsPerBlock = 256;
int blocksPerGrid =(numElements + threadsPerBlock - 1) / threadsPerBlock;
// printf("CUDA kernel launch with %d blocks of %d threads\n", blocksPerGrid, threadsPerBlock);
vectorAdd<<<blocksPerGrid, threadsPerBlock, 0, stream>>>(A, B, C, numElements);
cudaStreamDestroy(stream);
* Host main routine
int
main(void)
// Error code to check return values for CUDA calls
cudaError_t err = cudaSuccess;
// Print the vector length to be used, and compute its size
int numElements = 50000000;
size_t size = numElements * sizeof(float);
printf("[Vector addition of %d elements]\n", numElements);
// Allocate the host input vector A
float *h_A = (float *)malloc(size);
// Allocate the host input vector B
float *h_B = (float *)malloc(size);
// Allocate the host output vector C
float *h_C = (float *)malloc(size);
// Verify that allocations succeeded
if (h_A == NULL || h_B == NULL || h_C == NULL)
fprintf(stderr, "Failed to allocate host vectors!\n");
exit(EXIT_FAILURE);
// Initialize the host input vectors
for (int i = 0; i < numElements; ++i)
h_A[i] = rand()/(float)RAND_MAX;
h_B[i] = rand()/(float)RAND_MAX;
// Allocate the device input vector A
float *d_A = NULL;
err = cudaMalloc((void **)&d_A, size);
if (err != cudaSuccess)
fprintf(stderr, "Failed to allocate device vector A (error code %s)!\n", cudaGetErrorString(err));
exit(EXIT_FAILURE);
// Allocate the device input vector B
float *d_B = NULL;
err = cudaMalloc((void **)&d_B, size);
fprintf(stderr, "Failed to allocate device vector B (error code %s)!\n", cudaGetErrorString(err));
exit(EXIT_FAILURE);
// Allocate the device output vector C
float *d_C = NULL;
err = cudaMalloc((void **)&d_C, size);
fprintf(stderr, "Failed to allocate device vector C (error code %s)!\n", cudaGetErrorString(err));
exit(EXIT_FAILURE);
// Copy the host input vectors A and B in host memory to the device input vectors in
// device memory
printf("Copy input data from the host memory to the CUDA device\n");
err = cudaMemcpy(d_A, h_A, size, cudaMemcpyHostToDevice);
fprintf(stderr, "Failed to copy vector A from host to device (error code %s)!\n", cudaGetErrorString(err));
exit(EXIT_FAILURE);
err = cudaMemcpy(d_B, h_B, size, cudaMemcpyHostToDevice);
fprintf(stderr, "Failed to copy vector B from host to device (error code %s)!\n", cudaGetErrorString(err));
exit(EXIT_FAILURE);
// try to launch the kernels dynamically
vectorAddDyn<<<1, 1>>>(d_A, d_B, d_C, numElements);
// run the kernels in the usual way
vectorAdd<<<blocksPerGrid, threadsPerBlock>>>(d_A, d_B, d_C, numElements);
err = cudaGetLastError();
fprintf(stderr, "Failed to launch vectorAdd kernel (error code %s)!\n", cudaGetErrorString(err));
exit(EXIT_FAILURE);
// Copy the device result vector in device memory to the host result vector
// in host memory.
printf("Copy output data from the CUDA device to the host memory\n");
err = cudaMemcpy(h_C, d_C, size, cudaMemcpyDeviceToHost);
fprintf(stderr, "Failed to copy vector C from device to host (error code %s)!\n", cudaGetErrorString(err));
exit(EXIT_FAILURE);
// Verify that the result vector is correct
if (fabs(h_A[i] + h_B[i] - h_C[i]) > 1e-5)
fprintf(stderr, "Result verification failed at element %d!\n", i);
exit(EXIT_FAILURE);
printf("Test PASSED\n");
// Free device global memory
err = cudaFree(d_A);
fprintf(stderr, "Failed to free device vector A (error code %s)!\n", cudaGetErrorString(err));
exit(EXIT_FAILURE);
err = cudaFree(d_B);
fprintf(stderr, "Failed to free device vector B (error code %s)!\n", cudaGetErrorString(err));
exit(EXIT_FAILURE);
err = cudaFree(d_C);
fprintf(stderr, "Failed to free device vector C (error code %s)!\n", cudaGetErrorString(err));
exit(EXIT_FAILURE);
// Free host memory
free(h_A);
free(h_B);
free(h_C);
// Reset the device and exit
err = cudaDeviceReset();
fprintf(stderr, "Failed to deinitialize the device! error=%s\n", cudaGetErrorString(err));
exit(EXIT_FAILURE);
printf("Done\n");
return 0;
Here’s what the profiler would show:
Is this usual behavior or are we doing something wrong?
