Hi, I’m trying to dynamically take a capture based on if someone is in the frame or not. Unfortunately it looks like I can’t use smart record as it does not support audio and hence I need to add and remove elements to my pipeline dynamically.
I actually got this to work, with a catch. my original pipeline was as such
// nvarguscamerasrc ->nvvideoconver->capsfilter->nvstreammux->nvinfer->nvvideoconvert->nvdsosd->nvvideoconvert->| tee_post_osd->queue_pre_sink->nvegltransform->nveglglessink
This worked fine when I dynamically attached to the tee_post_osd, however, given that my FPS = 120, the video output is slightly “delayed” - this causes problems since my audio and video will no longer be in sync.
My other thought was to create the following pipeline,
camera -> tee-> queue -> nvvideoconvert -> caps -> streammux -> nvinfer->nvvideoconvert->nvdsosd->nvvideoconvert->nvegltransform->nveglglessink (x monitor)
this crashes with the follownig output whenever I try to dynmically attach to the Tee
NvMMLiteBlockCreate : Block : BlockType = 8
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:656 Failed to create CaptureSession
(misty-west-sw:12344): GStreamer-CRITICAL **: 00:52:32.037: gst_mini_object_set_qdata: assertion ‘object != NULL’ failed
CONSUMER: Done Success
NVMEDIA: H265 : Profile : 1
NVMEDIA_ENC: bBlitMode is set to TRUE
I have attached the important parts of the code below, is there a way I can do what I want?
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include <cuda_runtime_api.h>
#include "gstnvdsmeta.h"
#include "gst-nvdssr.h"
#include "pthread.h"
#include "time.h"
#include <unistd.h>
GST_DEBUG_CATEGORY (NVDS_APP);
//----------------------------------- Statics
static gboolean bbox_enabled = TRUE;
static GOptionEntry entries[] = {
{"enable", 'e', 0, G_OPTION_ARG_INT, &bbox_enabled,
"Display Bounding box in recorded files", NULL}
{NULL}
static gint frame_number = 0;
static gchar pgie_classes_str[4][32] = { "Vehicle", "TwoWheeler", "Person",
"Roadsign"
static NvDsSRContext *ctx = NULL;
static GMainLoop *loop;
static GstElement *pipeline, *tee_smart_cap, *mmux, *tee_aud, *fakesink, *audioconvert, *vorbisenc, *p_nvvidconv,
*encoder, *parser, *filesink_a, *filesink_v, *queue_record, *queue_aud, *matmux_a, *matmux_v;
static GstBus *bus;
static GstPad *teepad, *teepad_aud;
static gboolean recording = FALSE;
static int counter;
GstElement *source = NULL;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
GMainLoop *loop = (GMainLoop *) data;
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_EOS:
g_print ("End of stream\n");
g_main_loop_quit (loop);
break;
case GST_MESSAGE_ERROR:{
gchar *debug;
GError *error;
gst_message_parse_error (msg, &error, &debug);
g_printerr ("ERROR from element %s: %s\n",
GST_OBJECT_NAME (msg->src), error->message);
if (debug)
g_printerr ("Error details: %s\n", debug);
g_free (debug);
g_error_free (error);
break;
default:
break;
return TRUE;
static
GstPadProbeReturn unlink_cb(GstPad *pad, GstPadProbeInfo *info, gpointer user_data) {
g_print("Unlinking...");
GstPad *sinkpad;
sinkpad = gst_element_get_static_pad (queue_record, "sink");
gst_pad_unlink (teepad, sinkpad);
gst_object_unref (sinkpad);
sinkpad = gst_element_get_static_pad (queue_aud, "sink");
gst_pad_unlink (teepad_aud, sinkpad);
gst_element_send_event(vorbisenc , gst_event_new_eos());
gst_element_send_event(encoder , gst_event_new_eos());
usleep(150000);
gst_bin_remove(GST_BIN (pipeline), queue_record);
gst_bin_remove(GST_BIN (pipeline), queue_aud);
gst_bin_remove(GST_BIN (pipeline), encoder);
gst_bin_remove(GST_BIN (pipeline), parser);
gst_bin_remove(GST_BIN (pipeline), matmux_a);
gst_bin_remove(GST_BIN (pipeline), matmux_v);
gst_bin_remove(GST_BIN (pipeline), filesink_a);
gst_bin_remove(GST_BIN (pipeline), filesink_v);
gst_bin_remove(GST_BIN (pipeline), vorbisenc);
gst_element_set_state(queue_record , GST_STATE_NULL);
gst_element_set_state(queue_aud , GST_STATE_NULL);
gst_element_set_state(encoder , GST_STATE_NULL);
gst_element_set_state(parser , GST_STATE_NULL);
gst_element_set_state(vorbisenc , GST_STATE_NULL);
gst_element_set_state(matmux_a , GST_STATE_NULL);
gst_element_set_state(matmux_v , GST_STATE_NULL);
gst_element_set_state(filesink_a , GST_STATE_NULL);
gst_element_set_state(filesink_v , GST_STATE_NULL);
gst_object_unref(queue_record);
gst_object_unref(queue_aud);
gst_object_unref(encoder);
gst_object_unref(parser);
gst_object_unref(filesink_a);
gst_object_unref(filesink_v);
gst_object_unref(vorbisenc);
gst_object_unref(matmux_a);
gst_object_unref(matmux_v);
gst_element_release_request_pad (tee_aud , teepad_aud);
gst_element_release_request_pad (tee_smart_cap , teepad);
gst_object_unref (teepad);
gst_object_unref (teepad_aud);
return GST_PAD_PROBE_REMOVE;
static
void stop_recording() {
g_print("stop Recording\n");
gst_pad_add_probe(teepad, GST_PAD_PROBE_TYPE_IDLE, unlink_cb, NULL, (GDestroyNotify) g_free);
static
void start_recording() {
g_print("start Recording\n");
GstPad *sinkpad;
GstPadTemplate *templ;
/* get video T pad */
templ = gst_element_class_get_pad_template(GST_ELEMENT_GET_CLASS(tee_smart_cap), "src_%u");
teepad = gst_element_request_pad(tee_smart_cap, templ, NULL, NULL);
/* get audio T pad */
templ = gst_element_class_get_pad_template(GST_ELEMENT_GET_CLASS(tee_aud), "src_%u");
teepad_aud = gst_element_request_pad(tee_aud, templ, NULL, NULL);
/* Dynamic Video pipeline */
queue_record = gst_element_factory_make( "queue" , "queue_record");
encoder = gst_element_factory_make( "nvv4l2h265enc" , NULL );
parser = gst_element_factory_make( "h265parse" , NULL );
matmux_v = gst_element_factory_make( "matroskamux" , "muxy-mat-vid" );
filesink_v = gst_element_factory_make( "filesink" , NULL );
/* Dynamic audio pipeline */
queue_aud = gst_element_factory_make( "queue" , "que-ad" );
vorbisenc = gst_element_factory_make( "vorbisenc" , "vorb-1" );
matmux_a = gst_element_factory_make( "matroskamux" , "muxy-mat-aud" );
filesink_a = gst_element_factory_make( "filesink" , NULL );
char *file_name = (char*) malloc(255 * sizeof(char));
sprintf(file_name, "%s%daudio.mkv", "/home/sam/merge/", counter);
g_object_set(filesink_a, "location", file_name, NULL);
sprintf(file_name, "%s%dvideo.mkv", "/home/sam/merge/", counter);
g_object_set(filesink_v, "location", file_name, NULL);
free(file_name);
g_object_set(filesink_v, "sync", false, NULL);
gst_bin_add_many(GST_BIN(pipeline),
gst_object_ref(queue_record),
gst_object_ref(queue_aud),
gst_object_ref(encoder),
gst_object_ref(parser),
gst_object_ref(vorbisenc),
gst_object_ref(matmux_a),
gst_object_ref(matmux_v),
gst_object_ref(filesink_a),
gst_object_ref(filesink_v),
NULL);
/* add the video and audio elements */
gst_element_link_many(queue_record, encoder, parser, matmux_v, filesink_v, NULL);
if (!gst_element_link_many(queue_aud, vorbisenc, matmux_a, filesink_a, NULL)){
g_print("Failed! to link elements");
gst_element_sync_state_with_parent(queue_record);
gst_element_sync_state_with_parent(queue_aud);
gst_element_sync_state_with_parent(encoder);
gst_element_sync_state_with_parent(parser);
gst_element_sync_state_with_parent(vorbisenc);
gst_element_sync_state_with_parent(matmux_a);
gst_element_sync_state_with_parent(matmux_v);
gst_element_sync_state_with_parent(filesink_a);
gst_element_sync_state_with_parent(filesink_v);
sinkpad = gst_element_get_static_pad(queue_record, "sink");
gst_pad_link(teepad, sinkpad);
gst_object_unref(sinkpad);
sinkpad = gst_element_get_static_pad(queue_aud, "sink");
gst_pad_link(teepad_aud, sinkpad);
g_print("Recording!");
recording = TRUE;
void sigintHandler(int unused) {
g_print("You ctrl-c!\n");
static bool rec;
if (rec)
stop_recording();
else{
start_recording();
rec = true;
// Video pipeline
// camera -> tee|-> queue -> nvvideoconvert -> caps -> streammux -> nvinfer->nvvideoconvert->nvdsosd->nvvideoconvert->nvegltransform->nveglglessink (x monitor)
// (dynamic) |-> queue -> encoder -> parser -> matroskamux -> filesink
int
main (int argc, char *argv[])
signal(SIGINT, sigintHandler);
GMainLoop *loop = NULL;
GstElement *h264parser = NULL,
*decoder = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL, *nvvidconv = NULL,
*nvosd = NULL;
GstElement *transform = NULL;
GstBus *bus = NULL;
guint bus_watch_id;
GstPad *osd_sink_pad = NULL;
GstCaps *caps = NULL, *caps_filter_src = NULL;
GstElement *vidconvsrc, *nvvidconvsrc, *caps_nvvidconvsrc, *queue_post_osd, *queue_post_tee;
GstElement *encoder_post_osd, *parser_post_osd, *nvvidconv2;
int current_device = -1;
cudaGetDevice(¤t_device);
struct cudaDeviceProp prop;
cudaGetDeviceProperties(&prop, current_device);
GOptionContext *gctx = NULL;
GOptionGroup *group = NULL;
GError *error = NULL;
NvDsSRInitParams params = { 0 };
gctx = g_option_context_new ("Nvidia DeepStream Test-SR app");
group = g_option_group_new ("SR_test", NULL, NULL, NULL, NULL);
g_option_group_add_entries (group, entries);
g_option_context_set_main_group (gctx, group);
g_option_context_add_group (gctx, gst_init_get_option_group ());
GST_DEBUG_CATEGORY_INIT (NVDS_APP, "NVDS_APP", 0, NULL);
if (!g_option_context_parse (gctx, &argc, &argv, &error)) {
g_printerr ("%s", error->message);
g_print ("%s", g_option_context_get_help (gctx, TRUE, NULL));
return -1;
/* Standard GStreamer initialization */
gst_init (&argc, &argv);
loop = g_main_loop_new (NULL, FALSE);
/* Create gstreamer elements */
/* Create Pipeline element that will form a connection of other elements */
pipeline = gst_pipeline_new ("dstest1-pipeline");
/* Source element for reading from the camera */
source = gst_element_factory_make ( "nvarguscamerasrc", "nv-nvarguscamerasrc" );
vidconvsrc = gst_element_factory_make ( "videoconvert" , "convertor_src1" );
nvvidconvsrc = gst_element_factory_make ( "nvvideoconvert" , "convertor_src2" );
caps_nvvidconvsrc = gst_element_factory_make ( "capsfilter" , "nvmm_caps" );
p_nvvidconv = gst_element_factory_make ( "nvvideoconvert" , "nvvidconv-1" );
tee_smart_cap = gst_element_factory_make ( "tee" , "tee-post-osd" );
queue_post_tee = gst_element_factory_make ( "queue" , "queue-pre-osd" );
nvvidconv2 = gst_element_factory_make ( "nvvideoconvert" , "nvvideo-converter2" );
caps_filter_src = gst_caps_from_string ("video/x-raw(memory:NVMM), format=NV12, width=1280, height=720, framerate=120/1");
g_object_set (G_OBJECT (caps_nvvidconvsrc ), "caps", caps_filter_src, NULL);
gst_caps_unref (caps_filter_src);
/* Create nvstreammux instance to form batches from one or more sources. */
streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
if (!pipeline || !streammux) {
g_printerr ("One element could not be created. Exiting.\n");
return -1;
/* audio pipeline */
GstElement *asource, *aqueue2, *audioconvert, *capsfilter, *vorb;
asource = gst_element_factory_make ( "alsasrc" , "audio-source" );
tee_aud = gst_element_factory_make ( "tee" , "tee-aud" );
audioconvert = gst_element_factory_make ( "audioconvert" , "audio-conv" );
aqueue2 = gst_element_factory_make ( "queue" , "audio-queue2" );
capsfilter = gst_element_factory_make ( "capsfilter" , "capsfilter" );
fakesink = gst_element_factory_make ( "fakesink" , "fakesnink-1" );
g_object_set (G_OBJECT (asource), "device", "hw:tegrasndt210ref,0", NULL);
caps = gst_caps_from_string("audio/x-raw,format=S32LE,rate=96000,channnels=2");
g_object_set (capsfilter, "caps", caps, NULL);
gst_bin_add_many (GST_BIN (pipeline), asource, capsfilter, audioconvert, tee_aud, aqueue2, fakesink, NULL);
if (!gst_element_link_many ( asource, capsfilter, audioconvert, tee_aud, aqueue2, fakesink, NULL)) {
g_printerr ("Elements could not be linked: 1. Exiting.\n");
return -1;
pgie = gst_element_factory_make ("nvinfer" , "primary-nvinference-engine");
nvvidconv = gst_element_factory_make ("nvvideoconvert" , "nvvideo-converter");
nvosd = gst_element_factory_make ("nvdsosd" , "nv-onscreendisplay");
transform = gst_element_factory_make ("nvegltransform" , "nvegl-transform");
sink = gst_element_factory_make ("nveglglessink" , "nvvideo-renderer");
/* set GOBJECTS params */
g_object_set (G_OBJECT (source) , "bufapi-version", 1, NULL);
g_object_set (G_OBJECT (streammux), "width", 1280, NULL);
g_object_set (G_OBJECT (streammux), "height", 720, NULL);
g_object_set (G_OBJECT (streammux), "batch-size", 1, NULL);
g_object_set (G_OBJECT (streammux), "live-source", 1, NULL);
/* Set all the necessary properties of the nvinfer element,
* the necessary ones are : */
g_object_set (G_OBJECT (pgie), "config-file-path", "dstest1_pgie_config.txt", NULL);
g_object_set (G_OBJECT (sink), "sync", 0, NULL);
/* we add a message handler */
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
/* Set up the pipeline */
/* we add all elements into the pipeline */
if(prop.integrated) {
source, tee_smart_cap, queue_post_tee, vidconvsrc, nvvidconvsrc, caps_nvvidconvsrc, streammux, pgie, p_nvvidconv,
nvvidconv, nvosd, nvvidconv2, transform, sink, NULL);
GstPad *sinkpad, *srcpad;
gchar pad_name_sink[16] = "sink_0";
gchar pad_name_src[16] = "src";
sinkpad = gst_element_get_request_pad (streammux, pad_name_sink);
if (!sinkpad) {
g_printerr ("Streammux request sink pad failed. Exiting.\n");
return -1;
srcpad = gst_element_get_static_pad (caps_nvvidconvsrc, pad_name_src);
if (!srcpad) {
g_printerr ("Decoder request src pad failed. Exiting.\n");
return -1;
if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr ("Failed to link decoder to stream muxer. Exiting.\n");
return -1;
gst_object_unref (srcpad);
#if 1 /* this configuration fails to dynamically link */
if (!gst_element_link_many (source, tee_smart_cap, queue_post_tee, p_nvvidconv, caps_nvvidconvsrc, NULL)) {
return -1;
if (!gst_element_link_many (streammux, pgie,
nvvidconv, nvosd, nvvidconv2, transform, sink, NULL)) {
g_printerr ("Elements could not be linked: 2. Exiting.\n");
return -1;
#else /* this configuration works, but output is skewed */
if (!gst_element_link_many (source, p_nvvidconv, caps_nvvidconvsrc, NULL)) {
return -1;
nvvidconv, nvosd, nvvidconv2, tee_smart_cap, queue_post_tee, transform, sink, NULL)) {
return -1;
#endif
/* Set the pipeline to "playing" state */
g_print ("Now playing: %s\n", argv[1]);
gst_element_set_state (pipeline, GST_STATE_PLAYING);
/* Wait till pipeline encounters an error or EOS */
g_print ("Running...\n");
g_main_loop_run (loop);
/* Out of the main loop, clean up nicely */
g_print ("Returned, stopping playback\n");
gst_element_set_state (pipeline, GST_STATE_NULL);
g_print ("Deleting pipeline\n");
gst_object_unref (GST_OBJECT (pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
