H
i noted that only efficientnet-b0 backbone is available for tlt and noted that for pytoch efficient-b4 is available in ngc. Can i used tlt for efficientnet-b4? thanks
H
Could you please share the link for pytorch efficient-b4 in ngc?
Hi @Morganh
Can you suggest some reference for training efficientnet-b0 (available in NGC) on custom data using tlt?
@skim1
See Overview — TAO Toolkit 3.22.05 documentation and Transfer Learning Toolkit — Transfer Learning Toolkit 3.0 documentation , you can download faster_rcnn jupyter notebook and try run with efficientnet backbone.
hi
i am looking at this:
That one is not compatible with TLT. In TLT, see Transfer Learning Toolkit — Transfer Learning Toolkit 3.0 documentation , then https://ngc.nvidia.com/catalog/models/nvidia:tlt_pretrained_object_detection/files?version=efficientnet_b0_relu or https://ngc.nvidia.com/catalog/models/nvidia:tlt_pretrained_object_detection/files?version=efficientnet_b0_swish , currently, only b0 version is available.
thank you. Any chance that other than b0, b4 and above will be made available for transfer learning toolkit?
They are in the roadmap.
thank you. could i check on the roadmap what estimated time frame for it? thank you
Yesterday, the b1 versions are available at https://ngc.nvidia.com/catalog/models/nvidia:tlt_pretrained_object_detection/files?version=efficientnet_b1_swish and
https://ngc.nvidia.com/catalog/models/nvidia:tlt_pretrained_object_detection/files?version=efficientnet_b1_relu
Currently, EfficientNet B2-B7 are not supported in TLT.
thank you very much. Would hope if other such as B4 can be supported as well since it is already in the ngc.
Can i check what is the differences between those in the TLT and those offered in the NGC(non-TLT)? thanks
In your above-mentioned link efficientnet-b4 pretrained weights (PyTorch, AMP, ImageNet) | NVIDIA NGC , it is for classification. https://github.com/NVIDIA/DeepLearningExamples/tree/master/PyTorch/Classification/ConvNets
It is not compatible with TLT.
In TLT pretrained model link what I mentioned above, they are the pretrained models for TLT classification network or object detection network(FasterRCNN, SSD, DSSD,RetinaNet ) . They are compatible with TLT. Below are the links.
Efficinetnet b0/b1 pretrained models for TLT Classification network: https://ngc.nvidia.com/catalog/models/nvidia:tlt_pretrained_classification/files?version=efficientnet_b1_swish, https://ngc.nvidia.com/catalog/models/nvidia:tlt_pretrained_classification/files?version=efficientnet_b1_relu , https://ngc.nvidia.com/catalog/models/nvidia:tlt_pretrained_classification/files?version=efficientnet_b0_relu,
https://ngc.nvidia.com/catalog/models/nvidia:tlt_pretrained_classification/files?version=efficientnet_b0_swish
Efficinetnet b0/b1 pretrained models for TLT object detection networks: https://ngc.nvidia.com/catalog/models/nvidia:tlt_pretrained_object_detection/files?version=efficientnet_b1_swish,
https://ngc.nvidia.com/catalog/models/nvidia:tlt_pretrained_object_detection/files?version=efficientnet_b1_relu,
https://ngc.nvidia.com/catalog/models/nvidia:tlt_pretrained_object_detection/files?version=efficientnet_b0_relu,
