Hi guys,
I need an example of eglstream code that has GL producer and DMA consumer. I want convert GL buffer to DMA buffer(nvbuf_util.h) in Jetson Tegra Tx2.
Thanks so much
Hi guys,
Thanks so much
This may not be supported. The supported use-case is to create NvBuffer first and map it to an EGLImage. There are multiple demonstrations in the samples and please check
/usr/src/jetson_multimedia_api
