I’m trying to enable redundancy on TX2.
In default Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186_enc_rootfs_ab.xml
I coudn’t see a eks_b partition, so I have added one myself:
<partition name="eks" type="data" oem_sign="true">
<allocation_policy> sequential </allocation_policy>
<filesystem_type> basic </filesystem_type>
<size> 2097152 </size>
<file_system_attribute> 0 </file_system_attribute>
<allocation_attribute> 8 </allocation_attribute>
<percent_reserved> 0 </percent_reserved>
<filename> EKSFILE </filename>
<description> **Optional.** Contains the encrypted keys. </description>
</partition>
<partition name="eks_b" type="data" oem_sign="true">
<description> **Optional.** Slot B; contains the encrypted keys. </description>
</partition>
But after flashing and changing bootslot I see that MB2(TBoot-BPMP) using 0 slot for EKB, even if ekb_b partition exists:
[0000.186] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-03715cad)
[0000.195] I> Boot-device: eMMC
[0000.202] I> sdmmc bdev is already initialized
[0000.207] I> pmic: reset reason (nverc) : 0x0
[0000.239] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0000.259] I> Found 37 partitions in SDMMC_USER (instance 3)
[0000.265] I> A/B: bin_type (16) slot 1
[0000.269] I> Loading partition bpmp-fw_b at 0xd7800000
[0000.274] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.279] I> Addr: 0xd7800000, start-block: 58782912, num_blocks: 1
[0000.306] I> Binary(16) of size 534416 is loaded @ 0xd7800000
[0000.312] I> A/B: bin_type (17) slot 1
[0000.315] I> Loading partition bpmp-fw-dtb_b at 0xd79f0000
[0000.321] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.326] I> Addr: 0xd79f0000, start-block: 58786168, num_blocks: 1
[0000.354] I> Binary(17) of size 604720 is loaded @ 0xd796c400
[0000.585] I> Loading SCE-FW ...
[0000.588] I> A/B: bin_type (12) slot 1
[0000.591] I> Loading partition sce-fw_b at 0xd7300000
[0000.596] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.602] I> Addr: 0xd7300000, start-block: 58792312, num_blocks: 1
[0000.622] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.628] I> Init SCE
[0000.630] I> Loading APE-FW ...
[0000.633] I> A/B: bin_type (11) slot 1
[0000.637] I> Loading partition adsp-fw_b at 0xd7400000
[0000.642] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.647] I> Addr: 0xd7400000, start-block: 58773512, num_blocks: 1
[0000.667] I> Binary(11) of size 77216 is loaded @ 0xd7400000
[0000.673] I> Copy BTCM section
[0000.676] I> A/B: bin_type (13) slot 1
[0000.680] I> Loading partition cpu-bootloader_b at 0x96000000
[0000.685] I> Reading two headers - addr:0x96000000 blocks:1
[0000.691] I> Addr: 0x96000000, start-block: 58741768, num_blocks: 1
[0000.713] I> Binary(13) of size 302064 is loaded @ 0x96000000
[0000.719] I> A/B: bin_type (20) slot 1
[0000.722] I> Loading partition bootloader-dtb_b at 0x8520f400
[0000.728] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.734] I> Addr: 0x8520f400, start-block: 58743816, num_blocks: 1
[0000.757] I> Binary(20) of size 374528 is loaded @ 0x8520f400
[0000.763] I> A/B: bin_type (14) slot 1
[0000.766] I> Loading partition secure-os_b at 0x8530f600
[0000.772] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.777] I> Addr: 0x8530f600, start-block: 58750984, num_blocks: 1
[0000.801] I> Binary(14) of size 394672 is loaded @ 0x8530f600
[0000.809] I> TOS boot-params @ 0x85000000
[0000.812] I> TOS params prepared
[0000.816] I> Loading EKS ...
[0000.818] I> A/B: bin_type (15) slot 0 <# !!! Here
[0000.822] I> Loading partition eks at 0x8590f800
[0000.826] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.832] I> Addr: 0x8590f800, start-block: 58757128, num_blocks: 1
[0000.851] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0000.857] I> EKB detected (length: 0x400) @ 0x8590f800
[0000.862] I> Copied encrypted keys
[0000.866] I> boot profiler @ 0x275844000
[0000.869] I> boot profiler for TOS @ 0x275844000
[0000.874] I> Unhalting SCE
[0000.877] I> Primary Memory Start:80000000 Size:70000000
[0000.882] I> Extended Memory Start:f0110000 Size:1856f0000
[0000.889] I> MB2(TBoot-BPMP) done
So this is my fault or TX2 does not support EKS partition redundancy?
