We are trying to enable the A/B redundancy in TX2. We referred the below linkes and are able to enable it.
https://developer.ridgerun.com/wiki/index.php?title=How_to_enable_A/B_redundancy_in_TX2
We updated the smd_info.cfg file and executed the “sudo nv_smd_generator smd_info.cfg slot_metadata.bin” command and then flashed out device. Here is a copy of our smd_info.cfg.
# Copyright (c) 2017-2018, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
# SMD metadata information
< VERSION 3 >
# Config 1: Disable A/B support (Default)
# slot info order is important!
# <priority> <suffix> <retry_count> <boot_successful>
#15 _a 7 1
# Config 2: Enable redundancy support (by removing comments ##)
< REDUNDANCY_USER 1 >
15 _a 7 1
14 _b 7 1
We checked this with the below commands.
nvidia@tegra-ubuntu:~$ sudo nvbootctrl dump-slots-info
magic:0x43424e00, version: 3 features: 3 num_slots: 2
slot: 0, priority: 15, suffix: _a, retry_count: 7, boot_successful: 1
slot: 1, priority: 14, suffix: _b, retry_count: 7, boot_successful: 1
nvidia@tegra-ubuntu:~$ sudo nvbootctrl get-current-slot
0
The debug log for this case is attached as “normal_working.log”.
In order to test the change in the active slot, we used the dd command to corrupt the _a partition and rebooted the system. We observed two behaviours.
1.We corrupted the mts-bootpack partition using “sudo dd if=examples.desktop of=/dev/mmcblk0p2” command and rebooted the system. The system got booted successfully and the output for nvbootctrl command below.
[sudo] password for nvidia:
slot: 0, priority: 15, suffix: _a, retry_count: 0, boot_successful: 1
1
The device has booted in slot 1.The debug log is attached as “mts-bootpack_corrupted.log”
2.We tried the same by corrupting the kernel partition using “sudo dd if=examples.desktop of=/dev/mmcblk0p26”. This now the device failed to boot. The debug log is attached as “kernel_corrupted.log”
Are these steps enough to enable this device recovery feature? and is there an alternate way to test this?
kernel_corrupted.log (11.7 KB) mts-bootpack_corrupted.log (18.9 KB) normal_working.log (18.7 KB)
