I’m supposed to re-flash the bootloader to make USB 3 work on the Auvidea J90 carrier board.
The documentation I’ve found says I do this by using flash.sh -t EBT jetson-tx2 {partitionid}
However, I don’t know which of the 17 partitions is the EBT partition. None of them are labeled EBT!
nvidia@tegra-ubuntu:~$ sudo gdisk /dev/mmcblk0
GPT fdisk (gdisk) version 1.0.1
Partition table scan:
MBR: protective
BSD: not present
APM: not present
GPT: present
Found valid GPT with protective MBR; using GPT.
Command (? for help): p
Disk /dev/mmcblk0: 61071360 sectors, 29.1 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
Partition table holds up to 17 entries
First usable sector is 4097, last usable sector is 61071327
Partitions will be aligned on 1-sector boundaries
Total free space is 1 sectors (512 bytes)
Number Start (sector) End (sector) Size Code Name
1 4097 58724352 28.0 GiB 0700 APP
2 58724353 58732544 4.0 MiB 0700 mts-bootpack
3 58732545 58733056 256.0 KiB 0700 cpu-bootloader
4 58733057 58733568 256.0 KiB 0700 bootloader-dtb
5 58733569 58739712 3.0 MiB 0700 secure-os
6 58739713 58739716 2.0 KiB 0700 eks
7 58739717 58740924 604.0 KiB 0700 bpmp-fw
8 58740925 58741924 500.0 KiB 0700 bpmp-fw-dtb
9 58741925 58746020 2.0 MiB 0700 sce-fw
10 58746021 58758308 6.0 MiB 0700 sc7
11 58758309 58762404 2.0 MiB 0700 FBNAME
12 58762405 59024548 128.0 MiB 0700 BMP
13 59024549 59090084 32.0 MiB 0700 SOS
14 59090085 59221156 64.0 MiB 0700 kernel
15 59221157 59221668 256.0 KiB 0700 kernel-dtb
16 59221669 59745956 256.0 MiB 0700 CAC
17 59745957 61071326 647.2 MiB 0700 UDA
Which of these is the bootloader? Do I still use flash.sh -t EBT to flash the bootloader? Does it matter that “make” in the bootloader directory fails, complaining there is no “.config” created? (Even though I can make the kernel and modules?)
(And, honestly, WTH? Why is there more than a “boot” partition and a “file system” partition? What are the all for? What document am I missing that explains them all?)
