Embedded Data from MIPI in Xavier NX
This is my previous query related to same topic.
Here, I got output while applying the below settings.
mclk_khz = "24000";
				num_lanes = "2";
				tegra_sinterface = "serial_d";
				discontinuous_clk = "no";
				dpcm_enable = "false";
				cil_settletime = "0";
				dynamic_pixel_bit_depth = "16";
				csi_pixel_bit_depth = "16";
				mode_type = "yuv";
				pixel_phase = "yuyv";
				active_w = "1920";
				active_h = "1081";
				readout_orientation = "0";
				line_length = "2468";
				embedded_metadata_height = "0";
But as per the other forum solutions, to extract embedded data we need to set embedded_metadata_height = “1”. But while applying this, I’m facing some stuck in streaming.
Please check the output while I had set the height as 1081 and embedded data as 0. How to extract the embedded data from the above 1920*1081 buffer or Is there any files which I can take as reference?. Also, Is there any issues in the ISP binary which I’m using?
testcamembedded.zip (2.3 MB)
@ShaneCCC Can you please check this issue?.
The embedded data line shouldn’t include to the height. Just add correct line for the embedded_metadata_height and keep report the output exclude the embedded data line.
Hi @ShaneCCC
I had applied the below modifications in device tree as well as in the driver.
DEVICE TREE
vi@15c10000 {
	num-channels = <1>;
	ports {
			port@0 {
			reg = <0>;
			ox03a10_vi_in2: endpoint {
					port-index = <3>;
					bus-width = <2>;
					remote-endpoint = <&ox03a10_csi_out2>;
nvcsi@15a00000 {
	num-channels = <1>;
	channel@0 {
		reg = <0>;
		ports {
			port@0 {
				reg = <0>;
				ox03a10_csi_in2: endpoint@0 {
					port-index = <3>;
					bus-width = <2>;
					remote-endpoint = <&ox03a10_ox03a10_out2>;
			port@1 {
				reg = <1>;
				ox03a10_csi_out2: endpoint@1 {
					remote-endpoint = <&ox03a10_vi_in2>;
ox03a10_d@1c {
	compatible = "nvidia,ox03a10";
	reg = <0x1c>;
	devnode = "video2";
	physical_w = "15.0";
	physical_h = "12.5";
	sensor_model ="ox03a10";
	post_crop_frame_drop = "0";
	use_decibel_gain = "true";
	delayed_gain = "true";
	use_sensor_mode_id = "true";
	sensor_slave_mode = "true";
	mode0 {
		mclk_khz = "24000";
		num_lanes = "2";
		mode_type = "yuv";
		active_w = "1920";
		active_h = "1080";
		inherent_gain = "1";
		pix_clk_hz = "209681280";
		serdes_pix_clk_hz = "833333333";
		gain_factor = "16";
		min_gain_val = "16"; /* 0dB */
		max_gain_val = "511"; /* 48dB */
		step_gain_val = "1"; /* 0.1 */
		default_gain = "16";
		min_hdr_ratio = "1";
		max_hdr_ratio = "1";
		framerate_factor = "1000000";
		min_framerate = "20000000"; /* 20fps */
		max_framerate = "20000000"; /* 20fps */
		step_framerate = "1";
		default_framerate = "20000000";
		exposure_factor = "1000000";
		min_exp_time = "12"; /* us */
		max_exp_time = "50000"; /* us */
		step_exp_time = "1";
		default_exp_time = "1500";/* us */
		embedded_metadata_height = "1";
	ports {
		port@0 {
			reg = <0>;
			ox03a10_ox03a10_out2: endpoint {
				port-index = <3>;
				bus-width = <2>;
				remote-endpoint = <&ox03a10_csi_in2>;
DRIVER FILE
 * WARNING: frmfmt ordering need to match mode definition in
 * device tree!
static const struct camera_common_frmfmt ox03a10_frmfmt[] = {
	{{1920, 1080}, ox03a10_20fps, 1, 0, OX03A10_MODE_1920X1080_20FPS},
	/* Add modes with no device tree support after below */
While executing the below pipeline in order to get streaming, I’m getting a stuck in the streaming.
gst-launch-1.0 v4l2src -v device=/dev/video2 ! identity silent=FALSE ! videoconvert ! xvimagesink
Output Streaming Video :
stuck_streaming_embedded.zip (16.3 MB)
I had also collected trace from another terminal as mentioned here.
Trace Logs :
errlog_embedded_data.txt (1.7 MB)
Can you please check this issue and correct me if I’m doing anything wrong.
Looks the embedded data type incorrect. The embedded data type should be 0x12
 kworker/1:3-1629  [001] ....  6273.002251: rtcpu_vinotify_event: tstamp:196452047629 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:196451589255 data:0x04380040
Hi @ShaneCCC
Can you suggest me what might be the reason for the wrong embedded data type?. We’re getting the stream from an external ISP. Should we need to alter the ISP Image in order to resolve this issue?
You may need consult with sensor vendor to confirm the embedded data type. Current Jetson device only support 0x12 embedded data type only.
Hi @ShaneCCC
Thanks for the reply.
Can you help me to figure out what’s the current value of embedded data type from the trace what I shared.
Also, to make it clear the sensor vendor asked about what does this Embedded Data Type=0x12 means?. Is that the Generic 8 bit long packet data types mentioned in the below document?(page 73)
Yes, it’s
Hi @ShaneCCC
I checked with the sensor vendor and modified the ISP binary. Right now the data_type of embedded data is 0x12.
Also, I modified the device tree parameters like this.
active_w = "1920";
active_h = "1080";
Also, changed the driver parameters to
In this scenario, I’m facing similar stuck issue again, but with some irregularities in the stream.
Streaming Error : stuck_streaming_embedded_new-2024-01-03_17.09.39.zip (20.6 MB)
Trace Logs : tracelog_newbin_447.txt (3.6 MB)
Can you guide me to debug on this issue?
Make sure how many lines of embedded data output.
Hi @ShaneCCC
Sure, I’ll recheck with the vendor on the same.
I also wanted to add one more observation. When I tried to set embedded_data_height as 0, I’m getting streaming without any stuck. But still some irregularities in the streaming.
active_w = "1920";
active_h = "1080";
Driver End
Streaming Error : stuck_streaming_embedded_new_new-2024-01-03_22.53.41.zip (18.9 MB)
Trace Logs : tracelog.txt (1.4 MB)
Can you please check whether it’s an issue with Image Size or Embedded Data Size?
The CHANSEL_NOMATCH could be incorrect embedded data lines cause it.
kworker/0:2-8348 [000] … 372.957563: rtcpu_vinotify_event: tstamp:12079508852 tag:CHANSEL_NOMATCH channel:0x08 frame:0 vi_tstamp:12079133832 data:0x000003c9
Hi @ShaneCCC
The datatype expected for Embedded Data is 0x12 and for Image data it needs to be 0x1E If I’m planning to collect Embedded data and Image Data(YUV422 8-bit) simultaneously, right?
