Hi all. I use Xavier NX module to access some cameras, but mipi signal cannot be identified. I don’t use VI0 , but let LT9211 turn MIPI input VI1, VI2,VI3, VI4 , and let a PAL turn MIPI input VI5 . The mipi input of vi1-vi5 all have not collected data in these ways and trace said :
v4l2-ctl-8852 [000] … 669.389366: tegra_channel_open: vi-output, iraytek 14-0034
v4l2-ctl-8852 [000] … 669.390873: tegra_channel_set_power: iraytek 14-0034 : 0x1
v4l2-ctl-8852 [000] … 669.390885: camera_common_s_power: status : 0x1
v4l2-ctl-8852 [000] … 669.414067: tegra_channel_set_power: 15a00000.nvcsi–1 : 0x1
v4l2-ctl-8852 [000] … 669.414073: csi_s_power: enable : 0x1
v4l2-ctl-8852 [000] … 669.427030: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 10
v4l2-ctl-8852 [000] … 669.433261: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-8852 [000] … 669.434704: tegra_channel_set_stream: 15a00000.nvcsi–1 : 0x1
v4l2-ctl-8852 [000] … 669.434708: csi_s_stream: enable : 0x1
v4l2-ctl-8852 [000] … 669.434738: tegra_channel_set_stream: iraytek 14-0034 : 0x1
kworker/1:4-6018 [001] … 669.440528: rtos_queue_peek_from_isr_failed: tstamp:21343541525 queue:0x0bcbbbb8
kworker/1:4-6018 [001] … 669.440534: rtcpu_start: tstamp:21343543331
kworker/1:4-6018 [001] … 669.440537: rtos_queue_send_from_isr_failed: tstamp:21343553970 queue:0x0bcb2e38
kworker/1:4-6018 [001] … 669.440538: rtos_queue_send_from_isr_failed: tstamp:21343554122 queue:0x0bcb76a0
kworker/1:4-6018 [001] … 669.440542: rtcpu_string: tstamp:21343563192 id:0x04010000 str:“vi5_hwinit: firmware CL2018101701 protocol vers”
kworker/1:4-6018 [001] … 669.440544: rtcpu_string: tstamp:21343563312 id:0x04010000 str:"on 2.2
kworker/1:4-6018 [001] … 669.440570: rtos_queue_send_from_isr_failed: tstamp:21343651925 queue:0x0bcb2e38
kworker/1:4-6018 [001] … 669.440578: rtos_queue_send_from_isr_failed: tstamp:21343699503 queue:0x0bcbada0
kworker/1:4-6018 [001] … 669.496488: rtcpu_vinotify_event: tstamp:21344062350 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:21571973984 data:0x10000000
kworker/1:4-6018 [001] … 669.496491: rtcpu_vinotify_event: tstamp:21344062514 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:21571982176 data:0x31000001
kworker/1:4-6018 [001] … 669.496493: rtcpu_vinotify_event: tstamp:21344062676 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:21571984352 data:0x07020001
kworker/1:4-6018 [001] … 669.496494: rtcpu_vinotify_event: tstamp:21344062811 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:21572017664 data:0x10000000
kworker/1:4-6018 [001] … 669.496495: rtcpu_vinotify_event: tstamp:21344062968 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:21572025920 data:0x31000002
kworker/1:4-6018 [001] … 669.608472: rtos_queue_peek_from_isr_failed: tstamp:21348541898 queue:0x0bcbbbb8
and
kworker/0:2-1310 [000] … 159.965384: rtcpu_nvcsi_intr: tstamp:5421808113 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/0:2-1310 [000] … 159.965385: rtcpu_nvcsi_intr: tstamp:5421808113 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
My Device tree dts files such as:
tegra194-camera-jakku-rbpcv2-iraytek.dtsi (3.3 KB)
tegra194-camera-rbpcv2-iraytek.dtsi (25.3 KB)
I don’t know how to debug my error
Could anyone help me? Or what’s files do you want me to give you?
Boost the NVCSI/VI/ISP clocks then try capture by v4l2-ctl again.
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
Dear ShaneCCC,thanks your help. I execute your code and the v4l2-ctl capture results are as follows.
#v4l2-ctl -d /dev/video0 --set-fmt-video=width=1280,height=720,pixelformat=YUYV–set-ctrl --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --verbose
VIDIOC_QUERYCAP: ok
VIDIOC_S_EXT_CTRLS: ok
VIDIOC_G_FMT: ok
VIDIOC_ENUM_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : ‘YUYV’
Field : None
Bytes per Line : 3840
Size Image : 4147200
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Limited Range)
Flags :
VIDIOC_REQBUFS: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_STREAMON: ok
Index : 0
Type : Video Capture
Flags : mapped, error
Field : None
Sequence : 0
Length : 4147200
Bytesused: 4147200
Timestamp: 0.000000s (Monotonic, End-of-Frame)
But the camera still can’t collect information, my trace log is as follows.
trace.log (34.1 KB)
And I found that I set was 1280*720 in the DTS but it display 1920/1080 inthe v4l2-ctl.
What’s the real output size? Modify the driver to report correct size.
the real output size is 1280*720
Dear ShaneCCC, I have completed the camera recognition of the LT9211 turn MIPI input VI1-VI4, but the XS9922 chip PAL to MIPI input VI0 is still unsuccessful.There may be a problem with the VI5 board and I have abandoned it. There are some questions.
Firstly,it‘s said pix_clk_hz can be configured in three ways:
Using PLL multiplier and PLL pre/post dividers:
Using sensor CSI lane output rate:
Using frame size and frame rate:
but i use sensor CSI lane output rate: pix_clk_hz = 600M×2lane/16 = 75000000 and Using frame size and frame rate : pix_clk_hz = 1650×750*25 = 30937500. Which should i chance in my Device tree file?
My dtsi file is as follows
tegra194-camera-rbpcv2-iraytek(1).dtsi (24.3 KB)
Secondly, When my mipi input 1.5G/2lane, I collect the log print:
kworker/0:0-8728 [000] … 388.014154: rtcpu_vinotify_event: tstamp:12547617495 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:10671441664 data:0x10000000
kworker/0:0-8728 [000] … 388.014156: rtcpu_vinotify_event: tstamp:12547617657 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:10671449856 data:0x31000001
kworker/0:0-8728 [000] … 388.014157: rtcpu_vinotify_event: tstamp:12547617818 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:10671451968 data:0x07020001
kworker/0:0-8728 [000] … 388.014158: rtcpu_vinotify_event: tstamp:12547617954 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:10671485312 data:0x10000000
kworker/0:0-8728 [000] … 388.014159: rtcpu_vinotify_event: tstamp:12547618112 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:10671493600 data:0x3100000
But when my mipi input 800M/2lane, I collect the log print:
kworker/0:2-1637 [000] … 102.734404: rtcpu_nvcsi_intr: tstamp:3631040994 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:2-1637 [000] … 102.734405: rtcpu_nvcsi_intr: tstamp:3631040994 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:2-1637 [000] … 102.734406: rtcpu_nvcsi_intr: tstamp:3631177700 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:2-1637 [000] … 102.734406: rtcpu_nvcsi_intr: tstamp:3631177700 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000080
kworker/0:2-1637 [000] … 102.734407: rtcpu_nvcsi_intr: tstamp:3631178248 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000080
If it means that I did not collect mipi data at 1.5G, and i can collect mipi date but the date have some error at 800M. How can i correct it?
For your case the pix_clk_hz only for calculating the NVCSI/VI/ISP clocks bandwidth you can configure is as much bigger as any of your calculation or boost those clocks and ignore the configure in device tree.
