When attempting to integrate the IMX462 with the Orinoco NX, an embedded data line parsing error was encountered. For details, please refer to the log.
According to the sensor’s datasheet, the IMX462 has only 1 line of embedded data. However, when I attempted to set the “embedded_metadata_height” in the device tree source (DTS) to all values between 0 and 4, I encountered the error code 0x249 as shown in the attached log. error.txt (56.9 KB)
may I also know what’s the data-type of this embedded metadata?
is it sending top/bottom embedded metadata separately?
FYI, embedded data are supported with 0x12 data types, (i.e. embeddedData type specified by CSI-2).
if you’ve embedded line with other data type, it’ll need software implementation to setup a dedicate VI channel to receive embedded line data.
so, the configuration… embedded_metadata_height must be 1-line in the device tree settings.
please enable VI tracing log with 1-line of embedded data for reference, thanks
@JerryChang
I believe you’ve highlighted a crucial point of concern. The output of IMX462 has 3 dummy pixels on the right side of each line, which might be related to this.
For instance, if I set WINWH to 1920 and the dummy pixels are not what I desire, how should I configure it in this case?
Should it be active_w=1920, num_of_right_margin_pixels=3?
Does the line_length need to be set to a specific number accurately?
is it a SDR or WDR DOL (Digital Overlap) sensors?
this property num_of_right_margin_pixels only works with DOL sensors.
do you really need those dummy region?
what if setting active_w as 1920? don’t that match your expectation?
besides, line_length that should also depends-on your register settings.
@JerryChang I have made a new discovery. The previous assumption about the direction of active_w might have been incorrect. I encountered an error when using a resolution of 1920x1080, but when using 1920x1088, I am able to receive images correctly.
@JerryChang I have a question regarding how to configure active_h. Should EBD+NULL+OB+WINWH in the diagram above all be included in the calculation for active_h? In reality, I only need the data from WINWH.
there’re different pixel parsers, there’s specific pixel parser for embedded metadata.
it’s embedded_metadata_height definition to handle that, so, EBD is not included for active region.
active_h means the total height of the pixel-active region. basically, the active_h should be identical with recording pixel height, sometimes, you should add some effective margin for your real use-case.
