During the startup process of my chip, I received a prompt indicating this issue. After executing for 6 seconds, it got stuck on the bpmp log and stopped starting the system.
I have two questions: (1) Under what circumstances will it be triggered, and what are the triggering conditions? Could you provide some source code interpretation?
FATAL ERROR [FILE=platform/drivers/emc/lib/t264/dvfs_training_sequence.c, ERR_UID=9999113]: fatal error: 0x0000000
(2) Is it related to bpmp? Currently, we have reproduced the issue on two devices, and the output logs are stuck at bpmp logs compared to normal:
[mos][11-22 15:47:35][ 3.420263] sdhci-pltfm: SDHCI platform and OF driver helper
[mos][11-22 15:47:35][ 3.426578] ledtrig-cpu: registered to indicate activity on CPUs
[mos][11-22 15:47:35][ 3.431725] SMCCC: SOC_ID: ID = jep106:036b:0264 Revision = 0x00000401
[mos][11-22 16:04:16]ÿáL4TLauncher: Attempting Direct BoÿíL4TLÿáot
[mos][11-22 16:04:16]ÿíauncher: AttÿáL4T ÿíemptÿáOverÿíing ÿálayFÿíDireÿásModÿíct Bÿáe = ÿíoot
[mos][11-22 16:04:16]ÿá1, Sÿí
[mos][11-22 16:04:16]L4Tÿátatuÿí Oveÿás = ÿírlayÿáSuccÿíFsMoÿáess
[mos][11-22 16:04:16]ÿíde =ÿá
[mos][11-22 16:04:16]L4Tÿí 1, ÿá OveÿíStatÿárlayÿíus =ÿáFsMoÿí Sucÿáde oÿícessÿápen,ÿí
[mos][11-22 16:04:16]L4ÿá
[mos][11-22 16:04:16] reaÿíT Ovÿád apÿíerlaÿáp_upÿíyFsMÿáper ÿíode ÿábootÿíopenÿá\extÿí, reÿálinuÿíad aÿáx\exÿípp_uÿátlinÿípperÿáux.cÿí booÿáonf
[mos][11-22 16:04:16]ÿít\exÿá
[mos][11-22 15:47:30][ 0.000000] Kerne
[mos][11-22 15:47:30]l command line: root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 earlycon=tegra_utc,mmio32,0xc5a0000 console=ttyUTC0,115200 clk_ignore_unused firmware_class.path=/etc/firmware fbcon=map:0 efi=runtime nv-auto-config root=PARTUUID=4c8fd331-
[mos][11-22 15:47:30]30cb-4210-aad9-4e659cd5890f rw rootwait rootfstype=ext4 mminit_loglevel=4 earlycon=tegra_utc,mmio32,0xc5a0000 console=ttyUTC0,115200 clk_ignore_unused firmware_class.path=/etc/firmware fbcon=map:0 efi=runtime vfio-pci.ids=8086:15f2 default
[mos][11-22 15:47:30]_hugepagesz=2M hugepagesz=2M hugepages=128 isolcpus=4,5,6,7 irqaffinity=0,1,2,3,8,9,10,11,12,13 bl_prof_dataptr=6225920@0x2008010000 bl_prof_ro_ptr=65536@0x2008000000
[mos][11-22 15:47:30][ 0.000000] Unknown kernel command line parameters "nv-auto-config bl_prof_dataptr=
[mos][11-22 15:47:30]6225920@0x2008010000 bl_prof_ro_ptr=65536@0x2008000000", will be passed to user space.
[mos][11-22 15:47:30][ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[mos][11-22 15:47:30][ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432
[mos][11-22 15:47:30]bytes, linear)
[mos][11-22 15:47:30][ 0.000000] Fallback order for Node 0: 0
[mos][11-22 15:47:30][ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32264584
[mos][11-22 15:47:30][ 0.000000] Policy zone: Normal
[mos][11-22 15:47:30][ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[mos][11-22 15:47:31][ 0.000000] software IO TLB: area num 16.
[mos][11-22 15:47:31][ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[mos][11-22 15:47:31]��
[mos][11-22 15:47:31]FATAL ERROR [FILE=platform/drivers/emc/lib/t264/dvfs_training_sequence.c, ERR_UID=9999113]: fatal error: 0x0000000
[mos][11-22 15:47:31]8
[mos][11-22 15:47:31]firmware tag: 4ee12e385c2c3de43ce1-8a91e46f275
[mos][11-22 15:47:31]r0_usr 0x500efea6
[mos][11-22 15:47:31]r1_usr 0x00989309
[mos][11-22 15:47:31]r2_usr 0x500a47cc
[mos][11-22 15:47:31]r3_usr 0x50203914
[mos][11-22 15:47:31]r4_usr 0x50022204
[mos][11-22 15:47:31]r5_usr 0x500a47cc
[mos][11-22 15:47:31]r6_usr 0x00989309
[mos][11-22 15:47:31]r7_usr 0x500efea6
[mos][11-22 15:47:31]r8_usr 0x50203914 r8_fiq 0x00000000
[mos][11-22 15:47:31]r9_usr 0x0000
[mos][11-22 15:47:31]0000 r9_fiq 0x00000000
[mos][11-22 15:47:31]r10_usr 0x0003f7a0 r10_fiq 0x00000000
[mos][11-22 15:47:31]r11_usr 0x50350920 r11_fiq 0x00000000
[mos][11-22 15:47:31]r12_usr 0x50203d48 r12_fiq 0x00000000
[mos][11-22 15:47:31]sp_usr 0x502038f8 sp_fiq 0x50050880 sp_irq 0x50050c00
[mos][11-22 15:47:31]sp_svc 0x50051400 sp_abt 0x50050800 sp_und 0x50050770
[mos][11-22 15:47:31]lr_u
[mos][11-22 15:47:31]sr 0x50023563 lr_fiq 0x00000000 lr_irq 0x500cf7ba
[mos][11-22 15:47:31]lr_svc 0x5003a839 lr_abt 0x00000000 lr_und 0x50022208
[mos][11-22 15:47:31]pc 0x50022204
[mos][11-22 15:47:31]spsr 0x00000010
[mos][11-22 15:47:31]fpscr 0x80000010
[mos][11-22 15:47:31]00.0: base: 50000000 size: 00200000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
[mos][11-22 15:47:31]0.1: base: 50200000 size: 00200000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
[mos][11-22 15:47:31]00.2: base: 50400000 size: 00200000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
[mos][11-22 15:47:31]00.3: base: 50600000 size: 00200000 XN P_RW U_RW Non-shareab
[mos][11-22 15:47:31]le outer: WB, no WA inner: WB, no WA
[mos][11-22 15:47:31]00.4: base: 50800000 size: 00200000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
[mos][11-22 15:47:31]01: base: 80000000 size: 80000000 XN P_RW U_RW Shareable strongly-ordered
[mos][11-22 15:47:31]02: base: ffff0000 size: 00000040 X P_RO U_
[mos][11-22 15:47:31]NA Non-shareable outer: WB, no WA inner: WB, no WA
[mos][11-22 15:47:31]03.2: base: 50020000 size: 00010000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
[mos][11-22 15:47:31]03.3: base: 50030000 size: 00010000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
[mos][11-22 15:47:31]03.4: b
[mos][11-22 15:47:31]ase: 50040000 size: 00010000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
[mos][11-22 15:47:31]04.2: base: 50080000 size: 00040000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
[mos][11-22 15:47:31]04.3: base: 500c0000 size: 00040000 X P_RO U_RO Non-shareable out
[mos][11-22 15:47:31]er: WB, no WA inner: WB, no WA
[mos][11-22 15:47:31]04.4: base: 50100000 size: 00040000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
[mos][11-22 15:47:31]05: base: 50140000 size: 00040000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
[mos][11-22 15:47:31]06: base: 50200000 size: 0008
[mos][11-22 15:47:31]0000 XN P_RO U_NA Non-shareable outer: WB, no WA inner: WB, no WA
[mos][11-22 15:47:31]07.3: base: 50600000 size: 00200000 XN P_RO U_RO Non-share��[ ��able�� 0.0�� out��0000��er: ��0] M��WB, ��emor��no W��y: 1��A in��2824��ner:��3068�� WB,��K/13�� no ��1124��WA
[mos][11-22 15:47:31]��864K��07
What error codes represent?
Is the source code for dvfs_training_sequence.c open source?
[mos][11-22 15:47:31]FATAL ERROR [FILE=platform/drivers/emc/lib/t264/dvfs_training_sequence.c, ERR_UID=9999113]: fatal error: 0x00000008
It is a known issue to us and we are still debugging for the fix.
jetpack 7.1 版本能否修复?
这个问题和bpmp 有关系吗?
请问这个是否是thor单体间差异造成的?
no, this issue is from bpmp firmware.
再请问nvidia 的复现方法也是开关机压测吗?我们用不同设备做了大量的开关机测试,都没有复现问题。只是在两台机器人整机上做开关机测试偶现了这个问题。
Is this question the same as the one below, and will it be resolved in JP7.1?
One device always happen this issue when booting, and it cannot boot normally,
How to resolve this issue one this device? It is serious problem.
If only on this device, then suggest to contact our local distributor to do RMA.
This issue was not resolved in version JP7.1.
Since you have access to NVONLINE system, please work with our teams through NVONLINE. Thanks,
