Enable PXE Network Boot Support on NVIDIA Jetson AGX Xavier
Hi NVIDIA Team,
I am currently using agx xavier NVIDIA L4T R35.1.0 (JetPack 5.0.2) with our custom carrier board. We would like to know whether the NVIDIA Jetson AGX Xavier platform supports PXE booting over a network.
If PXE boot is supported, could you please provide guidance on the following?
  1. What are the prerequisites and configurations required to enable PXE/network boot on the AGX Xavier?
  2. Is there a specific procedure to generate a PXE-loadable boot image using the NVIDIA BSP (Board Support Package)?
  3. Are there any additional modifications required to the default BSP, bootloader, or device tree to support network booting?
  4. Could you share any relevant documentation, scripts, or reference implementations for setting up PXE boot?
Our objective is to boot the AGX Xavier over the network without relying on locally flashed boot media.
Any technical guidance or references would be greatly appreciated.
Regards,
Vrushti
Please refer to the documentation:
Hi @DavidDDD , are this steps to configure pxe compatible with NVIDIA L4T R35.1.0 (JetPack 5.0.2)?
Yes.
Noted: We still recommend upgrade to the latest bsp .
