We’re trying to enable RDMA on vSAN 8 (vCenter: 8.0.1 build: 21860503, VMware ESXi, 8.0.1, 21813344) with our ConnextX5 NICs but running into challenges getting everything configured.
No matter what we configure, we can’t get our NIC to show “Mode: 3 - IEEE mode”. It remains in Mode: 0 - Unknown.
[root@1:~] esxcli network nic dcb status get -n vmnic0
Nic Name: vmnic0
Mode: 0 - Unknown
Enabled: true
Capabilities:
Priority Group: true
Priority Flow Control: true
PG Traffic Classes: 8
PFC Traffic Classes: 8
PFC Enabled: true
PFC Configuration: 0 0 0 1 0 0 0 0
IEEE ETS Configuration:
Willing Bit In ETS Config TLV: 1
Supported Capacity: 8
Credit Based Shaper ETS Algorithm Supported: 0x0
TX Bandwidth Per TC: 13 13 13 13 12 12 12 12
RX Bandwidth Per TC: 13 13 13 13 12 12 12 12
TSA Assignment Table Per TC: 2 2 2 2 2 2 2 2
Priority Assignment Per TC: 1 0 2 3 4 5 6 7
Recommended TC Bandwidth Per TC: 13 13 13 13 12 12 12 12
Recommended TSA Assignment Per TC: 2 2 2 2 2 2 2 2
Recommended Priority Assignment Per TC: 1 0 2 3 4 5 6 7
IEEE PFC Configuration:
Number Of Traffic Classes: 8
PFC Configuration: 0 0 0 0 0 0 0 0
Macsec Bypass Capability Is Enabled: 0
Round Trip Propagation Delay Of Link: 0
Sent PFC Frames: 0 0 0 0 0 0 0 0
Received PFC Frames: 0 0 0 0 0 0 0 0
DCB Apps:
I’ve configured the NIC and ESXi like this:
/opt/mellanox/bin/mlxconfig -d mt4119_pciconf0 set DCBX_IEEE_P1=1 DCBX_CEE_P1=0 DCBX_IEEE_P2=1 DCBX_CEE_P2=0 LLDP_NB_DCBX_P1=1 LLDP_NB_DCBX_P2=1
esxcli system module parameters set -m nmlx5_core -p dcbx=1
esxcli system module parameters set -m nmlx5_core -p "pfctx=0x08 pfcrx=0x08 trust_state=2 max_vfs=4"
esxcli system module parameters set -m nmlx5_rdma -p "pcp_force=3 dscp_force=26"
[root@1:~] /opt/mellanox/bin/mlxconfig -d mt4119_pciconf0 query
Device #1:
Device type: ConnectX5
Description: HPE InfiniBand FDR/Ethernet 40/50Gb 2-port 547FLR-QSFP Adapter
Device: mt4119_pciconf0
Configurations: Next Boot
MEMIC_BAR_SIZE 0
MEMIC_SIZE_LIMIT _256KB(1)
HOST_CHAINING_MODE DISABLED(0)
HOST_CHAINING_CACHE_DISABLE False(0)
HOST_CHAINING_DESCRIPTORS Array[0..7]
HOST_CHAINING_TOTAL_BUFFER_SIZE Array[0..7]
FLEX_PARSER_PROFILE_ENABLE 0
FLEX_IPV4_OVER_VXLAN_PORT 0
ROCE_NEXT_PROTOCOL 254
ESWITCH_HAIRPIN_DESCRIPTORS Array[0..7]
ESWITCH_HAIRPIN_TOT_BUFFER_SIZE Array[0..7]
PF_BAR2_SIZE 0
PF_NUM_OF_VF_VALID False(0)
NON_PREFETCHABLE_PF_BAR False(0)
VF_VPD_ENABLE False(0)
PF_NUM_PF_MSIX_VALID False(0)
PER_PF_NUM_SF False(0)
STRICT_VF_MSIX_NUM False(0)
VF_NODNIC_ENABLE False(0)
NUM_PF_MSIX_VALID True(1)
NUM_OF_VFS 8
NUM_OF_PF 2
PF_BAR2_ENABLE False(0)
SRIOV_EN True(1)
PF_LOG_BAR_SIZE 5
VF_LOG_BAR_SIZE 0
NUM_PF_MSIX 63
NUM_VF_MSIX 11
INT_LOG_MAX_PAYLOAD_SIZE AUTOMATIC(0)
PCIE_CREDIT_TOKEN_TIMEOUT 0
ACCURATE_TX_SCHEDULER False(0)
PARTIAL_RESET_EN False(0)
SW_RECOVERY_ON_ERRORS False(0)
RESET_WITH_HOST_ON_ERRORS False(0)
ADVANCED_POWER_SETTINGS False(0)
CQE_COMPRESSION BALANCED(0)
IP_OVER_VXLAN_EN False(0)
MKEY_BY_NAME False(0)
ESWITCH_IPV4_TTL_MODIFY_ENABLE False(0)
PRIO_TAG_REQUIRED_EN False(0)
UCTX_EN True(1)
PCI_ATOMIC_MODE PCI_ATOMIC_DISABLED_EXT_ATOMIC_ENABLED(0)
TUNNEL_ECN_COPY_DISABLE False(0)
LRO_LOG_TIMEOUT0 6
LRO_LOG_TIMEOUT1 7
LRO_LOG_TIMEOUT2 8
LRO_LOG_TIMEOUT3 13
LOG_TX_PSN_WINDOW 7
LOG_MAX_OUTSTANDING_WQE 7
ROCE_ADAPTIVE_ROUTING_EN False(0)
TUNNEL_IP_PROTO_ENTROPY_DISABLE False(0)
ICM_CACHE_MODE DEVICE_DEFAULT(0)
TX_SCHEDULER_BURST 0
ZERO_TOUCH_TUNING_ENABLE False(0)
LOG_MAX_QUEUE 17
LOG_DCR_HASH_TABLE_SIZE 11
MAX_PACKET_LIFETIME 0
DCR_LIFO_SIZE 16384
LINK_TYPE_P1 ETH(2)
LINK_TYPE_P2 ETH(2)
ROCE_CC_PRIO_MASK_P1 255
ROCE_CC_PRIO_MASK_P2 255
CLAMP_TGT_RATE_AFTER_TIME_INC_P1 True(1)
CLAMP_TGT_RATE_P1 False(0)
RPG_TIME_RESET_P1 300
RPG_BYTE_RESET_P1 32767
RPG_THRESHOLD_P1 1
RPG_MAX_RATE_P1 0
RPG_AI_RATE_P1 5
RPG_HAI_RATE_P1 50
RPG_GD_P1 11
RPG_MIN_DEC_FAC_P1 50
RPG_MIN_RATE_P1 1
RATE_TO_SET_ON_FIRST_CNP_P1 0
DCE_TCP_G_P1 1019
DCE_TCP_RTT_P1 1
RATE_REDUCE_MONITOR_PERIOD_P1 4
INITIAL_ALPHA_VALUE_P1 1023
MIN_TIME_BETWEEN_CNPS_P1 4
CNP_802P_PRIO_P1 6
CNP_DSCP_P1 48
CLAMP_TGT_RATE_AFTER_TIME_INC_P2 True(1)
CLAMP_TGT_RATE_P2 False(0)
RPG_TIME_RESET_P2 300
RPG_BYTE_RESET_P2 32767
RPG_THRESHOLD_P2 1
RPG_MAX_RATE_P2 0
RPG_AI_RATE_P2 5
RPG_HAI_RATE_P2 50
RPG_GD_P2 11
RPG_MIN_DEC_FAC_P2 50
RPG_MIN_RATE_P2 1
RATE_TO_SET_ON_FIRST_CNP_P2 0
DCE_TCP_G_P2 1019
DCE_TCP_RTT_P2 1
RATE_REDUCE_MONITOR_PERIOD_P2 4
INITIAL_ALPHA_VALUE_P2 1023
MIN_TIME_BETWEEN_CNPS_P2 4
CNP_802P_PRIO_P2 6
CNP_DSCP_P2 48
LLDP_NB_DCBX_P1 True(1)
LLDP_NB_RX_MODE_P1 ALL(2)
LLDP_NB_TX_MODE_P1 ALL(2)
LLDP_NB_DCBX_P2 True(1)
LLDP_NB_RX_MODE_P2 ALL(2)
LLDP_NB_TX_MODE_P2 ALL(2)
ROCE_RTT_RESP_DSCP_P1 0
ROCE_RTT_RESP_DSCP_MODE_P1 DEVICE_DEFAULT(0)
ROCE_RTT_RESP_DSCP_P2 0
ROCE_RTT_RESP_DSCP_MODE_P2 DEVICE_DEFAULT(0)
DCBX_IEEE_P1 True(1)
DCBX_CEE_P1 False(0)
DCBX_WILLING_P1 True(1)
DCBX_IEEE_P2 True(1)
DCBX_CEE_P2 False(0)
DCBX_WILLING_P2 True(1)
KEEP_ETH_LINK_UP_P1 True(1)
KEEP_IB_LINK_UP_P1 False(0)
KEEP_LINK_UP_ON_BOOT_P1 False(0)
KEEP_LINK_UP_ON_STANDBY_P1 False(0)
DO_NOT_CLEAR_PORT_STATS_P1 False(0)
AUTO_POWER_SAVE_LINK_DOWN_P1 False(0)
KEEP_ETH_LINK_UP_P2 True(1)
KEEP_IB_LINK_UP_P2 False(0)
KEEP_LINK_UP_ON_BOOT_P2 False(0)
KEEP_LINK_UP_ON_STANDBY_P2 False(0)
DO_NOT_CLEAR_PORT_STATS_P2 False(0)
AUTO_POWER_SAVE_LINK_DOWN_P2 False(0)
NUM_OF_VL_P1 _4_VLs(3)
NUM_OF_TC_P1 _8_TCs(0)
NUM_OF_PFC_P1 8
VL15_BUFFER_SIZE_P1 0
QOS_TRUST_STATE_P1 TRUST_PCP(1)
NUM_OF_VL_P2 _4_VLs(3)
NUM_OF_TC_P2 _8_TCs(0)
NUM_OF_PFC_P2 8
VL15_BUFFER_SIZE_P2 0
QOS_TRUST_STATE_P2 TRUST_PCP(1)
DUP_MAC_ACTION_P1 LAST_CFG(0)
MPFS_MC_LOOPBACK_DISABLE_P1 False(0)
MPFS_UC_LOOPBACK_DISABLE_P1 False(0)
UNKNOWN_UPLINK_MAC_FLOOD_P1 False(0)
SRIOV_IB_ROUTING_MODE_P1 LID(1)
DUP_MAC_ACTION_P2 LAST_CFG(0)
MPFS_MC_LOOPBACK_DISABLE_P2 False(0)
MPFS_UC_LOOPBACK_DISABLE_P2 False(0)
UNKNOWN_UPLINK_MAC_FLOOD_P2 False(0)
SRIOV_IB_ROUTING_MODE_P2 LID(1)
PHY_AUTO_NEG_P1 DEVICE_DEFAULT(0)
PHY_RATE_MASK_OVERRIDE_P1 False(0)
PHY_FEC_OVERRIDE_P1 DEVICE_DEFAULT(0)
PHY_AUTO_NEG_P2 DEVICE_DEFAULT(0)
PHY_RATE_MASK_OVERRIDE_P2 False(0)
PHY_FEC_OVERRIDE_P2 DEVICE_DEFAULT(0)
PF_TOTAL_SF 0
PF_SF_BAR_SIZE 0
PF_NUM_PF_MSIX 63
ROCE_CONTROL ROCE_ENABLE(2)
PCI_WR_ORDERING per_mkey(0)
MULTI_PORT_VHCA_EN False(0)
PORT_OWNER True(1)
ALLOW_RD_COUNTERS True(1)
RENEG_ON_CHANGE True(1)
TRACER_ENABLE True(1)
IP_VER IPv4(0)
BOOT_UNDI_NETWORK_WAIT 0
UEFI_HII_EN True(1)
BOOT_DBG_LOG False(0)
UEFI_LOGS DISABLED(0)
BOOT_VLAN 1
LEGACY_BOOT_PROTOCOL PXE(1)
BOOT_INTERRUPT_DIS False(0)
BOOT_LACP_DIS True(1)
BOOT_VLAN_EN False(0)
BOOT_PKEY 0
P2P_ORDERING_MODE DEVICE_DEFAULT(0)
ATS_ENABLED False(0)
DYNAMIC_VF_MSIX_TABLE False(0)
EXP_ROM_UEFI_x86_ENABLE True(1)
EXP_ROM_PXE_ENABLE True(1)
ADVANCED_PCI_SETTINGS False(0)
SAFE_MODE_THRESHOLD 10
SAFE_MODE_ENABLE True(1)
We followed this guide for the switches:
https://enterprise-support.nvidia.com/s/article/qos-configuration-examples-for-cisco-nexus-5600
We also gathered the information from:
https://www.reddit.com/r/vmware/comments/ozhq6j/vsan_rdma_with_mellanox_nic/
Any idea what we may be missing or what else we can try? Everything looks like we should be able to use RDMA, yet here we are.
