Based on GPCDMA memory to memory low performance it looks like user space DMA would not allow for speeds greater than 111MB/s.
Back to the PCIe/DMA test kernel driver above. EP side usage is covered in The bandwidth of of virtual ethernet over PCIe between two xaviers is low - #19 by WayneWWW, but PC RP side (also Ubuntu 20.04) needs to be build, and there are some posts that imply it is buildable, but instructions are little unclear if not conflicting.
Building kernel/nvidia/drivers/misc/tegra-pcie-ep-mem.c is implied in Xavier AGX PCIe End-Point : access to dma_alloc_coherent return in CUDA kernel and How another CPU communicate with Xavier through PCIE? (Solved) - #8 by guo.tang.
Building kernel/nvidia/drivers/pci/endpoint/functions/pci-epf-nv-test.c implied in AGX Endpoint PCIe DMA speed - #5 by jack_lan, but it is not clear what needs to be modified.
Trying to build tegra-pci-dma-test.c from kernel_src/nvbuild.sh by first changing tegra_defconfig to include CONFIG_TEGRA_PCIE_DMA_TEST=y. Only tegra-pci-dma-test.o gets created but not .ko, and also tegra-pcie-ep-mem.o does not get created. In the kernel/nvidia/drivers/misc/Makefile there is a ifdef CONFIG_ARCH_TEGRA_19x_SOC around obj-$(CONFIG_TEGRA_PCIE_EP_MEM).
If ifdef is commented out, build breaks as follows
make[1]: Leaving directory '/home/me/kernel_src/kernel_out'
CALL /home/me/kernel_src/kernel/kernel-5.10/scripts/atomic/check-atomics.sh
CALL /home/me/kernel_src/kernel/kernel-5.10/scripts/checksyscalls.sh
CHK include/generated/compile.h
CC drivers/misc/tegra-pcie-ep-mem.o
/home/me/kernel_src/kernel/nvidia/drivers/misc/tegra-pcie-ep-mem.c: In function āinit_debugfsā:
/home/me/kernel_src/kernel/nvidia/drivers/misc/tegra-pcie-ep-mem.c:731:4: error: void value not ignored as it ought to be
731 | d = debugfs_create_x64("src", 0644, ep->debugfs,
/home/me/kernel_src/kernel/nvidia/drivers/misc/tegra-pcie-ep-mem.c:736:4: error: void value not ignored as it ought to be
736 | d = debugfs_create_x64("dst", 0644, ep->debugfs,
/home/me/kernel_src/kernel/nvidia/drivers/misc/tegra-pcie-ep-mem.c:741:4: error: void value not ignored as it ought to be
741 | d = debugfs_create_x32("size", 0644, ep->debugfs,
/home/me/kernel_src/kernel/nvidia/drivers/misc/tegra-pcie-ep-mem.c:746:4: error: void value not ignored as it ought to be
746 | d = debugfs_create_x8("channel", 0644, ep->debugfs,
make[3]: *** [/home/me/kernel_src/kernel/kernel-5.10/scripts/Makefile.build:281: drivers/misc/tegra-pcie-ep-mem.o] Error 1
make[2]: *** [/home/me/kernel_src/kernel/kernel-5.10/scripts/Makefile.build:498: drivers/misc] Error 2
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [/home/me/kernel_src/kernel/kernel-5.10/Makefile:1854: drivers] Error 2
make: *** [Makefile:213: __sub-make] Error 2
If kernel/nvidia/drivers/misc/Makefile is changed to
obj-m +=tegra-pcie-dma-test.o
all:
make -C /lib/modules/$(shell uname -r)/build M=$(PWD) modules
and invoked standalone, it has following errors
CPATH=/home/me/kernel_src/kernel/nvidia/include make
make -C /lib/modules/5.4.0-126-generic/build M=/home/me/me/kernel_src/kernel/nvidia/drivers/misc modules
make[1]: warning: jobserver unavailable: using -j1. Add '+' to parent make rule.
make[1]: Entering directory '/usr/src/linux-headers-5.4.0-126-generic'
CC [M] /home/me/kernel_src/kernel/nvidia/drivers/misc/tegra-pcie-dma-test.o
Building modules, stage 2.
MODPOST 1 modules
ERROR: "tegra_pcie_edma_initialize" [/home/me/kernel_src/kernel/nvidia/drivers/misc/tegra-pcie-dma-test.ko] undefined!
ERROR: "tegra_pcie_edma_submit_xfer" [/home/me/kernel_src/kernel/nvidia/drivers/misc/tegra-pcie-dma-test.ko] undefined!
ERROR: "tegra_pcie_edma_deinit" [/home/me/kernel_src/kernel/nvidia/drivers/misc/tegra-pcie-dma-test.ko] undefined!
make[2]: *** [scripts/Makefile.modpost:94: __modpost] Error 1
make[1]: *** [Makefile:1675: modules] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-5.4.0-126-generic'
make: *** [Makefile:3: all] Error 2
If Makefile is changed to
obj-m +=tegra-pcie-ep-mem.o
all:
and invoked standalone, .ko is created, once loaded with insmod, modinfo lists it but lsmod lists as unused and donāt see anything new under /sys/kernel/debug.
Not sure which of these modules needs to be build and how to properly change make files, could you please provide some guidance?
