I am using Nvidia Nano B01 Board. I am trying to connect Murata uSD-M2 Adapter to connect Nvidia Nano SD card port on uSD interface and wifi module connected to M.2 on Murata Board.
I am using 32.6.1 LFT
Following are the dts changes in b00 dts and iin porg-p3448-common.dtsi in the below node.
sdhci@700b0400 {
compatible = “nvidia,tegra210-sdhci”;
reg = <0x00 0x700b0400 0x00 0x200>;
interrupts = <0x00 0x13 0x04>;
aux-device-name = “sdhci-tegra.2”;
iommus = <0x2b 0x1b>;
nvidia,runtime-pm-type = <0x00>;
clocks = <0x21 0x45 0x21 0xf3 0x21 0x136 0x21 0xc1>;
clock-names = “sdmmc\0pll_p\0pll_c4_out2\0sdmmc_legacy_tm”;
resets = <0x21 0x45>;
reset-names = “sdhci”;
status = “okay”;
tap-delay = <0x03>;
trim-delay = <0x03>;
mmc-ocr-mask = <0x00>;
//max-clk-limit = <0x2faf080>;
// SDR104 UHS-I 1.8 208 1,4 104 UHS-I, 104 (SD3.0)
max-clk-limit = <50000000>;
ddr-clk-limit = <0x2faf080>;
bus-width = <0x04>;
calib-3v3-offsets = <0x7d>;
calib-1v8-offsets = <0x7b7b>;
compad-vref-3v3 = <0x07>;
compad-vref-1v8 = <0x07>;
pll_source = “pll_p\0pll_c4_out2”;
keep-power-in-suspend;
ignore-pm-notify;
non-removable;
cap-mmc-highspeed;
cap-sd-highspeed;
nvidia,en-io-trim-volt;
nvidia,en-periodic-calib;
cd-inverted;
wp-inverted;
pwrdet-support;
nvidia,min-tap-delay = <0x6a>;
nvidia,max-tap-delay = <0xb9>;
pinctrl-names = “sdmmc_schmitt_enable\0sdmmc_schmitt_disable\0sdmmc_clk_schmitt_enable\0sdmmc_clk_schmitt_disable\0sdmmc_drv_code\0sdmmc_default_drv_code\0sdmmc_e_33v_enable\0sdmmc_e_33v_disable”;
pinctrl-0 = <0x88>;
pinctrl-1 = <0x89>;
pinctrl-2 = <0x8a>;
pinctrl-3 = <0x8b>;
pinctrl-4 = <0x8c>;
pinctrl-5 = <0x8d>;
pinctrl-6 = <0x8e>;
pinctrl-7 = <0x8f>;
vqmmc-supply = <0x58>;
vmmc-supply = <0x90>;
uhs-mask = <0xfd>;
id = <0x00>;
nvidia,is-sdio;
fixed-clock-freq = <0x1851960 0x1851960 0x16e3600 0x2cd29c0 0x16e3600 0x2cd29c0 0x59a5380 0xc28cb00 0x00 0x00 0x00>;
nvidia,vqmmc-always-on;
nvidia,vmmc-always-on;
only-1-8-v;
nvidia,disable-rtpm;
force-non-removable-rescan;
no-sd;
no-mmc;
built-in;
wakeup-source;
cap-sdio-irq;
linux,phandle = <0xb9>;
phandle = <0xb9>;
prod-settings {
#prod-cells = <0x03>;
prod_c_ds {
prod = <0x100 0xff0000 0x10000 0x1e0 0x0f 0x07 0x1e4 0x30077f7f 0x3000007d>;
prod_c_hs {
prod_c_sdr12 {
prod = <0x100 0xff0000 0x10000 0x1e0 0x0f 0x07 0x1e4 0x30077f7f 0x30007b7b>;
prod_c_sdr25 {
prod_c_sdr50 {
prod = <0x100 0xff0000 0x10000 0x1c0 0xe000 0x8000 0x1e0 0x0f 0x07 0x1e4 0x30077f7f 0x30007b7b>;
prod_c_sdr104 {
prod = <0x100 0xff0000 0x10000 0x1c0 0xe000 0x4000 0x1e0 0x0f 0x07 0x1e4 0x30077f7f 0x30007b7b>;
prod_c_ddr52 {
prod = <0x100 0x1fff0000 0x00 0x1e0 0x0f 0x07 0x1e4 0x30077f7f 0x30007b7b>;
prod {
prod = <0x100 0x1fff000e 0x3090028 0x1c0 0x8001fc0 0x8000040 0x1c4 0x77 0x00 0x120 0x20001 0x01 0x128 0x43000000 0x00 0x1f0 0x80000 0x80000>;
Changes in
— a/kernel-dts/porg-plugin-manager/tegra210-porg-plugin-manager.dtsi
+++ b/kernel-dts/porg-plugin-manager/tegra210-porg-plugin-manager.dtsi
@@ -215,7 +215,9 @@
override@1 {
target = <&sdhci2>;
overlay {
vqmmc-supply = <&max77620_ldo6>;
status = "okay"; -
//vqmmc-supply = <&max77620_ldo6>; -
vmmc-supply = <&max77620_ldo6>; no-sdio; no-mmc; sd-uhs-sdr104;
dmesg Log:
root@ubuntu:/home/ubuntu#
root@ubuntu:/home/ubuntu# dmesg | grep mmc
[ 4.275214] bus: ‘platform’: add driver pwrseq_emmc
[ 4.275313] bus: ‘amba’: add driver mmci-pl18x
[ 4.310976] sdhci [sdhci_setup_host()]: mmc0: Auto-CMD23 available
[ 4.311193] sdhci: =========== REGISTER DUMP (mmc0)===========
[ 4.316655] sdhci [sdhci_setup_host()]: mmc1: Auto-CMD23 available
[ 4.316860] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 4.316941] ======= mmc1: Tuning windows =======
[ 4.316952] mmc1: tuning window[0]: 0x0
[ 4.316960] mmc1: tuning window[1]: 0x0
[ 4.316968] mmc1: tuning window[2]: 0x0
[ 4.316976] mmc1: tuning window[3]: 0x0
[ 4.316983] mmc1: tuning window[4]: 0x0
[ 4.316991] mmc1: tuning window[5]: 0x0
[ 4.316999] mmc1: tuning window[6]: 0x0
[ 4.317007] mmc1: tuning window[7]: 0x0
[ 4.317067] device: ‘mmc1::’: device_add
[ 4.317103] PM: Adding info for No Bus:mmc1::
[ 4.317119] device: ‘mmc1’: device_add
[ 4.317146] PM: Adding info for No Bus:mmc1
[ 4.317177] mmc1: clock 400000Hz busmode 2 powermode 1 cs 0 Vdd 21 width 1 timing 0
[ 4.318537] bus: ‘mmc’: add driver mmcblk
[ 4.318615] sdhci-tegra sdhci-tegra.0: mmc_regulator_set_vqmmc: found vmmc voltage range of 3300000-3400000uV
[ 4.343593] mmc1: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 1 timing 0
[ 4.367846] mmc1: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 4.367875] mmc1: mmc_rescan_try_freq: trying to init card at 400000 Hz
[ 4.367880] mmc1: clock 400000Hz busmode 2 powermode 2 cs 1 Vdd 21 width 1 timing 0
[ 4.368965] mmc1: starting CMD0 arg 00000000 flags 000000c0
[ 4.369156] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00000001
[ 4.369173] mmc1: req done (CMD0): 0: 00000000 00000000 00000000 00000000
[ 4.370241] mmc1: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 1 timing 0
[ 4.371334] mmc1: starting CMD8 arg 000001aa flags 000002f5
[ 4.371647] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.371650] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.371692] mmc1: req done (CMD8): -84: 00000000 00000000 00000000 00000000
[ 4.371754] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 4.372061] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.372062] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.372105] mmc1: req done (CMD55): -84: 00000000 00000000 00000000 00000000
[ 4.372168] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 4.372477] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.372479] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.372520] mmc1: req done (CMD55): -84: 00000000 00000000 00000000 00000000
[ 4.372586] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 4.372895] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.372896] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.372939] mmc1: req done (CMD55): -84: 00000000 00000000 00000000 00000000
[ 4.372946] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 4.373427] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8001
[ 4.373428] mmc1: CMD CRC or end bit error, int mask 0xc0001
[ 4.373470] mmc1: req done (CMD55): -84: 00000000 00000000 00000000 00000000
[ 4.373479] mmc1: clock 0Hz busmode 2 powermode 0 cs 0 Vdd 0 width 1 timing 0
[ 4.374697] mmc1: mmc_rescan_try_freq: trying to init card at 300000 Hz
[ 4.374700] mmc1: clock 300000Hz busmode 2 powermode 1 cs 0 Vdd 21 width 1 timing 0
[ 4.376202] sdhci-tegra sdhci-tegra.0: mmc_regulator_set_vqmmc: found vmmc voltage range of 3300000-3400000uV
[ 4.400815] mmc1: clock 300000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 1 timing 0
[ 4.424020] mmc1: clock 300000Hz busmode 2 powermode 2 cs 1 Vdd 21 width 1 timing 0
[ 4.425108] mmc1: starting CMD0 arg 00000000 flags 000000c0
[ 4.425368] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00000001
[ 4.425385] mmc1: req done (CMD0): 0: 00000000 00000000 00000000 00000000
[ 4.426573] mmc1: clock 300000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 1 timing 0
[ 4.427654] mmc1: starting CMD8 arg 000001aa flags 000002f5
[ 4.428096] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.428098] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.428165] mmc1: req done (CMD8): -84: 00000000 00000000 00000000 00000000
[ 4.428184] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 4.428619] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.428621] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.428676] mmc1: req done (CMD55): -84: 00000000 00000000 00000000 00000000
[ 4.428835] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 4.429272] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.429274] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.429325] mmc1: req done (CMD55): -84: 00000000 00000000 00000000 00000000
[ 4.429838] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 4.430277] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.430279] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.430331] mmc1: req done (CMD55): -84: 00000000 00000000 00000000 00000000
[ 4.430340] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 4.430777] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.430779] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.430833] mmc1: req done (CMD55): -84: 00000000 00000000 00000000 00000000
[ 4.430845] mmc1: clock 0Hz busmode 2 powermode 0 cs 0 Vdd 0 width 1 timing 0
[ 4.432021] mmc1: mmc_rescan_try_freq: trying to init card at 200000 Hz
[ 4.432025] mmc1: clock 200000Hz busmode 2 powermode 1 cs 0 Vdd 21 width 1 timing 0
[ 4.434493] sdhci-tegra sdhci-tegra.0: mmc_regulator_set_vqmmc: found vmmc voltage range of 3300000-3400000uV
[ 4.455625] mmc1: clock 200000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 1 timing 0
[ 4.475633] mmc1: clock 200000Hz busmode 2 powermode 2 cs 1 Vdd 21 width 1 timing 0
[ 4.476719] mmc1: starting CMD0 arg 00000000 flags 000000c0
[ 4.477047] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00000001
[ 4.477063] mmc1: req done (CMD0): 0: 00000000 00000000 00000000 00000000
[ 4.478120] mmc1: clock 200000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 1 timing 0
[ 4.479200] mmc1: starting CMD8 arg 000001aa flags 000002f5
[ 4.479774] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.479776] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.479841] mmc1: req done (CMD8): -84: 00000000 00000000 00000000 00000000
[ 4.479899] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 4.480471] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.480473] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.480536] mmc1: req done (CMD55): -84: 00000000 00000000 00000000 00000000
[ 4.480590] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 4.481162] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.481163] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.481226] mmc1: req done (CMD55): -84: 00000000 00000000 00000000 00000000
[ 4.481233] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 4.481802] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.481803] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.481866] mmc1: req done (CMD55): -84: 00000000 00000000 00000000 00000000
[ 4.481873] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 4.482442] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.482443] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.482506] mmc1: req done (CMD55): -84: 00000000 00000000 00000000 00000000
[ 4.482514] mmc1: clock 0Hz busmode 2 powermode 0 cs 0 Vdd 0 width 1 timing 0
[ 4.483688] mmc1: mmc_rescan_try_freq: trying to init card at 100000 Hz
[ 4.483691] mmc1: clock 100000Hz busmode 2 powermode 1 cs 0 Vdd 21 width 1 timing 0
[ 4.486167] sdhci-tegra sdhci-tegra.0: mmc_regulator_set_vqmmc: found vmmc voltage range of 3300000-3400000uV
[ 4.511622] mmc1: clock 100000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 1 timing 0
[ 4.535619] mmc1: clock 100000Hz busmode 2 powermode 2 cs 1 Vdd 21 width 1 timing 0
[ 4.536701] mmc1: starting CMD0 arg 00000000 flags 000000c0
[ 4.537323] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00000001
[ 4.537338] mmc1: req done (CMD0): 0: 00000000 00000000 00000000 00000000
[ 4.538398] mmc1: clock 100000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 1 timing 0
[ 4.539478] mmc1: starting CMD8 arg 000001aa flags 000002f5
[ 4.540589] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.540591] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.540701] mmc1: req done (CMD8): -84: 00000000 00000000 00000000 00000000
[ 4.540762] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 4.541865] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.541867] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.541970] mmc1: req done (CMD55): -84: 00000000 00000000 00000000 00000000
[ 4.542027] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 4.543135] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.543136] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.543239] mmc1: req done (CMD55): -84: 00000000 00000000 00000000 00000000
[ 4.543297] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 4.544409] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.544411] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.544520] mmc1: req done (CMD55): -84: 00000000 00000000 00000000 00000000
[ 4.544581] mmc1: starting CMD55 arg 00000000 flags 000000f5
[ 4.545685] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x000c8000
[ 4.545686] mmc1: CMD CRC or end bit error, int mask 0xc0000
[ 4.545789] mmc1: req done (CMD55): -84: 00000000 00000000 00000000 00000000
[ 4.545849] mmc1: clock 0Hz busmode 2 powermode 0 cs 0 Vdd 0 width 1 timing 0
[ 4.990459] ======= mmc0: Tuning windows =======
[ 4.990471] mmc0: tuning window[0]: 0x0
[ 4.990479] mmc0: tuning window[1]: 0x0
[ 4.990487] mmc0: tuning window[2]: 0x0
[ 4.990495] mmc0: tuning window[3]: 0x0
[ 4.990503] mmc0: tuning window[4]: 0x0
[ 4.990511] mmc0: tuning window[5]: 0x0
[ 4.990519] mmc0: tuning window[6]: 0x0
[ 4.990527] mmc0: tuning window[7]: 0x0
[ 4.990592] device: ‘mmc0::’: device_add
[ 4.990644] PM: Adding info for No Bus:mmc0::
[ 4.990665] device: ‘mmc0’: device_add
[ 4.990695] PM: Adding info for No Bus:mmc0
[ 4.990732] mmc0: clock 400000Hz busmode 2 powermode 1 cs 0 Vdd 21 width 1 timing 0
[ 4.992169] sdhci-tegra sdhci-tegra.2: mmc_regulator_set_vqmmc: found vmmc voltage range of 3300000-3400000uV
[ 5.019630] mmc0: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 1 timing 0
[ 5.039858] mmc0: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA 64-bit with 64 bit addr
[ 5.039884] mmc0: clock 0Hz busmode 2 powermode 0 cs 0 Vdd 0 width 1 timing 0
root@ubuntu:/home/ubuntu# dmesg | grep sd
[ 4.318376] bus: ‘platform’: really_probe: bound device sdhci-tegra.0 to driver sdhci-tegra
[ 4.324165] sdhci-tegra sdhci-tegra.0: tegra_sdhci_signal_voltage_switch_post: error -19 in comp drvup settings at 3.3v
[ 4.324168] sdhci-tegra sdhci-tegra.0: Initial signal voltage of 3.3v
[ 4.374705] sdhci-tegra sdhci-tegra.0: Setting clk limit 300000
[ 4.374708] sdhci-tegra sdhci-tegra.0: Enabling clk 300000, clk enabled 1
[ 4.374714] sdhci-tegra sdhci-tegra.0: chosen clk parent pll_p, parent rate 408000000
[ 4.374725] sdhci-tegra sdhci-tegra.0: req clk 300000, set clk 3175098
[ 4.381755] sdhci-tegra sdhci-tegra.0: tegra_sdhci_signal_voltage_switch_post: error -19 in comp drvup settings at 3.3v
[ 4.381757] sdhci-tegra sdhci-tegra.0: Initial signal voltage of 3.3v
[ 4.432029] sdhci-tegra sdhci-tegra.0: Setting clk limit 200000
[ 4.432032] sdhci-tegra sdhci-tegra.0: Enabling clk 200000, clk enabled 1
[ 4.432038] sdhci-tegra sdhci-tegra.0: chosen clk parent pll_p, parent rate 408000000
[ 4.432063] sdhci-tegra sdhci-tegra.0: req clk 200000, set clk 3175098
[ 4.439585] sdhci-tegra sdhci-tegra.0: tegra_sdhci_signal_voltage_switch_post: error -19 in comp drvup settings at 3.3v
[ 4.439588] sdhci-tegra sdhci-tegra.0: Initial signal voltage of 3.3v
[ 4.483695] sdhci-tegra sdhci-tegra.0: Setting clk limit 100000
[ 4.483698] sdhci-tegra sdhci-tegra.0: Enabling clk 100000, clk enabled 1
[ 4.483704] sdhci-tegra sdhci-tegra.0: chosen clk parent pll_p, parent rate 408000000
[ 4.483735] sdhci-tegra sdhci-tegra.0: req clk 100000, set clk 3175098
[ 4.491642] sdhci-tegra sdhci-tegra.0: tegra_sdhci_signal_voltage_switch_post: error -19 in comp drvup settings at 3.3v
[ 4.491645] sdhci-tegra sdhci-tegra.0: Initial signal voltage of 3.3v
[ 4.559626] sdhci-tegra sdhci-tegra.0: Setting clk limit 0
[ 4.559629] sdhci-tegra sdhci-tegra.0: Disabling clk 0, clk enabled 1
[ 4.990383] sdhci: Sys addr: 0x00000000 | Version: 0x00000303
[ 4.990389] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 4.990396] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 4.990402] sdhci: Present: 0x01fb00f0 | Host ctl: 0x00000000
[ 4.990408] sdhci: Power: 0x00000000 | Blk gap: 0x00000000
[ 4.990414] sdhci: Wake-up: 0x00000000 | Clock: 0x00000000
[ 4.990420] sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 4.990426] sdhci: Int enab: 0x00ff1003 | Sig enab: 0x00fc1003
[ 4.990432] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 4.990438] sdhci: Caps: 0x376cd08c | Caps_1: 0x10006f77
[ 4.990444] sdhci: Cmd: 0x00000000 | Max curr: 0x00000000
[ 4.990447] sdhci: Host ctl2: 0x00003000
[ 4.990456] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 4.990532] sdhci: Tap value: 9 | Trim value: 3
[ 4.990584] sdhci: ===========================================
[ 4.990736] sdhci-tegra sdhci-tegra.2: Setting clk limit 400000
[ 4.990739] sdhci-tegra sdhci-tegra.2: Enabling clk 400000, clk enabled 1
[ 4.990742] sdhci-tegra sdhci-tegra.2: req clk 400000, set clk 3175098
[ 5.001848] sdhci-tegra sdhci-tegra.2: tegra_sdhci_signal_voltage_switch_post: error -19 in comp drvup settings at 3.3v
[ 5.001851] sdhci-tegra sdhci-tegra.2: Initial signal voltage of 3.3v
[ 5.059615] sdhci-tegra sdhci-tegra.2: Setting clk limit 0
[ 5.059619] sdhci-tegra sdhci-tegra.2: Disabling clk 0, clk enabled 1
[ 5.113075] Root device found: sda1
[ 5.128552] bus: ‘scsi’: driver_probe_device: matched device 0:0:0:0 with driver sd
[ 5.128556] bus: ‘scsi’: really_probe: probing driver sd with device 0:0:0:0
[ 5.128609] sd 0:0:0:0: no default pinctrl state
[ 5.128703] driver: ‘sd’: driver_bound: bound to device ‘0:0:0:0’
[ 5.128708] bus: ‘scsi’: really_probe: bound device 0:0:0:0 to driver sd
[ 5.129279] sd 0:0:0:0: [sda] 120176640 512-byte logical blocks: (61.5 GB/57.3 GiB)
[ 5.138276] sd 0:0:0:0: [sda] Write Protect is off
[ 5.143073] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 5.143543] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 5.152754] device: ‘sda’: device_add
[ 5.152802] PM: Adding info for No Bus:sda
[ 5.165629] sda: sda1
[ 5.168010] device: ‘sda1’: device_add
[ 5.168055] PM: Adding info for No Bus:sda1
[ 5.169686] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 5.321542] Found dev node: /dev/sda1
[ 6.278117] EXT4-fs (sda1): recovery complete
[ 6.283324] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.292935] Rootfs mounted over sda1
[ 6.983805] cgroup: cgroup2: unknown option “nsdelegate”
[ 7.973148] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 35.967770] vdd-3v3-sd: disabling
[ 69.630656] EXT4-fs (sda1): resizing filesystem from 7812352 to 15021568 blocks
[ 69.630661] EXT4-fs (sda1): Converting file system to meta_bg
[ 69.684725] EXT4-fs (sda1): resized filesystem to 15021568
