Enabling tiled-display causes segmentation fault on Jetson Orin Nano running sample DS application
Board: Jetson Orin Nano DevKit 8GB
Deepstream: 6.4
Jetpack: 6.1
Docker image: nvcr.io/nvidia/deepstream-l4t:6.4-triton-multiarch
I have a setup as above and I am trying to run deepstream-app sample config from the above docker image.
deepstream-app -c source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
However I am met with segmentation fault
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
      To go back to the tiled display, right-click anywhere on the window.
**PERF:  FPS 0 (Avg)	FPS 1 (Avg)	FPS 2 (Avg)	FPS 3 (Avg)
**PERF:  0.00 (0.00)	0.00 (0.00)	0.00 (0.00)	0.00 (0.00)
** INFO: <bus_callback:301>: Pipeline ready
WARNING from src_elem: No decoder available for type 'audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)119056e500, rate=(int)48000, channels=(int)2'.
Debug info: ../gst/playback/gsturidecodebin.c(960): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstURIDecodeBin:src_elem
Debug info: ../gst/playback/gsturidecodebin.c(960): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin2/GstURIDecodeBin:src_elem
Debug info: ../gst/playback/gsturidecodebin.c(960): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem
Debug info: ../gst/playback/gsturidecodebin.c(960): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstURIDecodeBin:src_elem
/bin/dash: 1: lsmod: not found
/bin/dash: 1: modprobe: not found
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:287>: Pipeline running
If I disable tiled-display in the config, I can run the app successfully with EGL display.
Here are the steps to reproduce.
  1. Get into docker environment
DOCKER_IMG="nvcr.io/nvidia/deepstream-l4t:6.4-triton-multiarch"
MNT_PROJECT_DIR="-v $PWD:/home/work"
FWD_DISPLAY="-e DISPLAY -v /tmp/.X11-unix:/tmp/.X11-unix"
ENV_PLATFORM="JETSON"
xhost +si:localuser:root
docker run -it --rm --runtime nvidia -e PLATFORM=$ENV_PLATFORM \
    --network host \
    $FWD_DISPLAY \
    $MNT_PROJECT_DIR \
    $DOCKER_IMG \
    bash
  1. Inside the docker environment, fix Glib issues, which was mentioned on the release notes of Deepstream 6.4.
apt-get update && apt-get install -y --no-install-recommends python3-dev meson ninja-build libxslt1-dev libpcre2-dev
curl -LO https://download.gnome.org/sources/glib/2.76/glib-2.76.6.tar.xz && \
    tar -xvf glib-2.76.6.tar.xz && \
    cd glib-2.76.6 && \
    meson _build --prefix=/usr --buildtype=release && \
    ninja -C _build && \
    ninja -C _build install && \
    cd .. && rm -rf glib-2.76.6 glib-2.76.6.tar.xz
  1. cd to deepstream config path and run
If you are using Jetpack 6.1, please install the DeepStream 7.1. You can refer to our Jetson model Platform and OS Compatibility. If the compatibility do not match, there maybe some exceptions.
I downgraded to Jetpack 5.1.2 and Deepstream 6.3 as per the compatibility requirements and it works fine now.
