Deepstream runtime_source_add_delete.py application segmentation fault(core dumped)
Jetson Xavier Nx
• DeepStream Version
Deepstream 6.1.1
5.0.1 [rev. 1]
• TensorRT Version
8.4
bugs
The issue is that runtime_source_add_delete.py python application throws the segmentation fault(core dumped) error. So in order to reproduce this issue simply comment out loop.quit() at line number 222. Reason behind this is that application should keep on running after all sources are removed, so that we can add stream again later without closing the application. This sample was previously working with Deepstream 6.0, But after update to Deepstream 6.1.1. Its not working anymore and one more thing you can perform same thing on Ubuntu (x86_64) with Deepstream 6.1.1 there will no issue application will keep on running without any error or issue.
1.Could you attach your log here?
2.Deepstream 6.2 GA is available. Could you try it with DS6.2. https://developer.nvidia.com/deepstream-getting-started
LOGS:
python3 deepstream_rt_src_add_del.py file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4
Creating Pipeline
Creating streammux
Creating source_bin 0
Creating uridecodebin for [file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4]
source-bin-00
Creating Pgie
Creating nvtracker
Creating tiler
Creating nvvidconv
Creating nvosd
Creating nv3dsink
Adding elements to Pipeline
Linking elements in the Pipeline
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
[NvMultiObjectTracker] Initialized
0:00:00.593460196 8330 0x38dab300 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1170> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
WARNING: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.1/samples/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine open error
0:00:04.252584330 8330 0x38dab300 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1897> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.1/samples/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed
0:00:04.303537718 8330 0x38dab300 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.1/samples/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed, try rebuild
0:00:04.303633239 8330 0x38dab300 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
0:01:31.203268785 8330 0x38dab300 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1955> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-6.1/samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine successfully
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:01:31.290661373 8330 0x38dab300 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus: [UID 1]: Load new model:dstest_pgie_config.txt sucessfully
Decodebin child added: source
Decodebin child added: decodebin0
Now playing…
1 : file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4
Starting pipeline
Decodebin child added: qtdemux0
Decodebin child added: multiqueue0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: aacparse0
Decodebin child added: avdec_aac0
Decodebin child added: nvv4l2decoder0
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
In cb_newpad
gstname= video/x-raw
sink_0
Decodebin linked to pipeline
In cb_newpad
gstname= audio/x-raw
Calling Start 2
source-bin-02
Decodebin child added: decodebin1
Decodebin child added: qtdemux1
Decodebin child added: multiqueue1
Decodebin child added: h264parse1
Decodebin child added: capsfilter1
Decodebin child added: aacparse1
Decodebin child added: avdec_aac1
Decodebin child added: nvv4l2decoder1
In cb_newpad
sink_2
In cb_newpad
Calling Start 3
source-bin-03
Decodebin child added: decodebin2
Decodebin child added: qtdemux2
Decodebin child added: multiqueue2
Decodebin child added: h264parse2
Decodebin child added: capsfilter2
Decodebin child added: aacparse2
Decodebin child added: avdec_aac2
Decodebin child added: nvv4l2decoder2
In cb_newpad
sink_3
In cb_newpad
Calling Start 1
source-bin-01
Decodebin child added: decodebin3
Decodebin child added: qtdemux3
Decodebin child added: multiqueue3
Decodebin child added: h264parse3
Decodebin child added: capsfilter3
Decodebin child added: aacparse3
Decodebin child added: avdec_aac3
Decodebin child added: nvv4l2decoder3
In cb_newpad
sink_1
In cb_newpad
Calling Stop 1
STATE CHANGE SUCCESS
sink_1
Calling Stop 2
sink_2
Calling Stop 3
sink_3
Calling Stop 0
sink_0
Segmentation fault (core dumped) is happening at
streammux.release_request_pad(sinkpad) [line number 169 ]
I also tested this on Deepstream 6.2. It still causes the same error. [segmentation fault(core dumped)]
OK, we can repro this problem in our env. We’ll check it.
