IMX728 (3840x2160, raw10, 4 lanes DPHY) → MAX96717 (GMSL2 serializer) → MAX96712 (deserializer)
My log:
nv@nv:~$ sudo nvsipl_camera -c R0SIM728S3RU2120NB2 -t transport_settings_orin.json -m “0x0001” -s -v 4 -H
Platform configuration name: R0SIM728S3RU2120NB2
Platform configuration file: transport_settings_orin.json
Verbosity level: 4
Raw output: disabled
ISP0 output: enabled
ISP1 output: enabled
ISP2 output: enabled
Enabled FPS logging
Disabled Metadata logging
Disabled automatic recovery
Disabled profiling
Disabled ISP Statistics settings override
Subframe : enabled
Disabled Passive mode
Camera HAL path: enabled
Disabled retrieving/displaying NITO Metadata
nvsipl_camera: Setting up signal handler
libnvsipl_query.so: CNvMCameraQuery.cpp : 1414: ParseJsonFile: CNvMCameraQuery::ParseJsonFile reading file transport_settings_orin.json
libnvsipl_query.so: CNvMCameraQuery.cpp : 453: ParseCameraConfigs: ParseCameraConfigs: Processing module: R0SIM728S3RU2120NB2
libnvsipl_query.so: CNvMCameraConfigInfo.cpp : 79: ParseJson: Parsing camera config: name=R0SIM728S3RU2120NB2 type=GMSL
libnvsipl_query.so: CNvMCameraConfigInfo.cpp : 197: ParseJson: R0SIM728S3RU2120NB2: mipiSettings parsed: phyMode=0 dphyRate=1500000 cphyRate=0 lanes=4
libnvsipl_query.so: CNvMCameraConfigInfo.cpp : 694: ParseGMSLConfig: No linkIndex specified, defaulting to 0
libnvsipl_query.so: CNvMCameraConfigInfo.cpp : 712: ParseGMSLConfig: Parsed linkMode: LINK_MODE_GMSL2_6GBPS
libnvsipl_query.so: CNvMCameraConfigInfo.cpp : 725: ParseGMSLConfig: Parsed fsyncMode: osc_manual
libnvsipl_query.so: CNvMCameraConfigInfo.cpp : 742: ParseGMSLConfig: R0SIM728S3RU2120NB2: serializer name=MAX96717
libnvsipl_query.so: CNvMSerInfo.cpp : 71: ParseJson: Parsed MAX96717
libnvsipl_query.so: CNvMCameraConfigInfo.cpp : 814: ParseGMSLConfig: Parsing 1 GMSL sensors from ‘sensorInfo’ array
libnvsipl_query.so: CNvMCameraConfigInfo.cpp : 833: ParseGMSLConfig: Parsed GMSL sensor[0]: R0SIM728S3RU2120NB2 with 1 virtual channels
libnvsipl_query.so: CNvMCameraConfigInfo.cpp : 842: ParseGMSLConfig: Parsed GMSL module with 1 sensors
libnvsipl_query.so: CNvMCameraConfigInfo.cpp : 855: ParseGMSLConfig: R0SIM728S3RU2120NB2: GMSL config complete: phyMode=0 dphyRate=1500000 cphyRate=0 mipiClockRate=1500000
libnvsipl_query.so: CNvMCameraQuery.cpp : 1498: ParseJsonFile: Parsing unified platformTransportSettings format
libnvsipl_query.so: CNvMCameraQuery.cpp : 967: ParsePlatformTransportSettings: ParsePlatformTransportSettings: Parsing 1 platform entries
libnvsipl_query.so: CNvMCameraQuery.cpp : 1006: ParsePlatformTransportSettings: ParsePlatformTransportSettings: Platform ‘jetson-orin’ using driver suffix ‘NativeGpio’
libnvsipl_query.so: CNvMCameraQuery.cpp : 670: ParseTransportSettings: Parsing deserializer info for ‘Max96712GmslDeserializer’ in GMSL transport ‘transportSettings_jetson-orin_A’
libnvsipl_query.so: CNvMDeserInfo.cpp : 111: ParseJson: Parsed Max96712GmslDeserializer
libnvsipl_query.so: CNvMCameraQuery.cpp : 1020: ParsePlatformTransportSettings: ParsePlatformTransportSettings: Platform ‘jetson-orin’ has 1 transports, 1 enable masks
libnvsipl_query.so: CNvMCameraQuery.cpp : 1032: ParsePlatformTransportSettings: ParsePlatformTransportSettings: Total platforms parsed: 1
libnvsipl_query.so: CNvMCameraQuery.cpp : 876: GetPlatformIndex: Platform detected: ‘jetson-orin’ (board prefix ‘NVIDIA Jetson AGX Orin’)
libnvsipl_query.so: CNvMCameraQuery.cpp : 1509: ParseJsonFile: Selected platform: jetson-orin (index=0)
libnvsipl_query.so: CNvMCameraQuery.cpp : 1554: ParseJsonFile: ParseJsonFile: Associated 1 transports with 1 GMSL camera configs
libnvsipl_query.so: CNvMCameraQuery.cpp : 1558: ParseJsonFile: ParseJsonFile: Complete - cameras=1, transports=1
libnvsipl_query.so: CNvMCameraQuery.cpp : 1609: GetSensorSystemConfig: GetCameraSystemConfig: Looking up ‘R0SIM728S3RU2120NB2’
libnvsipl_query.so: CNvMCameraQuery.cpp : 1631: GetSensorSystemConfig: GetCameraSystemConfig: R0SIM728S3RU2120NB2 mipiSettings: phyMode=0 dphyRate=1500000 cphyRate=0 mipiClockRate=1500000
libnvsipl_query.so: CNvMCameraQuery.cpp : 1794: GetSensorSystemConfig: GetCameraSystemConfig: Using module-specific transports for ‘R0SIM728S3RU2120NB2’ (1 transports)
libnvsipl_query.so: CNvMCameraQuery.cpp : 1811: GetSensorSystemConfig: Processing transport: transportSettings_jetson-orin_A, transportIndex=0, csiPort=2
libnvsipl_query.so: CNvMCameraQuery.cpp : 1828: GetSensorSystemConfig: Sensor: id=0, deviceIndex=0
libnvsipl_query.so: CNvMCameraQuery.cpp : 1844: GetSensorSystemConfig: Created module instance: linkIndex=0, csiPort=2
libnvsipl_query.so: CNvMCameraQuery.cpp : 1828: GetSensorSystemConfig: Sensor: id=1, deviceIndex=0
libnvsipl_query.so: CNvMCameraQuery.cpp : 1844: GetSensorSystemConfig: Created module instance: linkIndex=1, csiPort=2
libnvsipl_query.so: CNvMCameraQuery.cpp : 1828: GetSensorSystemConfig: Sensor: id=2, deviceIndex=0
libnvsipl_query.so: CNvMCameraQuery.cpp : 1844: GetSensorSystemConfig: Created module instance: linkIndex=2, csiPort=2
libnvsipl_query.so: CNvMCameraQuery.cpp : 1828: GetSensorSystemConfig: Sensor: id=3, deviceIndex=0
libnvsipl_query.so: CNvMCameraQuery.cpp : 1844: GetSensorSystemConfig: Created module instance: linkIndex=3, csiPort=2
libnvsipl_query.so: CNvMCameraQuery.cpp : 1855: GetSensorSystemConfig: Built sensor system config: 4 modules, 1 transports
nvsipl_camera: Setting link masks
libnvsipl_query.so: CNvMCameraQuery.cpp : 1866: ApplyMask: ApplyMask: Starting with 4 modules, 1 transports
libnvsipl_query.so: CNvMCameraQuery.cpp : 1881: ApplyMask: ApplyMask: Using user-provided masks (1 masks)
libnvsipl_query.so: CNvMCameraQuery.cpp : 1899: ApplyMask: Transport[0]: csiPort=2
libnvsipl_query.so: CNvMCameraQuery.cpp : 1940: ApplyMask: Mask check: module=R0SIM728S3RU2120NB2, linkIndex=0, transportIdx=0, linkMask=0x1, enabled=1
libnvsipl_query.so: CNvMCameraQuery.cpp : 1945: ApplyMask: Enabled module: R0SIM728S3RU2120NB2, csiPort=2, transportIdx=0, linkIndex=0
libnvsipl_query.so: CNvMCameraQuery.cpp : 1940: ApplyMask: Mask check: module=R0SIM728S3RU2120NB2, linkIndex=1, transportIdx=0, linkMask=0x1, enabled=0
libnvsipl_query.so: CNvMCameraQuery.cpp : 1940: ApplyMask: Mask check: module=R0SIM728S3RU2120NB2, linkIndex=2, transportIdx=0, linkMask=0x1, enabled=0
libnvsipl_query.so: CNvMCameraQuery.cpp : 1940: ApplyMask: Mask check: module=R0SIM728S3RU2120NB2, linkIndex=3, transportIdx=0, linkMask=0x1, enabled=0
libnvsipl_query.so: CNvMCameraQuery.cpp : 2003: ApplyMask: ApplyMask: Filtered to 1 modules based on mask
nvsipl_camera: Creating camera master
nvsipl_camera: Setting up master
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 159: GetInstance: Entering
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 174: GetInstance: Exiting
nvsipl_camera: Creating consumers
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/deserializers/MAX967XX/MAX967XX.cpp, ConfigureDriver(), ConfigureDriver called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/deserializers/MAX967XX/MAX967XX.cpp, SetMipiOutputMode(), MIPI output mode set to 2x4 (4-lane)
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 1083: SetPipelineCfg: Entering for pipeline[0][0]
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 1300: SetPipelineCfg: Exiting for pipeline[0][0]
nvsipl_camera: Creating consumer for output:1 of sensor:0
nvsipl_camera: Profiler initialization for output:1 of sensor:0
nvsipl_camera: Consumer initialization for output:1 of sensor:0
nvsipl_camera: Creating consumer for output:2 of sensor:0
nvsipl_camera: Profiler initialization for output:2 of sensor:0
nvsipl_camera: Consumer initialization for output:2 of sensor:0
nvsipl_camera: Creating consumer for output:3 of sensor:0
nvsipl_camera: Profiler initialization for output:3 of sensor:0
nvsipl_camera: Consumer initialization for output:3 of sensor:0
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 1831: GetImageAttributes: Entering for pipeline[0][0] and output type: 0
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 1890: GetImageAttributes: Exiting for pipeline: 0 and output type: 0
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 1831: GetImageAttributes: Entering for pipeline[0][0] and output type: 3441973505
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 1890: GetImageAttributes: Exiting for pipeline: 0 and output type: 1
Pipeline: 0 ISP Output: 0 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 1831: GetImageAttributes: Entering for pipeline[0][0] and output type: 2905249282
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 1890: GetImageAttributes: Exiting for pipeline: 0 and output type: 2
Pipeline: 0 ISP Output: 1 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 1831: GetImageAttributes: Entering for pipeline[0][0] and output type: 2905249283
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 1890: GetImageAttributes: Exiting for pipeline: 0 and output type: 3
Pipeline: 0 ISP Output: 2 is using RGBA PACKED FLOAT16 PL SENSOR_RGBA
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 4646: FillNvSciSyncAttrList: Entering for pipeline[0][0] output type: 3441975041, and client type: 0
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 4708: FillNvSciSyncAttrList: Exiting for pipeline[0][0], output type: 3441975041, and client type: 0
nvsipl_camera: Initializing master interface
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 1712: Init: Entering
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/deserializers/MAX967XX/MAX967XX.cpp, ProbeHardware(), ProbeHardware called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/deserializers/MAX967XX/MAX967XX.cpp, Init(), Init called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/deserializers/MAX967XX/MAX967XX.cpp, SetDefault(), SetDefault called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/deserializers/MAX967XX/MAX967XX.cpp, SetI2cPort(), Configuring deserializer I2C port: 0 (SoC I2C bus: 9)
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/deserializers/MAX967XX/MAX967XX.cpp, prepareMipiPhyConfig(), Setting DPHY: rate=1500000 kHz, mipiSpeed=15 (0x0F)
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/deserializers/MAX967XX/MAX967XX.cpp, ControlLink(), ControlLink called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/serializers/MAX96717/MAX96717.cpp, SerInit(), SerInit called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/serializers/MAX96717/MAX96717.cpp, SerInit(), Setting translator: physical=0x1a, virtual=0x08
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/serializers/MAX96717/MAX96717.cpp, SerInit(), Setting translator: physical=0x54, virtual=0x09
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/deserializers/MAX967XX/MAX967XX.cpp, InitWithSerializer(), InitWithSerializer called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/deserializers/MAX967XX/MAX967XX.cpp, CheckLinkLock(), CheckLinkLock called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/deserializers/MAX967XX/MAX967XX.cpp, InitWithSerializer(), Enable raw10 double pixel mode
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/deserializers/MAX967XX/MAX967XX.cpp, ConfigureVideoPipelineMappingForLink(), Setting video pipeline mapping for link 0: txPort PHY=1, isEmbDataType=0, pipelineMapping=0x15, outputController=0x10
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/serializers/MAX96717/MAX96717.cpp, SerPrepareForModuleInit(), SerPrepareForModuleInit called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/sensors/IMX728/IMX728.cpp, ProbeHardware(), ProbeHardware called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/sensors/IMX728/IMX728.cpp, ProbeHardware(), CFA is RGGB
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/sensors/IMX728/IMX728.cpp, ProbeHardware(), Revision ID: 0x33
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/sensors/IMX728/IMX728.cpp, ProbeHardware(), Detected IMX728 revision: 7
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/sensors/IMX728/IMX728.cpp, Init(), Init called
nvsipl_camera: Queue timeout
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/sensors/IMX728/IMX728.cpp, GetSensorAttributes(), GetSensorAttributes called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/deserializers/MAX967XX/MAX967XX.cpp, FinalizeInitWithSerializer(), FinalizeInitWithSerializer called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/serializers/MAX96717/MAX96717.cpp, SerFinalizeInit(), SerFinalizeInit called
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 1743: Init: Exiting
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 4497: RegisterImages: Entering for pipeline[0][0] and output type: 2906830848
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 4545: RegisterImages: Exiting for pipeline: 0 and output type: 0
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 4497: RegisterImages: Entering for pipeline[0][0] and output type: 2906830849
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 4545: RegisterImages: Exiting for pipeline: 0 and output type: 1
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 4497: RegisterImages: Entering for pipeline[0][0] and output type: 2906830850
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 4545: RegisterImages: Exiting for pipeline: 0 and output type: 2
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 4497: RegisterImages: Entering for pipeline[0][0] and output type: 2906830851
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 4545: RegisterImages: Exiting for pipeline: 0 and output type: 3
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 4824: RegisterNvSciSyncObj: Entering for pipeline[0][0] output type: 2906797313, and sync object type: 1
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 4870: RegisterNvSciSyncObj: Exiting for pipeline[0][0], output type: 2906797313, and sync object type: 1
nvsipl_camera: Opened NITO file for module “R0SIM728S3RU2120NB2”, file name: “/var/nvidia/nvcam/settings/sipl/R0SIM728S3RU2120NB2.nito”
nvsipl_camera: data from NITO file loaded for module “R0SIM728S3RU2120NB2”
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 1514: RegisterAutoControlPlugin: Entering for pipeline[0][0] of type: 0
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/sensors/IMX728/IMX728.cpp, SetSensorControls(), SetSensorControls called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/sensors/IMX728/IMX728.cpp, SetExposure(), SetExposure called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/sensors/IMX728/IMX728.cpp, GetdBGain(), GetdBGain called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/sensors/IMX728/IMX728.cpp, SetWBGain(), SetWBGain called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/sensors/IMX728/IMX728.cpp, WriteHoldValueToRegister(), WriteHoldValueToRegister called
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 1569: RegisterAutoControlPlugin: Exiting for pipeline[0][0] of type: 0
nvsipl_camera: Starting master
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 4989: Start: Entering
nvsipl_camera: Pipeline: 0, NOTIF_INFO_CDI_PROCESSING_DONE
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/deserializers/MAX967XX/MAX967XX.cpp, StartStreaming(), StartStreaming called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/sensors/IMX728/IMX728.cpp, StartStreaming(), StartStreaming called
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 5014: Start: Exiting
Enter ‘q’ to quit the application
nvsipl_camera: ERROR: Pipeline: 0, NOTIF_ERROR_ISP_PROCESSING_FAILURE
Output
Sensor0_Out1 Frame rate (fps): 0
Sensor0_Out2 Frame rate (fps): 0
Sensor0_Out3 Frame rate (fps): 0
Sensor 0 Frame captured: 0 Frame drops: 0 Frame discontinuities: 0 Frames authenticated: 0 Frames failed to authenticate: 0 Frames authenticated as Out Of Order: 0
nvsipl_camera: [TEARDOWN_PROBE] phase_begin: 0 ms
nvsipl_camera: Stopping master
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 5066: Stop: Entering
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/sensors/IMX728/IMX728.cpp, StopStreaming(), StopStreaming called
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/deserializers/MAX967XX/MAX967XX.cpp, StopStreaming(), StopStreaming called
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 5077: Stop: Exiting
nvsipl_camera: [TEARDOWN_PROBE] upMaster->Stop: 52 ms
nvsipl_camera: [TEARDOWN_PROBE] devblkNotify->Stop: 0 ms
nvsipl_camera: [TEARDOWN_PROBE] pipelineNotify->Stop: 0 ms
nvsipl_camera: [TEARDOWN_PROBE] frameCompletionQueue->Stop: 0 ms
nvsipl_camera: [TEARDOWN_PROBE] readers->Deinit: 0 ms
nvsipl_camera: [TEARDOWN_PROBE] composite->Deinit: 0 ms
nvsipl_camera: [TEARDOWN_PROBE] devblkNotify->Deinit: 0 ms
nvsipl_camera: Deinitializing pipeline notificationHandler: 0
nvsipl_camera: [TEARDOWN_PROBE] pipelineNotify->Deinit: 986 ms
nvsipl_camera: Deinitializing frameCompletionQueueHandler: 0
nvsipl_camera: [TEARDOWN_PROBE] frameCompletionQueue->Deinit: 1730 ms
nvsipl_camera: [TEARDOWN_PROBE] eglRenderers->delete: 0 ms
nvsipl_camera: Deinitializing consumer Sensor0_Out1
nvsipl_camera: Deinitializing consumer Sensor0_Out2
nvsipl_camera: Deinitializing consumer Sensor0_Out3
nvsipl_camera: [TEARDOWN_PROBE] consumers->Deinit: 0 ms
nvsipl_camera: Deinitializing profiler Sensor0_Out1
nvsipl_camera: Deinitializing profiler Sensor0_Out2
nvsipl_camera: Deinitializing profiler Sensor0_Out3
nvsipl_camera: [TEARDOWN_PROBE] profilers->Deinit: 0 ms
nvsipl_camera: [TEARDOWN_PROBE] frameFeeder->Deinit: 0 ms
nvsipl_camera: Deinitializing master
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 5177: Deinit: Entering
/home/nv/usr/src/jetson_sipl_api/sipl/uddf/drivers/deserializers/MAX967XX/MAX967XX.cpp, Deinit(), Deinit called
Main: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/CNvMCamera.cpp: 5206: Deinit: Exiting
nvsipl_camera: [TEARDOWN_PROBE] upMaster->Deinit: 90 ms
nvsipl_camera: ERROR: Pipeline failure
And here is the kernel log:
[ 7097.454654] tegra194-vi5 13e00000.host1x:vi0@15c00000: [PIPELINE 0] VI capture setup complete (channel_id=0, csi_stream=0, vc=0)
[ 7097.457638] tegra194-isp5 14800000.isp: [PIPELINE 0] ISP capture setup complete (channel_id=1)
[ 7097.542512] [RCE] VM0 deactivatingVM0 activating===== NVCSI Stream Configuration =====
[ 7097.542542] [RCE] stream_id: PP 0, csi_port: PORT A
[ 7097.542547] [RCE] Brick: PHY 0, Mode: D-PHY
[ 7097.542551] [RCE] Partition: CIL A, LP bypass: Enabled, Lanes: 4
[ 7097.542555] [RCE] Clock information:
[ 7097.542559] [RCE] CIL rate: 408000000 Hz
[ 7097.542563] [RCE] MIPI clock rate: 750000 kHz
[ 7097.542567] [RCE] Physical rate: 1500000 Kbps
[ 7097.542571] [RCE] T_HS settle: autoconfigured, T_CLK settle: autoconfigured
[ 7097.542576] [RCE] NVCSI prod write phy: 0 cil: 0 reg=0x00011c18 mask=0x06070000 value=0x04020000 (was 0x04020100)
[ 7097.542581] [RCE] NVCSI prod write phy: 0 cil: 0 reg=0x00011c84 mask=0x00000fff value=0x00000555 (was 0x00000777)
[ 7097.542585] [RCE] NVCSI prod write phy: 0 cil: 0 reg=0x00011c00 mask=0x00000001 value=0x00000000 (was 0x00000001)
[ 7097.542590] [RCE] NVCSI prod write phy: 0 cil: 0 reg=0x00011c88 mask=0x0000003c value=0x00000000 (was 0x00000555)
[ 7097.542594] [RCE] NVCSI prod write phy: 0 cil: 0 reg=0x00011ce4 mask=0x000000ff value=0x00000027 (was 0x00007411)
[ 7097.542598] [RCE] NVCSI prod write phy: 0 cil: 0 reg=0x00011c84 mask=0x00000fff value=0x00000666 (was 0x00000555)
[ 7097.542603] [RCE] CSI port AB IDAC calibration result with freqband=0:
[ 7097.542607] [RCE] Trio A0 rxab=21 rxbc=24 rxca=15
[ 7097.542611] [RCE] Trio A1 rxab=19 rxbc=19 rxca=19
[ 7097.542615] [RCE] CSI port AB IDAC calibration result with freqband=0:
[ 7097.542619] [RCE] Trio B0 rxab=23 rxbc=18 rxca=16
[ 7097.542631] [RCE] Trio B1 rxab=20 rxbc=16 rxca=16
[ 7097.542635] [RCE] CSI port AB
[ 7097.542639] [RCE] AFE_HFGAIN_IO0_A=6
[ 7097.542643] [RCE] AFE_HFGAIN_IO1_A=6
[ 7097.542646] [RCE] AFE_HFGAIN_CLK_A=6
[ 7097.542650] [RCE] AFE_HFGAIN_IO0_B=6
[ 7097.542654] [RCE] AFE_HFGAIN_IO1_B=6
[ 7097.542657] [RCE] AFE_HFGAIN_CLK_B=6
[ 7097.542661] [RCE] VI ch[35] frame configuration: 3840x2160
[ 7097.542665] [RCE] left skip pixels=0 top skip lines=0
[ 7097.542669] [RCE] right crop pixels=0 bottom crop lines=0
[ 7097.542673] [RCE] pixel format=VI_PIXFMT_FORMAT_T_R16 fmt=196
[ 7099.558479] [RCE] NVCSI prod write phy: 0 cil: 0 reg=0x00011c18 mask=0x06070000 value=0x04020000 (was 0x04020000)
[ 7099.558509] [RCE] NVCSI prod write phy: 0 cil: 0 reg=0x00011c84 mask=0x00000fff value=0x00000555 (was 0x00000666)
[ 7099.558516] [RCE] NVCSI prod write phy: 0 cil: 0 reg=0x00011c00 mask=0x00000001 value=0x00000000 (was 0x00000000)
[ 7099.558522] [RCE] NVCSI prod write phy: 0 cil: 0 reg=0x00011c88 mask=0x0000003c value=0x00000000 (was 0x00000541)
[ 7099.558560] [RCE] NVCSI prod write phy: 0 cil: 0 reg=0x00011ce4 mask=0x000000ff value=0x00000027 (was 0x00007427)
[ 7099.558565] [RCE] NVCSI prod write phy: 0 cil: 0 reg=0x00011c84 mask=0x00000fff value=0x00000666 (was 0x00000555)
Any help is appreciated.
