ERR_NVGPUCTRPERM Despite following instructions
I’m trying to use ncu to profile my GPU, but I keep running into the ERR_NVGPUCTRPERM permission denied error.
I have followed all steps at https://developer.nvidia.com/nvidia-development-tools-solutions-err_nvgpuctrperm-permission-issue-performance-counters and they do not work.
I’m using a RTX 3080 with CUDA 11.2, Driver 460.73.01 on Ubuntu 20.04.
The steps on the webpage are known to work, you might need to verify that they were applied in the correct order. Can you check the following:
Does profiling work for you when run as sudo/root?
Have you created a file with this exact content
options nvidia "NVreg_RestrictProfilingToAdminUsers=0"
within /etc/modprobe.d, e.g. as below
/etc/modprobe.d/nvidia.conf
and rebooted afterwards?
If so, have you confirmed that the file is still present after reboot?
I am not the original poster but the above instructions do work. On a side note, one doesn’t need to reboot. Instead:
  1. Stop the nvidia persistence deamon if that’s running:
    sudo systemctl stop nvidia-persistenced
  2. Unload the nvidia module (after unloading all the dependent modules that it would complain about). It’s usually:
    sudo rmmod nvidia_drm nvidia_uvm nvidia_modeset nvidia
  3. Insert the nvidia module: sudo modprobe nvidia
This will ensure the module is inserted with the option described upthread and ncu works without any issues post that.
