I’m in the process of converting a .pb file into a .bin file.
I have this error:
AttributeError: ‘NoneType’ object has no attribute ‘serialize’
So I added that function.
def replace_fusedbnv3(graph):
“”“Replace all ‘FusedBatchNormV3’ in the graph with ‘FusedBatchNorm’.
NOTE: ‘FusedBatchNormV3’ is not supported by UFF parser.
TensorRT 6.0.1 + TensorFlow 1.14 - No conversion function registered for layer: FusedBatchNormV3 yet - TensorRT - NVIDIA Developer Forums
for node in graph.find_nodes_by_op(‘FusedBatchNormV3’):
gs.update_node(node, op=‘FusedBatchNorm’)
return graph
Then this error occurred.:
Traceback (most recent call last): File “build_engine.py”, line 240, in main() File “build_engine.py”, line 217, in main dynamic_graph = replace_fusedbnv3(dynamic_graph) File “build_engine.py”, line 195, in replace_fusedbnv3 gs.update_node(node, op=‘FusedBatchNorm’) AttributeError: module ‘graphsurgeon’ has no attribute ‘update_node’
Research has shown that it is because the tensorrt api is the seventh version of tensorrt.
- Is there a separate solution for the above errors?
2.Where can I see api for tensorrt 5.x?
