Hi all,
I’m getting started with TensorRT 3.0 here and having a couple of issues. This is all happening on an i5 + NVIDIA GPU + CUDA 9.0 + Tensorflow 1.6 + TensorRT 3.0 using the Python TensorRT API with the intent to deploy to TX2 later (I wish there was a Python API for TX2 …)
So I have a model I’m trying to convert to TensorRT and I get the following error:
input: "Squeeze_2"
attr {
key: "T"
value {
type: DT_INT64
attr {
key: "_output_shapes"
value {
list {
shape {
dim {
dim {
dim {
File "./deeplab-tf2trt.py", line 23, in <module>
uff_model = uff.from_tensorflow_frozen_model(GRAPH_FILENAME, ["SemanticPredictions"])
File "/usr/lib/python2.7/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 103, in from_tensorflow_frozen_model
return from_tensorflow(graphdef, output_nodes, **kwargs)
File "/usr/lib/python2.7/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 75, in from_tensorflow
name="main")
File "/usr/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py", line 64, in convert_tf2uff_graph
uff_graph, input_replacements)
File "/usr/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py", line 51, in convert_tf2uff_node
op, name, tf_node, inputs, uff_graph, tf_nodes=tf_nodes)
File "/usr/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py", line 28, in convert_layer
fields = cls.parse_tf_attrs(tf_node.attr)
File "/usr/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py", line 177, in parse_tf_attrs
for key, val in attrs.items()}
File "/usr/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py", line 177, in <dictcomp>
File "/usr/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py", line 172, in parse_tf_attr_value
return cls.convert_tf2uff_field(code, val)
File "/usr/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py", line 157, in convert_tf2uff_field
'type': 'dtype', 'list': 'list'}[code]
KeyError: 'shape'
I then modify /usr/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py as follows:
:) diff converter.bac.py converter.py
155a156,159
> if code == 'shape':
> val = field_value[0]
> shp = val.dim
> return uff.List('i', [dim.size for dim in shp])
Following which I get this error:
File "/usr/lib/python2.7/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 77, in from_tensorflow
uff_metagraph_proto = uff_metagraph.to_uff()
File "/usr/lib/python2.7/dist-packages/uff/model/meta_graph.py", line 39, in to_uff
graphs=[graph.to_uff(debug) for graph in self.graphs],
File "/usr/lib/python2.7/dist-packages/uff/model/graph.py", line 26, in to_uff
graph = uff_pb.Graph(id=self.name, nodes=self._check_graph_and_get_nodes())
File "/usr/lib/python2.7/dist-packages/uff/model/graph.py", line 46, in _check_graph_and_get_nodes
raise extend_with_original_traceback(e, node._trace)
ValueError: Field name must be a string
Originally defined at:
name="main")
File "/usr/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py", line 29, in convert_layer
uff_graph.custom_node(op, inputs, name, fields)
File "/usr/lib/python2.7/dist-packages/uff/model/graph.py", line 233, in custom_node
return self._add_node(op, name, inputs=inputs, fields=fields, extra_fields=extra_fields)
File "/usr/lib/python2.7/dist-packages/uff/model/graph.py", line 65, in _add_node
node = Node(self, op, name, inputs, fields, extra_fields)
Can anyone shed any light on this error?
