I am trying to connect a custom LiDAR to CAM1 via MIPI. Here are the hardware specifications:
Interface: MIPI CSI-2
Lanes: 4-Lane
Data Format: RAW12
I configured the device tree for this setup. However, I encounter an error when applying it. The system fails to probe the device properly.
Here is my device tree configuration:
/dts-v1/;
/plugin/;
#define CAM_I2C_MUX 19
#define GPIO_ACTIVE_HIGH 0
overlay-name = "ADS6311 + GPIO bidirectional";
/* 40pin GPIO pinmux + 24pin CSI camera in one DTBO */
jetson-header-name = "Jetson 40pin Header";
compatible = "nvidia,p3768-0000+p3767-0000", "nvidia,p3768-0000+p3767-0001", "nvidia,p3768-0000+p3767-0003", "nvidia,p3768-0000+p3767-0004", "nvidia,p3768-0000+p3767-0005", "nvidia,p3768-0000+p3767-0000-super", "nvidia,p3768-0000+p3767-0001-super", "nvidia,p3768-0000+p3767-0003-super", "nvidia,p3768-0000+p3767-0004-super", "nvidia,p3768-0000+p3767-0005-super", "nvidia,p3509-0000+p3767-0000", "nvidia,p3509-0000+p3767-0001", "nvidia,p3509-0000+p3767-0003", "nvidia,p3509-0000+p3767-0004", "nvidia,p3509-0000+p3767-0005";
/* fragment@0: Jetson 40pin header GPIO pinmux (from gpio.dts) */
fragment@0 {
target = <&pinmux>;
__overlay__ {
pinctrl-names = "default";
pinctrl-0 = <&jetson_io_pinmux>;
jetson_io_pinmux: exp-header-pinmux {
hdr40-pin7 {
nvidia,pins = "soc_gpio59_pac6";
nvidia,tristate = <0x0>;
nvidia,enable-input = <0x1>;
nvidia,pull = <0x0>;
hdr40-pin15 {
nvidia,pins = "soc_gpio39_pn1";
hdr40-pin29 {
nvidia,pins = "soc_gpio32_pq5";
hdr40-pin31 {
nvidia,pins = "soc_gpio33_pq6";
hdr40-pin32 {
nvidia,pins = "soc_gpio19_pg6";
hdr40-pin33 {
nvidia,pins = "soc_gpio21_ph0";
/* fragment@1: ADS6311 MIPI CSI-2 RAW12 (from ads6311.dts) */
fragment@1 {
target-path = "/";
__overlay__ {
tegra-capture-vi {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port: port@0 {
reg = <0>;
vi_in: endpoint {
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&csi_out>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <12>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <7500000>;
isp_peak_byte_per_pixel = <2>;
isp_bw_margin_pct = <25>;
modules {
cam_module0: module0 {
badge = "ads6311";
position = "front";
orientation = "1";
drivernode0 {
pcl_id = "v4l2_sensor";
sysfs-device-tree = "/sys/firmware/devicetree/base/bus@0/cam_i2cmux/i2c@1/ads6311@12";
bus@0 {
host1x@13e00000 {
nvcsi@15a00000 {
num-channels = <1>;
#size-cells = <0>;
csi_chan: channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
csi_cahn1_port0: port@0 {
reg = <0>;
csi_in: endpoint {
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&ads6311_out>;
csi_chan1_port1: port@1 {
reg = <1>;
csi_out: endpoint {
remote-endpoint = <&vi_in>;
cam_i2cmux {
status = "okay";
compatible = "i2c-mux-gpio";
#size-cells = <0>;
mux-gpios = <&gpio_aon CAM_I2C_MUX GPIO_ACTIVE_HIGH>;
i2c-parent = <&cam_i2c>;
i2c@1 {
status = "okay";
reg = <1>;
#size-cells = <0>;
ads6311@12 {
compatible = "namuga,ads6311";
reg = <0x12>;
devnode = "video0";
use_sensor_mode_id = "true";
sensor_model = "ads6311";
num_lanes = "4";
mode0 {
num_lanes = "4";
tegra_sinterface = "serial_c";
readout_orientation = "0";
lane_polarity = "0";
mode_type = "bayer";
pixel_phase = "grbg";
csi_pixel_bit_depth = "12";
mclk_khz = "24000";
phy_mode = "DPHY";
discontinuous_clk = "no";
active_w = "60888";
active_h = "64";
line_length = "60888";
dpcm_enable = "false";
cil_settletime = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
ads6311_out: endpoint {
remote-endpoint = <&csi_in>;
port-index = <2>;
bus-width = <4>;
bus-type = <4>; /* MIPI_CSI2_DPHY */
clock-lanes = <0>;
data-lanes = <1 2 3 4>;
link-frequencies = /bits/ 64 <400000000>;
Could you provide any advice on what might be wrong with my device tree? Any help would be appreciated.
Thank you.
