Dear Nvidia Support,
We have been using Xavier NX (P3668) 16GB eMMC model since 2023. I created massflash blob based on JetPack 4.6 / L4T R32.6.1. It has worked well until lately. With some P3668 modules the massflash claimed successful. But the cold boot hits error. Console output is as following:
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.034] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Chip revision : A02P
[0000.045] I> Bootrom patch version : 15 (correctly patched)
[0000.050] I> ATE fuse revision : 0x200
[0000.054] I> Ram repair fuse : 0x0
[0000.057] I> Ram Code : 0x4
[0000.059] I> rst_source : 0x0
[0000.062] I> rst_level : 0x0
[0000.065] I> Boot-device: QSPI
[0000.068] I> Qspi flash params source = brbct
[0000.072] I> Qspi using bpmp-dma
[0000.075] I> Qspi clock source : pllp
[0000.079] I> QSPI Flash Size = 32 MB
[0000.082] I> Qspi initialized successfully
[0000.086] W> No valid slot number is found in scratch register
[0000.092] W> Return default slot: _a
[0000.095] I> Active Boot chain : 0
[0000.098] I> Boot-device: QSPI
[0000.101] I> Qspi flash params source = brbct
[0000.107] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.114] I> Temperature = 55000
[0000.117] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.122] W> Skipping boost for clk: BPMP_APB
[0000.126] W> Skipping boost for clk: AXI_CBB
[0000.130] W> Skipping boost for clk: AON_CPU_NIC
[0000.134] W> Skipping boost for clk: CAN1
[0000.138] W> Skipping boost for clk: CAN2
[0000.142] I> Boot-device: QSPI
[0000.145] I> Boot-device: QSPI
[0000.147] I> Qspi flash params source = mb1bct
[0000.152] I> Qspi using bpmp-dma
[0000.155] I> Qspi clock source : pllc_out0
[0000.158] I> Qspi reinitialized
[0000.161] I> Qspi flash params source = mb1bct
[0000.167] E> NONE: Invalid value MemBct dram size: 0MB for slot: 0.
[0000.173] E> Task 39 failed (err: 0x102)
[0000.176] E> Top caller module: NONE, error module: NONE, reason: 0x02, aux_info: 0x01
[0000.184] I> MB1(1.5.1.7-t194-41334769-98030a79) BIT boot status dump :
000000000001111111111011111111111111111100010000000000000000000000000000000000000000000000000000000000000
[0000.214] I> Reset to recovery mode
I believe the patch, XNX-16GB-r32.6.1-overlay.tbz2, should be the solution. My questions are:
- how can I tell if a module is in 669 level and version >= 301 as stated in the release notes? I tested two modules. A module can boot up has part number 900-83668-0030-000. A module can not boot up with the part number 900-83668-0000-0T0.
- Since the files are in the massflash blob, should I copy the files to replace those in the blob, or I need to recreate the massflash blob?
