Hi all,
We’re trying to flash several 8 GB Jetson Xavier NX modules (part number P3668-0000, production date Q4-2024, Micron DRAM) with JetPack 4.6 / L4T 32.6.1 .
Every attempt stops at the BCT stage with the message:
[ 5.5341 ] 0000000000000102: E> NONE: Invalid value MemBct dram size: 0MB for slot: 0.
Error: Return value 2
Failed flashing t186ref.
Is there an updated MB1/BCT package for JetPack 4.6 that supports this Micron DRAM revision on 8 GB NX modules?
or
Has anyone succeeded in flashing these newer 8 GB boards on JP 4.6, and if so, what exact patch or overlay did you use?
errottr.txt (37.0 KB)
