We got Xavier NX with DDR:16G SOM recently and try to use the following command to flash image with L4T32.6.1 and it failed:
sudo ./flash.sh jetson-xavier-nx-devkit-emmc mmclk0p1
here is the console log:
[0017.389] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0017.397] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0017.402] I> Boot-mode: RCM
[0017.405] I> Chip revision : A02P
[0017.408] I> Bootrom patch version : 15 (correctly patched)
[0017.413] I> ATE fuse revision : 0x200
[0017.417] I> Ram repair fuse : 0x1
[0017.420] I> Ram Code : 0x3
[0017.422] I> rst_source : 0x0
[0017.425] I> rst_level : 0x0
[0017.429] I> USB configuration success
[0020.475] I> bct_bootrom image downloaded
[0020.486] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0020.494] I> Temperature = 28500
[0020.497] W> Skipping boost for clk: BPMP_CPU_NIC
[0020.501] W> Skipping boost for clk: BPMP_APB
[0020.505] W> Skipping boost for clk: AXI_CBB
[0020.509] W> Skipping boost for clk: AON_CPU_NIC
[0020.513] W> Skipping boost for clk: CAN1
[0020.517] W> Skipping boost for clk: CAN2
[0020.521] I> Boot-device: QSPI
[0020.524] I> Boot-device: QSPI
[0020.527] I> Qspi flash params source = mb1bct
[0020.531] I> bct_mb1 image downloaded
[0020.544] E> NONE: Invalid value MemBct dram size: 0MB for slot: 3.
[0020.550] C> OEM authentication of MEM-BCT failed!!!
[0020.555] E> NV3P_SERVER: Failed to verify image bct_mem.
We also using SDK Manager and try to flash L4T32.6.1.1 to the same SOM and also got failed. Here is the SDK Manager terminal log:
17:02:14 INFO: Flash Jetson Xavier NX - flash: [ 3.2551 ] Retrieving EEPROM data
17:02:14 INFO: Flash Jetson Xavier NX - flash: [ 3.2551 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/jay/Desktop/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
17:02:14 INFO: Flash Jetson Xavier NX - flash: [ 3.2561 ] MB2 Applet version 01.00.0000
17:02:14 INFO: Flash Jetson Xavier NX - flash: [ 3.2649 ] Saved platform info in /home/jay/Desktop/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
17:02:14 INFO: Flash Jetson Xavier NX - flash: [ 3.3016 ]
17:02:14 INFO: Flash Jetson Xavier NX - flash: [ 3.3017 ] Rebooting to recovery mode
17:02:14 INFO: Flash Jetson Xavier NX - flash: [ 3.3044 ] tegrarcm_v2 --ismb2
17:02:14 INFO: Flash Jetson Xavier NX - flash: [ 3.3055 ] MB2 Applet version 01.00.0000
17:02:14 INFO: Flash Jetson Xavier NX - flash: [ 3.3100 ]
17:02:14 INFO: Flash Jetson Xavier NX - flash: [ 3.3100 ] Rebooting to recovery mode
17:02:14 INFO: Flash Jetson Xavier NX - flash: [ 3.3123 ] tegrarcm_v2 --reboot recovery
17:02:14 INFO: Flash Jetson Xavier NX - flash: [ 3.3134 ] MB2 Applet version 01.00.0000
17:02:16 INFO: Flash Jetson Xavier NX - flash: [ 3.3276 ]
17:02:16 INFO: Flash Jetson Xavier NX - flash: --- Reading board information succeeded.
17:02:16 INFO: Flash Jetson Xavier NX - flash: Parsing module EEPROM:
17:02:16 INFO: Flash Jetson Xavier NX - flash: --- Parsing board ID (3668) succeeded.
17:02:16 INFO: Flash Jetson Xavier NX - flash: --- Parsing board version (301) succeeded.
17:02:16 INFO: Flash Jetson Xavier NX - flash: --- Parsing board SKU (0003) succeeded.
17:02:16 INFO: Flash Jetson Xavier NX - flash: --- Parsing board REV (B.0) succeeded.
17:02:16 ERROR: Flash Jetson Xavier NX - flash: Error: Target board not found.
17:02:16 INFO: Flash Jetson Xavier NX - flash: [ Component Install Finished with Error ]
17:02:16 INFO: Flash Jetson Xavier NX - flash: [host] [ 5.16 MB used. Disk Avail: 374.88 GB ]
17:02:16 INFO: Flash Jetson Xavier NX - flash: [ NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP Install took 25s ]
17:02:16 ERROR: Flash Jetson Xavier NX - flash: command terminated with error
17:02:16 SUMMARY: Flash Jetson Xavier NX - flash: First Error: Installation failed.
Have any idea about how to flash the image to the Xavier NX DDR 16G SOM ?
