I’ve been porting some code from CUDA to OpenCL and I get the following error in my code when I try to run it. The kernel builds fine and so does the program. It’s during runtime that it screams. Here is the info I feel would be relevant, but let me know if anything else is needed.
[codebox]size_t localWorkSize = {16, 4, 4};
size_t globalWorkSize = {27, 45 * 38, 1};[/codebox]
[codebox]error |= clSetKernelArg(fdk_kernel, 0, sizeof(cl_mem), (void *) &dev_vol);
error |= clSetKernelArg(fdk_kernel, 1, sizeof(int2), (void *) &kargs->img_dim);
error |= clSetKernelArg(fdk_kernel, 2, sizeof(float2), (void *) &kargs->ic);
error |= clSetKernelArg(fdk_kernel, 3, sizeof(float4), (void *) &kargs->nrm);
error |= clSetKernelArg(fdk_kernel, 4, sizeof(float), &kargs->sad);
error |= clSetKernelArg(fdk_kernel, 5, sizeof(float), &kargs->scale);
error |= clSetKernelArg(fdk_kernel, 6, sizeof(float4), (void *) &kargs->vol_offset);
error |= clSetKernelArg(fdk_kernel, 7, sizeof(int4), (void *) &kargs->vol_dim);
error |= clSetKernelArg(fdk_kernel, 8, sizeof(float4), (void *) &kargs->vol_pix_spacing);
error |= clSetKernelArg(fdk_kernel, 9, sizeof(int), &blocksInY);
error |= clSetKernelArg(fdk_kernel, 10, sizeof(cl_float), &invBlocks_Y);
error |= clSetKernelArg(fdk_kernel, 11, sizeof(cl_mem), (void *) &dev_img);
error |= clSetKernelArg(fdk_kernel, 12, sizeof(cl_mem), (void *) &dev_matrix);[/codebox]
[codebox]__kernel void kernel_fdk(
__global float *dev_vol,
__global int2 img_dim,
__global float2 ic,
__global float4 nrm,
__global float sad,
__global float scale,
__global float4 vol_offset,
__global int4 vol_dim,
__global float4 vol_pix_spacing,
__global uint Blocks_Y,
__global float invBlocks_Y,
__global float *dev_matrix,
__global float *dev_img
)[/codebox]
The system errors out when trying to run the kernel using the following command:
[codebox]error = clEnqueueNDRangeKernel(command_queue, fdk_kernel, 3, NULL, globalWorkSize, localWorkSize, 0, NULL, NULL);[/codebox]
In C, since int2, int4, float2 and float4 don’t exist, I created the following:
[codebox]struct int2 {
int x;
int y;
struct int4 {
int x;
int y;
int z;
int w;
struct float2 {
float x;
float y;
struct float4 {
float x;
float y;
float z;
float w;
};[/codebox]
