error F0000 : Internal compiler error
Dear All,
A simple cuda fortran code was compiled and executing successfully on a desktop GPU(8800GT). However, an error occurred while compiling on the thinkpad T430 with NVS 5400M GPU with the following message “error F0000 : Internal compiler error. Device compiler exited with error status code 0”. Can someone help me to figure out this problem?
Hi Stanely,
Can you post the complete output? This just means the backend CUDA compiler failed for some reason. Hopefully, the rest of the output will help understand why, Though, I may need to ask you to either post or send to PGI Customer Service (trs@pgroup.com) a reproducing example in order to determine the cause.
Thanks,
Mat
