Error: Function id not found when testing nvidia/usdcode model
Gemini 說了
這看起來是 NVIDIA NIM (NVIDIA Inference Microservice) 或 AI Foundation Models 介面在調用特定函數時發生的後端錯誤。
以下為你準備的英文貼文草稿,你可以直接複製到 NVIDIA 官方論壇(如 Developer Forums):
Subject: Error: Function id not found when testing nvidia/usdcode model
Body:
Hi NVIDIA Team,
I encountered a persistent error while trying to use the nvidia/usdcode model on the NVIDIA API Catalog / Experience playground.
Error Message:
Error: Function id ‘9cd20136-a5d3-4679-80c8-a7470a4f2559’ version ‘null’: Specified function in account ‘NtdWIOlq9M-CYlmoK2kS6Qp53OQ6Y9Dmou6DMUaiP1M’ is not found
Steps to Reproduce:
  1. Navigate to the nvidia/usdcode model experience page.
  2. Input a prompt (e.g., “What is LIVRPS?”).
  3. The interface returns the “Function not found” error instead of generating a response.
Additional Information:
  • Model: nvidia/usdcode
  • Time of Occurrence: March 26, 2026
  • Environment: Web-based Model Card Experience / Playground
I get the same thing with your repro steps. I’ll alert someone internally. Thanks!
@qaq81704 Looks like the USD Code NIM is being deprecated. Please check out GitHub - NVIDIA-Omniverse/kit-usd-agents: The base repository to build OmniverseKit USD agents. · GitHub as an alternative.
I am currently hitting synchronization bottlenecks that are impacting the development of an advanced mission control dashboard
I am building a multi-agent orchestration system that coordinates coding tasks across different AI providers
I am frequently hitting the default rate limits, which causes timeouts and breaks the workflow synchronization. A higher rate limit would allow for the seamless testing and execution required for this level of orchestration
I would be immensely grateful if a member of the developer infrastructure team could review my account for a rate limit exception
Thanks for your help .
