brightness_config Protobuf message
This protobuf message configures the translation augmentation operator. Defining this activates translating the images across the x and/or y axes.
translate_x: 8
translate_y: 8
Using the offline augmenter, it results in a folder with augmented images and labels. The filenames however aren’t changed. So if I want to use both original AND augmented images (which have to be all in one directory: image_2) I have to do some programming to change the filenames of the images and according annotationfiles. Is there a feature in the augmenter to change filenames?
Currently, the output path is specified by “--output-dataset”. See Offline Data Augmentation — TAO Toolkit 3.22.05 documentation. If want to merge the augmented files to the original folder, yes, need to do some programming to differentiate the files.
I will mark down this feature request from your side.
