(kv) [ding3@gpua003 torch]$ nsys profile -o cuda_test python cuda_test.py
Average of the elements in tensor a: 2.0
Generating '/tmp/nsys-report-c641.qdstrm'
Failed to create '/projects/bcjw/ding3/torch/cuda_test.nsys-rep': File exists.
Use `--force-overwrite true` to overwrite existing files.
[1/1] [========================100%] nsys-report-d601.nsys-rep
Importer error status: Importation succeeded with non-fatal errors.
**** Analysis failed with:
Status: TargetProfilingFailed
Props {
Items {
Type: DeviceId
Value: "Local (CLI)"
Error {
Type: RuntimeError
SubError {
Type: ProcessEventsError
Props {
Items {
Type: ErrorText
Value: "/build/agent/work/323cb361ab84164c/QuadD/Host/Analysis/Modules/TraceProcessEvent.cpp(45): Throw in function const string& {anonymous}::GetCudaCallbackName(bool, uint32_t, const QuadDAnalysis::MoreInjection&)\nDynamic exception type: boost::wrapexcept<QuadDCommon::InvalidArgumentException>\nstd::exception::what: InvalidArgumentException\n[QuadDCommon::tag_message*] = Unknown runtime API function index: 440\n"
**** Errors occurred while processing the raw events. ****
**** Please see the Diagnostics Summary page after opening the report file in GUI. ****
Failed to create '/projects/bcjw/ding3/torch/cuda_test.qdstrm': File exists.
Generated:
/tmp/nsys-report-d601.nsys-rep
my environment
nvcc 11.8
NVIDIA Nsight Systems version 2022.4.2.1-df9881f
NVIDIA-SMI 535.161.08 Driver Version: 535.161.08 CUDA Version: 12.2
nsys status --environment
Timestamp counter supported: Yes
CPU Profiling Environment Check
Root privilege: disabled
Linux Kernel Paranoid Level = 2
Linux Distribution = RHEL
Linux Kernel Version = 4.18.0-477.51.1.el8_8.x86_64: OK
Linux perf_event_open syscall available: OK
Sampling trigger event available: OK
Intel(c) Last Branch Record support: Not Available
CPU Profiling Environment (process-tree): OK
CPU Profiling Environment (system-wide): Fail
See the product documentation at Nsight Systems — nsight-systems 2024.2 documentation for more information,
including information on how to set the Linux Kernel Paranoid Level.
